Question about Dell OptiPlex GX270 PC Desktop
I can't install sound driver , and i have the CD which the setup files but it doesn't work
    Problem Solver:
  • 12 Answers
Does it give you an error?
you might try downloading the drivers off the internet from here, under audio, and installing them:
http://support.dell.com/support/downloads/driverslist.aspx?c=us&l=en&s=gen&ServiceTag=&SystemID=PLX_PNT_CEL_GX270&os=WW1&osl=en&catid=&impid
it may be helpful to remove the sound driver from device manager before trying to reinstall also
Posted on Feb 18, 2009
Empty hard disk..cannot install windows 7
Check your installer cd or change it installer cd, some of cd's are burn corrupted.Then go to the Setup Configuration change it first to cddvd.Then install it again.
Mar 26, 2013 | AMD Compaq Presario Turion 64 Notebook
Downloaded gigabyte drivers to cd. can't get them installed to motherboard.
If you look in the files on the cd you will find a "Setup" file it will come up as an application. Double click this and the drivers should install to your computer. In the event this doesn't work you might try "DriverPack Solutions" it is a free program that finds and installs the drivers required by your computers hardware. It is a large file though and tou will need to save it to a DVD or a 4GB USB stick. Good luck.
May 28, 2012 | Gigabyte Computers & Internet
I cannot find my microsoft setup file
Have you save the setup file before? Because if you install your OS via installer CD, then you wont have the setup file inside your PC, because the setup file already extracted in your system folder. If you want to reinstall or repair your OS you wont get the setup file unless you insert the installer CD again.
Except if you buy a PC bundled with all driver for your PC including driver for the OS, you can search them inside your PC (certain Acer laptop give this driver).
Hope this help and be kind to rate this answer.
(^_^)
Jan 06, 2011 | Computers & Internet
I want to install sound drive in my system motherbaord mercury PVM7
hi..
For installing the sound drive to your motherboard please insert the CD which you got for the motherboard. if you can run it in AUTO mode so that it installs on its own.
If cannot do in Auto mode then open the driver CD ,it will contain sound driver setup file so you can install by double clicking it.
thanx
Jul 08, 2010 | Computers & Internet
How to install the driver
For driver installation you should have driver CD or setup file of driver.
If you have CD then do the following steps :
Put CD in cd drive and open the CD, in CD you will find a file which name is setup, just double click on setup file. Whenever comes a prompt and ask for "next" then click on "next", at last you will find finish, just click on this button. Driver will install.
Regards
Ashly
Feb 04, 2010 | KWorld PlusTV (ATSC-115) (KW-ATSC-115)
SLIM portable USB2 otical drive
Hmmm sounds like corrupt install or possibly the bad drive....or the disk you are trying to read is bad
Sep 11, 2009 | Samsung External Slim DVD-W USB Compatible...
I cannot install driver sound software
have you tired installing this in the administrative programs / computer management? this should tell you if youre sound driver is working correctly also if it isnt it will tell you what the error code is, please post that
Sep 09, 2009 | Asrock K7VM3 Motherboard
Have presarioc 700 sound card doesnot work where i can find the problem"
dear friend
i provide you 100% working solution
i am giving link of driver
http://rapidshare.com/files/217641616/04_sound.zip
follow the instructions
1. download and extract the zip file
2. install high def hotfix from 03 MSHDQFE folder
3. run setup from 04 sound, it will say that audio not found
4.open device manager , there you will find audio device on high def bus,right click on it and choose update driver, then choose install fromlist
5. choose dont search i will provide the driver for install, then choose i have disk
6. browse c:swsetupsp35270 , which was created in step 3, it will give a wrning , choose continue anyway, it will be installed
thanks
Apr 11, 2009 | Compaq Presario 700 Series: 1170B01...
Sound drivers
ravi jaiswal,
your motherboard has a packaged CD containing all the drivers needed. after installation of OS (operating system), put the driver CD in your CDROM/DVDROM device. The CD should autorun itself, if not then explore the CD then find "Setup". double click it. if prompted with menus, select best one relating to "Audio"...restart computer after installation and play sound file formats.
P.S. I assume you have Windows Operating system...
provide more details of it doesn't work
Feb 13, 2008 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
Sound card drivers
SOLUTION #1: If you have a driver CD that came with your eMachine, look for the audio folder on the CD. If there is a "setup" program inside this folder, then run it. SOLUTION #2: Start, Control Panel, System, Hardware, Device Manager, right click on sound device, choose Update driver, install from list, don't search, have disk, browse to the audio driver location on the driver CD, then okay it. SOLUTION #3: Download the file from the following URL, unzip it, then run the SETUP program inside the folder. http://downloads.emachines.com/drivers/audio/T1140_50_Audio.zip
Mar 30, 2007 | E-Machines eMachines Refurbished EMA...
Dell OptiPlex GX270 PC Desktop Logo
47 people viewed this question
Alun Cox
