Question about Dell Inspiron B130 Notebook
Dell inspiron b130 power problem
My laptop is approximately three years old...the battery has not held a charge for more than 10 minutes for the past two years, so instead of replacing the battery, i have just kept it plugged in. over the last three days, when my computer has been on for about an hour (and plugged in), the battery indicator light rapidly flashes orange (which i have read means defective battery) and the computer shuts off. If I happen to catch that the light is flashing, if I unplug the AC adaptor from the back of the computer and quickly plug it back in, then it is good for another hour or so.
Is the battery necessary for the computer to run? Do I need to replace my battery? Or is it a power cord issue? I am confused because it does run for about an hour, but is connected to AC power and the battery has not run for more than 10 minutes in over two years. Any help is greatly appreciated. Thanks!
Your power adaptor sounds like it needs replaced.
A battery is not necessary to run your computer but it will help to prevent loss of work in progress.
The amber flashing light simply means the battery is fully charged.
This usually happens with a replacement battery not manufactured by Dell.
Not a big deal.
If you open your power meter (right click on the icon) and notice the charge continues to diminish even while plugged in and indicating "charging"
You should unplug and use your laptop until the battery is depleted.
You can set adjust the power properties (right click on the same icon) to hibernate when the critical battery reaches 5% so that you don't lose any work in progress.
If the battery will not begin to recharge after running it down and plugging back in, leave your laptop plugged in, remove the battery and lock it back in place.
The computer will reset and the battery begins to recharge again.
This appears to be a feature that occurs in replacement batteries to ensure the battery is kept at an optimal charging capacity.
If your battery lasts only a few minutes after indicating it is fully charged you most likely bought an inferior replacement or in your case indicating it's (years old), it probably is time to replace it.
Posted on Sep 07, 2010
  • 547 Answers
Try running with battery out it should still work as long as it is pluged to a/c
Posted on Feb 18, 2009
My Dell Inspiron B130 won't turn on. The battery light blinks yellow twice then green, but that is the only thing happening.
Take the battery off completely and drain the flea power from the laptop by holding down the power button while the battery is off. Hold down the power button for about 15-20 seconds to ensure no power remains on the laptop. Check if your battery has a drain button too. Drain the battery and place it back on the laptop.
Charge it for about 30 minutes before you turn it on. See if it works.
Post here if you need further help.
Jul 30, 2011 | Dell Inspiron™ B130 PC Notebook
The Power status of my laptop says O% power remaining in my batteries. What really is the problem with my batteries?
If the laptop battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, until they won't charge up at all. If the battery drops to an unacceptable charge level then the battery needs to be replaced.
Feb 03, 2010 | Dell Inspiron B130 Notebook
My Dell Inspiron B130 will not turn on
The battery is critically low, indicating that it is not getting a charge from the AC adapter. If the system will not power on from the AC adapter, then the motherboard power connection is suspect.
Motherboards are about $100 on EBay
Feb 01, 2010 | Dell Inspiron B130 Notebook
Inspiron B130 shuts down after about 5 seconds
Sounds like a bad AC adapter not charging the system. If a known good adapter has the same issue (Or this adapter works on another system) then it is a motherboard replacement
Sep 14, 2009 | Dell Inspiron B130 Notebook
Dell inspiron 1501 battery won't recharge fully.
Laptop batteries last 1 to 3 years (check your warranty = most laptop batteries are only 1 year ..) .. anyone who gets 3 years out of one is doing well ...
Mar 15, 2009 | Dell Computers & Internet
Lights flashing on my dell inspiron b130
Remove all power sources and try restarting it with just the A/C adapter connected. Does it power up then?
Dec 27, 2008 | Dell Inspiron B130 Notebook
DELL XPS M140
One of three things, 1- power supply, check your power supply with an ohm meter to see f it's getting the proper output to the machine. If the supply is starving the machine of power the charging system won't work to it's full potential. 2- the power management system on the motherboard, if this system isn't working properly it can divert power from the charging system. If it's just glitched then a bios download or chipset utility download will fix it, if it's malfunctioning, then motherboard replacement is the only option. 3- the battery itself, I have a Dell, and in the past two years, I've ordered two new batteries. The first held a great charge, more than three hours, but only lasted about eight months. The second only holds little more than an hour charge, but has lasted well. Batteries are just funny that way. Start with the power supply test.
Aug 23, 2008 | Dell Inspiron XPS M140 Notebook
Dell inspiron b130 won't boot up.
Connect an external monitor to the laptop and see if you can see what is happening on that.
It is a possibility that your inverter is faulty and will need to be replaced. They will normally power on for a few seconds, then cut out.
Remember to set the laptop to use the external monitor with the function keys.
Apr 09, 2008 | Dell Inspiron B130 Notebook
My laptop battery won't charge
possible when the old AC adapter blew it took part of the power management circuit with it, This is the circuit that detects and charges the battery, I'm not sure whether this a seperate replaceable daughter card or whether it is part of the main motherboard. you will need to investigate this (or send it for a service)
Oct 09, 2007 | Dell Inspiron B130 Notebook
Dell Inspiron B130 Notebook Logo
514 people viewed this question
Alun Cox
