Question about Mitsubishi VS-55707 TV
Mitsubishi wd73733 wont respond to remote control
  • 252 Answers
Maybe your remote have a problem,try to open your remote control and change the crystal inside it,it is an orange color parts.
Posted on Feb 18, 2009
How to reset lamp timer on Mitsubishi tv model wd73733
  1. Turn on the projector
  2. Press the < > and Power buttons at the same time for about 3 seconds on the control panel.
May 05, 2017 | Mitsubishi Televison & Video
Mitsubishi tv sound no picture?
It is most likely that your light engine has gone out. When this happened to mine that was the part the service technician changed.
Aug 17, 2014 | Mitsubishi WD-73733 73" HDTV
Replacement remote for Mitsubushi aircon MSH-24TV, how do we get them talking?
If you wish to buy a genuine remote control, you have to contact the authorized service centre for Mitsubishi. If you wan to buy a universal remote control, you should first check, which brand remote control have setup codes to Mitsubishi brand TVs. If you wish to get this detail, try the links given here. It has setup code list, and setup procedure to many popular brand remote controls. Check and find out which brand remote control have the codes to Mitsubishi, and buy that one according to availability.
Dec 24, 2013 | Televison & Video
I have a problem code...its says check EO
Signal transmitting/receiving
(Indoor controller does not
respond to remote controller
During individual unit control
1) Bad contact of transmission
2) Signal transmitting/receiving circuit
is abnormal.
1) Check the transmission wire.
2) Check with another remote controller. If "EO" is
still indicated, replace the indoor controller
If other check code appears. replace the original
remote controller.
P3 Signal transmission error
(Remote controller does not
respond to indoor controller
is abnormal.
3) Wrong operation due to noise
wave emitted
Nov 10, 2010 | Mitsubishi Mr. Slim MXZ30TN Air...
Need code for mitsubishi tv
THE codes for programming RCA Universal Remote Control to a Mitsubishi TV are 006, 011, 014, 019, 022, 027, 041, 056, 061 and 068.
But then if it will not work on these codes you can try these steps for you to be able to program your remote control without the code.
  1. Manually turn ON your TV
  2. Press and "HOLD" CODE SEARCH
  3. Press and release the TV button you want to set up.The TV button will flash once.
  4. Release CODE SEARCH.
  5. Press OFF/ON repeatedly until the TV turns off (you may have to press up to 100 times at a rate of once per second).
  6. Once the TV turns off, press and release ENTER.
  7. With the TV on, press any other button. If the device responds, no further programming is required. If the device does not respond, repeat steps 1-6.
Jun 13, 2010 | RCA Universal Remote Control
Parental control is LOCK
mitsubishi 45605 . I bought a universal remote and it wont respond anymore. I tryied reprogram and it wont take the old code or any code. I bought a new remote and it wont respond
Apr 11, 2009 | Mitsubishi VS-45605 50" Rear Projection...
Tv wont respond because device menu is changing through each device
I had a similar problem: my WS-55511 would not respond to the remote and the front control buttons (with the exception of Power) cycled through the Device Menu. I solved this problem by disconnecting the front panel. Here's how to do it: 0. Unplug the TV
1. Remove the speaker grill from the front by pulling forward: there are no screws. 2. Disconnect the two cables that are exposed after the grill is removed. 3. Plug the TV back in, wait for 5 minutes to reset. 4. Try using the remote.  Hope this helps!
Oct 06, 2008 | Mitsubishi WS-55511 55" Rear Projection...
Direction of vane changes
Push the reset button of your remote control and try. If it wont work try to "off" and "on" the circuit breaker to reset the unit and try the remote control.
Dec 31, 2007 | Mitsubishi MS12TN Air Conditioner
Mitsubishi VS-55707 TV Logo
77 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
