Question about Fisher and Paykel E522BRXFD Stainless Steel Bottom Freezer Refrigerator
High pitched buzzing & ringing sounds from f&p e522bxfd iridium
The above fridge barely purchased for 6 mths .
Compressor is giving a the above fault . Initially thought water tray problem , replaced water tray - fault still there .
took out produce from fridge & isolated fans - fans ok .isolated compressor with power running - compressor still producing high pitched noise .
adjusted legs of the fridge - problem still persists .
Help please : email to rr_1975@hotmail.com
hotuna
  • 288 Answers
SOURCE: very hot compresser upside down fidge
Is there a little fan back there with the compressor? if so is it turning? also check the outside coil, it may be covered with dust & crap. Sometimes that is all thet it takes. A good cleaning.
Posted on Feb 16, 2008
  • 158 Answers
SOURCE: cold fridge but not freezer
try DEFROSTING the fridge and restart it after COMPLETELY defrosting it.
Posted on May 31, 2008
reddyanantha
  • 205 Answers
SOURCE: I have a Fisher and Paykel E522B Fridge and the
hello sir/mam
after replacing the tempreture probe have u checked the compressor so that it should get the signals for cutt in and cutt off if not please check it.if this is not happening please change the temperature sensor.
Posted on Sep 14, 2009
Testimonial: "which temerature censor ( there are three )"
cj2176
  • 520 Answers
SOURCE: noisy high pitched noise from fridgefreezer fan
The insulation in these units is taped in place. This will slip and rub the fan. That is what usually causes this noise. The inner back panel comes out fairly easily by removing the screws and then the panel. Simply re-tape the insulation with a strong bonding tape and give it a try. Hope this helps. Good luck.
Posted on Dec 08, 2009
SOURCE: Fridge and freezer are alot warmer than normal
fridge not cooling pruperly
Posted on Feb 26, 2010
Funai tv. When plugged in, makes ear piercing high pitched buzz that goes away when unplugged. Will not respond to buttons. No picture or power. Already replaced power board. What now??
TV not turning on; making high-pitched sounds - Tom's ...
www.tomshardware.com > Forum > Graphics Cards
Tom's Hardware Guide
Nov 30, 2013 - 7 posts - ‎2 authors
Both of them are refusing to turn on, and make high-pitched sounds when plugged in and unplugged. More about : turning making high pitched ...Missing: ear ‎piercing
Top 136 Complaints and Reviews about Funai TV ' Page 2
www.consumeraffairs.com > Electronics > Televisions
Rating: 1.1 - ‎65 votes
We unplugged the unit and waited 15 - 20 seconds and plugged the unit back in, and it wouldn't ... He heard a loud high-pitched whining which led him to TV in my daughter's room. ... It only makes a humming sound now, no pictures at all.Missing: ear ‎piercing
HELP! what is that high pitched noise when tv is on? - TV - Audio ...
www.tomsguide.com/forum/60895-6-help-high-pitched-noise
Jan 25, 2013 - 3 posts - ‎2 authors
Hello, I hear this constant high pitched noise, almost like ringing, but even ... pitch
Jan 21, 2016 | Funai Televison & Video
What may cause a high pitch hum.even when muted or volume turned down?
Samsung DLP making a buzzing noise, but works fine - High Def ...
www.highdefforum.com > ... > Rear-Projection TVs
Dec 11, 2009 - 7 posts - ‎5 authors
My Samsung HLP-5063 DLP starting making a loud buzzing noise recently. ... I've only used it to watch TV for a half hour or so at a time, as I have a new LED LCD in my room. ... Other than that, I can't figure out what might be causing it. .... a humming high pitch sound, it will be an issue with the color wheel. RCA D52W25 making high pitch noise - High Def ...
Apr 15, 2009
humming sound in my dlp - High Def Forum - Your High ...
Nov 6, 2006
More results from www.highdefforum.com
High pitched sound coming from my Samsung DLP TV - Open Forum ...
www.dslreports.com > Forums > Social > Open Forum
DSLReports
Oct 3, 2009 - 30 posts - ‎7 authors
Its so high pitched that some people can barely hear it, but I guess I have sensitive hearing. ... Anyway, this seems to be a fairly common issue and it is caused by either the ... You're probably hearing a transformer humming.
