Question about Dell Inspiron 1501 Notebook
Dell inspiron 1525 ac adapter not charging the battery. Have two of them and niether work on this computer. I have another computer that takes the same family of adapters and they both work fine on that one. have checked all the pins that connect it to the motherboard and it is fine. is there a ac adapter driver for vista that might be causeing this problem?
  • 569 Answers
This is a common problem. The issue is almost certainly a faulty power board, a small PCB that accepts the power input and also holds two USB sockets – located on the top left side of the PC near the screen.
If your machine is in warranty the solution is a Dell repair/replacement.
If out of warranty then you will need to replace the component, or have someone do it for you.
The procedure involves buying a new power board, (Part number 48.4W006.021, available from Dell or more cheaply on Ebay at about £35), and replacing the old component. This is a task you should only undertake if you are comfortable with disassembling your laptop right down to removal of the system board. Instructions can be found in the Dell Service Manual at
http://support.euro.dell.com/support/edocs/systems/ins1526/en/SM/index.htm
This is not difficult if you are competent at this type of repair, but I would not recommend it for someone that has not taken a laptop apart before.
Posted on Dec 17, 2009
    Novelist:
  • 148 Answers
what you are telling me proves that the AC adapters are working fine, so there is something that is causing the issue at the laptop,
if your laptop is not charging when its in off state as well, then it signals that most likely you are having a hardware problem
call dell technical support they will replace the faulty hardware, let them know what you already have tried with the laptop to troubleshoot.
Further Queries are welcome
Posted on Feb 18, 2009
    Guru:
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 49 Answers
You can reference the article :Laptop not receiving power from AC Adapter
if your ac adapter is bad ,you can buy "dell 1525 adapter cheaply at professional online store such as udtek.com
hope it can give some help
Posted on Feb 05, 2010
I have a Dell Inspirion 1525. I have a fairly new after market replacement battery which I have only had now for 4 months. I am using Vista. As soon as I unplug, computer shuts down. I go to power settings...
The adapter is working correctly. The battery is either slow to charge or in need of replacement.
It's possible your battery isn't charging at all so to test this boot into bios -> battery status and watch it run overnight.
Sep 09, 2010 | Dell Inspiron 1525 Notebook
My Dell Inspiron 1525 is now around 4 years old and recently it has not been able to charge and only works when it is plugged in. Also when i start the laptop, it displays a message saying i need to...
As you say the system is 4 years old update the bios
your download link is here!
IMP. Be sure to plug in the battery and it should be charges above 10 % and the system should be connected to the mains power supply also ensure there will not be a power outage during the update process
this will resolve the issue 100 %
Dont forget to say thanks!
Aug 11, 2010 | Dell Inspiron 1525 Notebook
Problem of charging the battery
Check battery indicator. If OK, update BIOS. If no change, check battery bios info, if AC Adapter is incorrect, replaces it. Please comment if the information provided has been helpful for the improvement of my support assistance. Thank you and regards.
Jul 12, 2010 | Dell Inspiron 1525 Notebook
Dell inspiron 1525 battery not charging
Take out battery & place it again.
If does not charge again, contact sevice centre.
Apr 16, 2010 | Dell Inspiron 1525 Laptop
Dell 1525 won't run on ac but will on generic battery
Dell systems will not charge the battery without a Dell Branded AC adapter connected to the system (The BIOS looks for the adapter ID and disables the battery charger if not ID'd)
It appears, that since the system will not power on with either AC adapter, that there is a problem with the power connection of the system. You can replace the power board
http://cgi.ebay.com/DeLL-Inspiron-1525-1526-Power-Jack-Board-48-4W006-011_W0QQitemZ380212346664QQcmdZViewItemQQptZMotherboards?hash=item58866bff28#ht_953wt_1165
if that fails to resolve next is the motherboard
http://shop.ebay.com/i.html?_nkw=dell+inspiron+1525+motherboard&_sacat=0&_dmpt=Laptop_Adapters_Chargers&_odkw=dell+inspiron+1525+charger+board&_osacat=0&_trksid=p3286.c0.m270.l1311
Mar 14, 2010 | Dell Inspiron 1525 Notebook
Hey i had my dell inspiron 1525 for quite a while and now the charger stopped working for some reason. i need help
The charging circuit requires an ac adapter with an intact sensing pin in the center of the Adapter barrel plug that connects to the computer. If the pin is bent or broken, the charger is disabled.
If possible, try a known good adapter from another D or E Series Dell Portable. If a KG adapter charges the battery, replace the adapter. If it makes no difference, then replace the motherboard
Jan 22, 2010 | Dell Inspiron 1525 Notebook
Dell inspiron 1525 battery doesnot charge
1. remove all external peripherals 2. try to use ac adapter alone check if laptop will power on. 3. put back batt in with ac adapter. 4. check bios (power on laptop keep tap on F2) 5. check for the bios version, battery info and battery health. 6. check if batt is 0% or 10% charge 7. check battery health and info if the ac adapter is determine or not. also check if batt is performing normally. 8. if batt has 10% charge then download the latest bios for your system. download it from support.dell.com
Nov 12, 2009 | Dell Inspiron 1525 Notebook
Ac adapter will not charge my computer
If the laptop will run from the adaptor, then the adaptor is probably fine. That being the case, if the charge light flashes when the adaptor is plugged in, the battery is faulty. No charge light on an otherwise working system is probably the battery charging circuit in the laptop.
May 17, 2009 | Dell Inspiron 1525 Laptop
Can I use ther Targus Adaptor for Inspiron 1525
On the long term, a power adapter with a bigger amperage can damage battery and battery charger.
Better to get an adapter with same specs as the 65/70W one , or an original replacemant:
Dell Inspiron 1525 New AC Power Adapter Supply $14.29 - Buy.com Dell Inspiron 1525 65 Watt Original AC Adapter $25.00 - parts4nb.com Dell Inspiron 1525 Power Cord PA-12 $16.95 - AmeriMax Advance
DELL Inspiron 1525 DC Power Laptop Adapter ... £25.23 - B2C Shopping UK DELL Inspiron 1525 Laptop AC Adapter power adapter £38.99 - Very Good Battery Dell Inspiron 1525 Ac Adapter Charger Power ... £16.50 - eBay UK
AU/NZ - DELL INSPIRON 1505 E1405 E1505 AC Adapter Power Supply
Dell : Lind Electronics 70-Watt DC Power Adapter for Dell Inspiron
Apr 22, 2009 | Dell Inspiron 1501 Notebook
Dell Inspiron will not work on Battery.
At the very minimum its your battery. The other side is that it could be your power utility inside your laptop. Lets try getting a new battery first.
Note: Try a different AC outlet first.
Mar 12, 2009 | Dell Inspiron 1525 Notebook
Dell Inspiron 1501 Notebook Logo
1,434 people viewed this question
Alun Cox
