Question about Jenn-Air JCB2282H Side by Side Refrigerator
Just want to know where and how to gain access to the defrost timer in my black JENN-AIR JS21 side by side fridge. Cheers Al.
  • Alastair Nicholson
    Alastair Nicholson Feb 18, 2009
    Will heed your advice.
    Cheers.
    Problem Solver:
  • 14 Answers
Most times I've found them behind a removable kick-panel in front of the fridge.
Posted on Feb 18, 2009
Jenn-Air js42sefxda. Freezer and fridg won't cool. Ice was built up at the top of the freezer. I turned it off for 24 hours and once the ice melted it operates normally. How do I prevent the ice...
There is a defrost timer that normally controls the defrost cycles.
It appears that the defrost timer has failed. A new timer needs to be fitted. a technician can help you with that
Mar 24, 2011 | Jenn-Air JS42SEFXDA Stainless Steel Side...
MY JENN-AIR REFRIGERATOR #JCD2389GES IS NOT COOLING ON THE REFRIGERATOR SIDE. THE FREEZER IS OKAY. THE REFRIGERATOR TEMPERTURE IS 60 DEGREES F.
Possible that the vent is getting blocked to prevent the cool air to be blown into the fridge section. So make sure that the auto defrost is working, if not check the auto defrost timer section, the fan, the heaters.
make sure that the thermostat is set to normal.
Finally shut off the fridge for 6-8 hours and see if the cooling resumes. If so the defrost section must be revisited
Oct 30, 2010 | Jenn-Air JCD2389G Side by Side...
JCD2289AES jennair fridge refridgerator side is not cold but the freezerside works
The fridge side is not getting enough cold air from the freezer side. This could be due to a few things. The vents from the freezer is blocked, or the evaporator fan/motor has failed, or the evaporator coil is iced up due to the defrost circuit failure.
To check which is the problem you will need to empty the freezer to you can get access to the panel that covers evaporator coil. After removing the panel check to see if the fan is turning, also note whether the evaporator coil is iced up. If it is iced up, then the defrost circuit is failed. The problems usually are a failed defrost heater, defrost timer or defrost thermostat.
Aug 12, 2010 | Jenn-Air Refrigerators
I have a Jenn Air JS48FSDBFA. The freezer works fine but the fridge wont get below 46-47 degrees. What could it be.
If the freezer is staying cold it sounds like a defrost system problem. A bad timer, heater or thermostat can cause frost to build up on the coils and block air flow to the refrig side. Check out ACMEHowTo.com for troubleshooting the defroster problem
May 21, 2010 | Jenn-Air JCB2280HES Side by Side...
On a Jenn Air Model JCD2289AES refrigerator, how do I replace the defrost timer - I have the new timer
According to your model number you don't have a defrost timer you have an adaptive defrost control which monitors the freezer and fridge and determines when it's time to defrost. It's part 13 on this diagram. http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=JCD2289AES&productCategoryId=0165000&brandId=1266&brandDescription=JENN-AIR&modelName=SIDE-BY-SIDE-REFRIGERATOR&diagramPageId=00007&componentDescription=CONTROLS&documentId=M0406285&blt=06
If the defrost thermostat and heater are good then replace the control if you are have defrost problems.
Mar 11, 2010 | Refrigerators
Jenn Air side by side refrigerator Model JCD2389GES is still making ice, food is still frozen on ice making side, but the refrigerator side is not cold, milk is souring rapidly and vegetables are turning...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
Dec 09, 2009 | Jenn-Air JCD2389G Side by Side...
Frigerator not working
2 possible issues. freezer fan is not working ,should be able to hear it inside frz.2nd issue auto defrost is not working, look for ice/frost build up on rear wall of frz.possible timer or heater issue Hope this helps ,pleases rate my response :)
Jun 25, 2009 | Jenn-Air Jenn Air Side-By-Side...
Fridge not cooling
We will need to see if yours has the defrost timer or the adaptive defrost. Let me know if your model is the JSD2789GES. I have the manual we can work with. ..Sea Breeze
Jun 19, 2009 | Jenn-Air JSD2789GES Side by Side...
Jenn-Air JCB2389GRS Fridge not cooling properly
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
puiodf
Mar 15, 2009 | Jenn-Air JCD2389G Side by Side...
Icemaker is not freezing ice, freezer not freezing food,
The ice maker won't work if the freezer is warmer than 17 degrees so that's not an issue till you get the freezer cold again. I would guess that your unit is stuck in the defrost cycle. This could be the defrost timer failing. See if you can find the defrost timer in your unit and advance it by hand if possible. http://www.partselect.com/PartSearchResults.aspx?modelnum=jcd2295hes&mfgmodelnum=&fkmfgid=1&hint=defrost
Dec 01, 2006 | Jenn-Air JCD2295HES Side by Side...
Jenn-Air JCB2282H Side by Side Refrigerator Logo
97 people viewed this question
Top Jenn-Air Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Jenn-Air Refrigerator Expert? Answer questions, earn points and help others