Jan 08, 2016 | Televison & Video
6 y/o E381T fridge. Last 6 mths, started making knocking sound. Motor not running. Occurs when room temp cool - at night etc. If power off then on, it stops and motor starts. Else continues a minute.
from your description of the problem it is impossible to accurately diagnose the fault
Best advice is to get a technician out to check it out as it could be a failing compressor or compressor mounts
get a quote for any major repairs as a compressor replacement generally costs more than a new unit
Oct 26, 2015 | Refrigerators
Motor attempt to start an make buss sound ,do it need bareing
high pitched sound is the bearings, if its a buzzing sound and motor doesn't come on, run capacitor may be shot
Dec 21, 2014 | Heating & Cooling
Does not cool it is like it is stuck on defrost makes a high pitch buzzing sound What could be wrong
Top of Form
If there is no cooling at all , before we go further we must confirm the first step of confirming the compressor and gas pressure. So shut off the fridge and leave it off while you clean and check the evaporator for frost. If frost is seen it is a good indication as the compressor is working with sufficient gas within.
Now after about 6 hours plug in the fridge to start. Observe cooling to happen in about one hour and ice to from under three hours.
Earlier make sure that the thermostat was set to normal mode for freezer and fridge. If there is no ice formation we have a big issue as the compressor and gas must be checked out. If compressor is running check the pressure, get help to test gas pressure. If not you will need to fill up ,If gas pressure is good the possibility of the compressor being inefficient is high. In such a case you must take consensus to estimate and decide, if RPM of motor is low check capacitor.
However if Ice forms then observe the fridge for about 24 hours for cooling to continue and the fridge to cut off . If not the auto defrost timer, or the thermostat must be checked.
If defrost timer works but frost keeps forming check while the compressor shuts if the heaters are working, check continuity of the heaters.
So try this test from the outside and make your observations so that we come to the solution.
Please check this link for tips to work.
http://www.espares.co.uk/advice/fridges-and-freezers/a/2
Jul 27, 2011 | Maytag Refrigerators
SAMSUNG RS21 AMERICAN FRIDGE FREEZER SOUNDS LIKE A GENERATOR RATHER THAN A FRIDGE AND NOT SHOWING CORRECT TEMPERATURE ON READINGS. FOOD BARELY FROZEN AT TIMES BUT FRIDGE PART SEEMS OK. ANY IDEA'S?
Ring samsung up because this is a common fault in that make. I had the same problem, They should do something depending on when it was purchased ( 2005-2006 i think it was) it was on watchdog.
Nov 12, 2009 | Refrigerators
My Amana fridge (model ARSE67RBB) compressor has stopped working. It locks up when it gets too hot, and then makes a high pitched buzzing sound. I purchased the fridge used, so I don't think Amana is...
The buzzing noise is the compressor stalled and trying to start. Is the condensor fan working? (the fan at the back by the compressor) as if it's not it could cause this issue. If the rest of the unit is in good condition then yes I'd replace the compressor as these are normally good models and aren't cheap to buy new. This problem shouldn't happen again if you have a good new compressor installed by an expert. cheers
Oct 30, 2009 | Amana ARSE67RBB / ARSE67RBW / ARSE67RBC...
Buzzing/high pitch noise for 10 seconds with clicking on and off
hmm do you know where the noise is coming from, go to the back and touch the compressor and lets see if the noise is there so we can rule that out
Jun 23, 2009 | Amana ABD2533DEW / ABD2533DEB / ABD2533DEQ...
Buzzing sound, freezer nor fridge cooling
sounds like a compressor issue, perhaps the good news would be if its just under 5 yrs, youll have a 5 yr warr onthe compressor assy.( you should anyway) ck your manual for warr info
Nov 20, 2008 | Frigidaire FRT21H8 Top Freezer...
Fisher and Paykel E522BRXFD Stainless Steel Bottom Freezer Refrigerator Logo
167 people viewed this question
Top Fisher and Paykel Refrigerators Experts
Brian Coughlan
Charles T Nevin
Charles T Nevin
Are you a Fisher and Paykel Refrigerator Expert? Answer questions, earn points and help others
