Question about GPX DV7500 System
Instruction manuel needed for GPX dv7500 system please
Remote control will not allow video signal and surround sound speaker volumes are not balanced properly.
    President:
  • 1,734 Answers
You can get a user manual from http://manualfox.com
Just send them a search request.
Posted on Feb 18, 2009
No audio come out in speakers.
change the input. Amp could be blown. the speakers should have some type of hum when volume is turned up.
Apr 04, 2014 | Sony Av Digital Audio Video Control Center...
The rear surround sound speakers are not working.the front ones are and the sub woofer works fine also. everything is connected properly but have no idea what to do to make them work.can you please help
Make sure that the media you are using has the surround sound...eg. if you are listening to the radio then the rear speaskers will not work as the signal is not transmitted in surround...if you put a dvd in that has the dolby digital signal encoded on it then the rears should work....the rears will only work when you have the receiver in the surround mode..make sure the receiver is in the right mode...also, you may have rear speaker volume settings in the setup menu that may need to be set up..go through the manual and see if there is a setting for the rear volume...most home theater sets have this feature and it allows you to set up the system for different size rooms
Jun 11, 2011 | Sony DAV-DZ850KW Theater System
Only two speakers work when a CD is being played...either MP3 or regular CD's. Why are the other speakers and subwoofer not playing sounds. Model DV7500
You mean a GPX DV7500? I can't find the manual. Do YOU have it? Do all the speakers work during setup or on real multichannel sources?
If you're using analog inputs and NOT selecting any of the DSP modes you will hear just stereo.
May 20, 2011 | Audio Players & Recorders
The Directv codes for my Samsung HT-TZ512 surround sound/dvd player don't work. How can I program my Directv remote to control the dvd player? The codes I've tried are 20490, 20573, 20820, 21075 and 20899....
sometimes directv remotes do not work with surround dvd players. Try doing an automatic code search . Most of the time it will only allow you to power the dvd player and operate the volume.
Oct 23, 2009 | Samsung HT-TZ512T Theater System with...
Hook up to tv
hello there. name is ryan lets see if this helps.
typically in a combination unit there is no rca audio ouputs on the tv. reason being is it is a combo unit not meant to be a item within a home theater system. it has the whole home theater built in it. ;) however if there is any audio output jacks on the tv you should be able to wire the surround sound unit up via rca cable output from tv to input on reciever for surround sound
Feb 13, 2009 | GPX DV7500 System
Rear and Centre speakers not working
The system comes with l remote which provides controls for "Power", "Master Volume", "Bass (Subwoofer) Volume" and "Matrix Mode" . Matrix mode allows you to spread stereo sound to all speakers where your sound card may not have the ability to do so.
I find that the "Stereo Surround" setting works best as opposed to the recommended "CMSS" setting
Oct 22, 2008 | Logitech X-540 Multimedia Surround Sound...
Connect to dvd player
On the back panel of your tv you will see two audio inputs labeled AUDIO TO HI-FI. Plug your surround sound audio jacks, ( red and white ) into that. Plug your video jack ( yellow ) into what ever number input you are going to use for dvd, if needed. This will allow you to watch tv and hear it in your surround sound. You should also go to menu- then- audio option and turn off your tv internal speakers, this will allow your tv remote to control your volume of surround sound. Hope this helped.
Sep 07, 2008 | Hitachi 51F59 51" HDTV Projection...
How do i hook up Altec Lansing AVS500 speakers to my computer
Hello sweetnikki1,
The Altec Lansing AVS500 are 4.1 channel speakers, meaning 4 speakers (front, rear and 2 satellites) and a subwoofer.
1. Make sure the rear and/or center/sub audio cable is plugged in to the correct port. On most surround sound cards, the rear audio port is black, the front audio port is green, and the satellite cords are similarly color coded. The output from the sub to the front right satellite is a heavy-duty cable that immediately stands out from the rest. This cable is thicker because the right front speaker has most of the system controls on it: power, volume, and surround volume. If you do not have a surround sound card, make sure you obtain the proper adapter or use surround sound emulation if your speaker system offers it. If you are not sure if you have a surround sound card, please check with the manufacturer of your sound card for details.
2. Make sure your sound card supports the same amount of channels as your speaker system contains. For 4.1 systems, it should have a front and rear speaker jack on the card. The card should be properly installed and configured. Please contact your sound card manufacturer for details. If you do not have a surround sound capable sound card, on the left side are the sub level control, the AC jack, satellite outs, and a sound mode switch. With this switch you decide between Gaming and Stereo. In Stereo mode, the normal stereo signal is sent to both the fronts and the rears. In Gaming mode, the speakers use the four-channel signal from your soundcard. Hence if you just hav the regular sound card, do not connect the satellite speakers and use Stereo mode.
3. You can also use an adapter to split the signal for the front and rear speakers. This type of adapter is a 3.5mm male to 2-3.5mm female jacks. You can purchase this adapter at your local electronic store. Please refer to your manual if you do not know if your speaker system can emulate surround sound.
Hope this helps..
Should you have any further questions, please feel free to post them here. Please do not assign a rating until you feel your problem is resolved. I will try my best to help you further, if need be.
If you are satisfied with my solution or have no other questions, please close the problem by assigning a FixYa! rating for my solution. I would be very grateful for your show of appreciation.
Thank you for using FIXYA!
Cheers!
IrishDruid
Apr 20, 2008 | Computers & Internet
The volume is way to high even on the lowest setting
Sorry I don't have a solution. We have this model and ours is loud also, at the very lowest setting. I disconnected some of the speakers, and sometimes have to put the working speakers into a drawer to lower the sound.
May 29, 2006 | GPX DV7500 System
Progressive Scan Mode Resetting
Hi, Open the CD and press return on the remote to reset it back to Interlace mode. Thanks Annarr
Jan 14, 2006 | GPX DV7500 System
GPX DV7500 System Logo
250 people viewed this question
Top GPX Audio Players & Recorders Experts
Are you a GPX Audio Player and Recorder Expert? Answer questions, earn points and help others
