Question about Hitachi 50UX57B 50" Rear Projection Television
50v720 no picture blinking light temp and lamp
  • Singam56 Mar 18, 2009
    My Hitachi rear projection 50V720 is under 2 years old will not turn on. Indicator light green come on, then in a minute starts to blink and next 2 lights (one is temperature, other not sure) both red starts blinking. Waited 2 minutes, nothing happened and I turned it off. Read the manual and they talked about bulb and bulb door.
  • Anonymous May 20, 2009
    screen blach temp and lamp flashing red
You may need to replace the lamp there is a small door in the back take screws out make sure you disconnet TV first, Also make sure you shop around online get TV model and type of lamp from your manual and GOOGLE it you will surprise by the prices from $70 up to $300, you can do it yourself. Hope this helps
Posted on Apr 01, 2009
Color issue
download this manual
http://merchant.satisfusion.com/sf/library/manuals/owners/50V720.pdf
see page 59,60,61,62. The problem can be the lamp
After extended use, if the TV picture turns dark, the color looks unusual or LAMP INDICATOR light turns on, then it
is time to replace the lamp with a new lamp.
Mar 21, 2008 | Hitachi 50V720 Television
I put a new lamp in my hitachi 50v720 tv. The light keeps blinking and the power will not come on
If it was blinking like it was, it's probably either a bad lamp or a faulty install. Try re-installing the housing of the lamp in the T.V. if you're sure you didn't over tighten or under tighten the screws on the lamp. These are all simple things to check before you send back the potentially bad lamp.
Jun 17, 2011 | Hitachi 50V720 Television
Hitachi model number 50V720 does not show picture or sound when turned on. The Temp light and the lamp light flash red on and off. What's the problem?
Check the tv fan it is running?No than the fan require replacing.Yes,than the tv projection lamp life are ending require replacing.
Apr 14, 2011 | Hitachi 50V500 50 in. HD-Ready LCD...
TV went off, and three lights come on (green "power", red "temp", and red "lamp")for just a second, in succession from left to right.
My television had two red lights flashing, one for Temp and the other for the lamp. I removed mythe lamp assembly and the bulb filament was burnt out. I order a new lamp and housing unit UX21517 and replaced it and now I have the red light flashing which is calling out the lamp again.
Oct 10, 2009 | Hitachi 50V720 Television
We have a Hitachi model # 50V720 TV. When you turn it on, green power light flashes, then temp and lamp lights begin to flash, eventually goes to just the lamp. Can you guide us as to what the problem may...
Y sus (sustain) board or main power board has dry capacitors or dead transistors or even main chip is dead, but to know more accurately you need to count the red light flashes. Google "red blinking codes" should find the answer, ebay sells Y sus boards or power boards around $125 (cheapest) for plasma TVs.
Jul 21, 2009 | Televison & Video
Black Screen
You may have a fan that is not spinning fast enought and a overheat condition is occuring or you may have a bad lamp.
Apr 06, 2009 | Hitachi 50V720 Television
Changed the lamp power won't come on
I think you might be having a different issue, which seems to be the power supply board.
Feb 21, 2009 | Hitachi 50V720 Television
Hitachi 50UX57B 50" Rear Projection Television Logo
212 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
