Question about Acer Aspire 5720-6661 Notebook PC
The cursor moves by itself during typing. It jumps to a position and I find myself typing in the wrong place.
  • Anonymous Mar 25, 2009
    I have a new Acer Aspire 4710G,and it is beautiful.
    The only problem is the cursor keeps skipping when i'm typing!
  • Anonymous Apr 11, 2009
    mines does the exact same thing
  • 259 Answers
I have found this is usually the small button in the middle of the keyboard (mouse button) I have tried some software to remove this problem but it did not on my laptop I ended up carefully removing the key board and disconnecting the two wires that go to the button My cursors kept moving across the screen
Posted on Feb 18, 2009
  • Doug Simmans
    Doug Simmans Sep 05, 2014
    I had this with a Sony and the only way to stop it was to disable the mouse pad and use a usb mouse instead. I think with some laptops the are around the edge of the mousepad is very sensitive so that if you brush the sedg with your palm while typing it causes the mouse to place the cursor at the position that you last moved it to.
Frequently during the typing of a document my cursor will jump to a completely different part of the document and until I lookup I'm typing in the wrong section. I'm not touching the internal mouse pad....
Be very careful about this. When I used my laptop all the time the same thing would happen from time to time.
If you touch the mouse pad at all it will move your cursor. Even lightly touching it with part of your hand can do the trick. Its best to hold your hands as high off the laptop as you are comfortable with. Try this and see if the problem persists.
Apr 07, 2011 | Dell Latitude E4300 Notebook
Jumping cursor
Open touchpad properties, touchpad settings section, enable Touchcheck, set the slider to minimum setting Click OK
TouchCheck disabled the touchpad while typing
Jul 10, 2010 | Dell Latitude E4300 Notebook
Keyboard problem- cursor keeps jumping around when I'm typing
You may be inadvertently touching the touch pad with the side of your hand or fingers as you type OR the touch pad itself is bad and needs replacement.
Jan 07, 2010 | Acer Computers & Internet
I am having a problem when I type and the cursor moving
This happens when your hands get to close to the palmrest and your wrists are actually causing the cursor to jump to another spot. Go to the control panel > mouse> settings > highlight the touchpad listed and select the settings button. Look through the entries and there is a setting for palmrest sensitivity. Turn down the sensitivity so your hands and wrists don't trigger a cursor movement. The hardware and drivers are fine, this is a setting adjustment.
Oct 10, 2009 | HP Pavilion DV6700T Notebook PC
I bought a lenovo notebook 3000 G430 model. I have a problem hile typing data in keypad the cursor automaticlly jumps to the other position. could someone help me out in this
This is probably caused by you catching the touchpad while ypu are typing. It thinks you have clicked the mouse so the cursor moves to the mouse position. You could try adjusting the click sensitivity of the touchpad in Control panel>mouse
Jul 25, 2009 | IBM Computers & Internet
Cursor jumping
maybe its keyboard problem ,some keys on ur a new text document and test all the keys of keyborad if any type more than 1 times when u push u have to clean under that key .
Jun 09, 2009 | Sony VAIO Notebook
Cursor jumps around
Does the cursor jump around when your hands are nowhere near the touchpad? The touchpads are heat and pressure sensitive. I personally have very warm (and sometimes sweaty) hands. I have this problem often when working on laptops. If I hover my hands over the pad, it causes the mouse to move. I've had to take a business card, put tape on one side of it, and use it as a flip-cover for the touchpad on most of my laptops. If the cursor moves around when you're nowhere near the laptop, then you may want to try disabling the pointing stick (if it has one). I've had several clients with laptops where the pointing stick mouse control go crazy and move and click on things.
May 13, 2009 | Dell Inspiron 1420 Laptop
I have Compaq Presario V3826TU which i bought about 10 months ago. when i am typing in fast mode, the key 'a' and some key on the left hand side tend to working wrongly. For example when A key is press,...
Mar 05, 2009 | Computers & Internet
Cursor position jumps back or down a line or two in Outlook.
Are you using windows vista? If so, that is a common problem with vista. The reason is the driver for the touchpad. Your palm may brush up against the touchpad while you are typing which moves the cursor all around. You can open up the properties for the touchpad (in control panel or by right clicking the icon next to the clock that corresponds to the touchpad and selecting properties), and play around with the sensitivity and palmtouch options in it as well as make sure you have the most up to date drivers available if you are using vista. Oh and one more thing, please give this solution a fixya rating. Thanks!
Dec 27, 2008 | Computers & Internet
Typing problem
the problem is where the mouse cursor is. When you begin to type have the mouse cursor as far down the page as possible the glide pad can pick up the slightest variant of pressure and move your text to the position where the mouse cursor is.
Jun 04, 2008 | Computers & Internet
Acer Aspire 5720-6661 Notebook PC Logo
758 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
