Question about Dell 5100cn Laser Printer
Dell 5110cn printer error code 016-317
The error code comes up and ask to restart printer but it still comes on
  • fredafraid Apr 15, 2009
    I still have the same problem but I read that I had to update the firmware, that I did (I found the relevant applications on Dell website).
    Unfortunately it didn't work: I ran the firmware update tool through USB but even though the data were sent, the printer never complete the installation and is permanently saying "PLEASE WAIT... USB)
    ==> the printer is now blocked either on stand by (please wait mode) or showing the "016-370 erro - restart".
    What should I do please??!!
    Thanks
  • 9 Answers
The 016-317 on this printer refers to the printer not being able to communicate with the MCU board. This is what you should do. This was pulled from support.dell.com. Which is the same troubleshooting trees as the phone/internet agents use. If this doesn't solve your issue, you will more than likely need to update the firmware of the printer, or replace the board. STEP: Reseat the controller card on the 5100cn-series printer.
Additional Information dell 5110cn printer error code 016-317 - image001.gif CAUTION: Before you perform any of the following steps, read the Precautionary Measures warning (located in the Resources/Additional Resources section) for your personal safety and to prevent damage to the computer system from electrostatic discharge.
To reseat the controller card, perform the following steps:
  1. Make sure that the printer is turned off and unplug all cables including the power cord from the rear of the printer.
  2. Pull the tray rear cover so that the top edge tilts out, then lift the tray rear cover off its hinges. (Figure 1)
    Figure 1 - Remove the Tray Rear Cover
  3. Remove the three screws on the control board from the back side of the printer. (Figure 2)
    Figure 2 - Remove the Three Screws
  4. Remove and reinsert the controller card from the printer by the handdell 5110cn printer error code 016-317 - remove%20control%20board%205100cn.jpgmg src="http://i.fixya.net/uploads/images/remove%20control%20board%205100cn.jpg" alt="remove%20control%20board%205100cn.jpg" class="h_mi" />
    Figure 3 - Reseat the Controller Card
  5. Tighten the three screws on the control board on the back side of the printer.
  6. Reattach the tray rear cover to the back of the printer.
Posted on Aug 24, 2009
094-402 error code resolution?
web search dell laser printer error codes
Sep 15, 2015 | Dell 5110cn Color Laser Printer 5110 Cn
003-345
Please reply with exact error so that we can find solution....................thanks.
Jul 02, 2008 | Dell 5110cn Laser Printer
I have a Dell Printer model 5110cn and it has error code 001-361. I restarted printer and computer but error code will not go away and printer will not function. HELP!!
  1. Prior to setting up port forwarding in your router, you must manually enter an IP address into the Nintendo 3DS Internet settings.
  2. Use your router settings to forward the ports 9103, and 50000 through 60000, to the IP address you provided your Nintendo 3DS system.
for more help visit CBR Tech Solutions
Aug 18, 2011 | Office Equipment & Supplies
DELL 5110CN 093-426? What error is this?
093-426 is a "black toner replace soon" error message. first make sure that you're using a dell-branded toner cartridge (you can order online here: www.dell.com/supplies) & you can try reseating the black toner cartridge.
Jul 13, 2009 | Dell 5110cn Laser Printer
Dell error 007 371.How to solve or reset this problem ?thanks
http://support.dell.com/support/edocs/software/dtk/2.4/CLI/pdf/dtk24cli.pdf look here codes are posted
May 24, 2009 | Dell 5110cn Laser Printer
Error message ''001-361 restart printer''
Shut down the computer and the printer.
Pull the power cord from the printer. Wait a minute and restart the printer. After it is fully ready, restart the computer.
Mar 18, 2009 | Dell 5110cn Laser Printer
Dell 5110 004-310 reset printer error
This may not solve your problem but it did mine when I got the "reseat cartridge" error. I had inadvertently ordered the cartridge for the 5100cn, which looks exactly the same as the 5110cn and actually fits if you order the generic version (the Dell 5100cn cartridge looks like the 5110cn but doesn't quite fit).
So, first make sure that you ordered the 5110cn cartridge. (And if you need two opened 5100cn cartridges, I've got them up on ebay :( !!!!)
Jan 23, 2009 | Dell 5110cn Laser Printer
ERROR CODE 010-387 RESEAT FUSER
I had the same exact issue with my 5110cn printer. It turned out that the 5100 fuser is wrong for this printer and will not work. The 5110 has a circuit board on the inside and the 5100 fuser does not. Dell item number KX491 with a BCN # of 652423 works perfectly.
Hope this helps!
Jan 08, 2009 | Dell 5110cn Laser Printer
Error message CRUM ID 093-693
please help with diagnosis of following error for Dell 5110CN CRUM ID -093-665
I tried everyting. I took the imaging drum out and poot it in, and notihng. This imaging drum worded before OK.
Tom
Dec 12, 2007 | Dell 5110cn Laser Printer
Error 016-313
Try a firmware update.
if that doesn't solve it, reseat controller card.
if that doesn't solve it, replace controller card
For the 370 error, try the same steps. If they don't solve, then replace the Machine Control Unit.
Replaceing these parts can get expensive.
Aug 16, 2007 | Dell 5110cn Laser Printer
Dell 5100cn Laser Printer Logo
2,590 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
