Question about IBM NetVista PC Desktop
Plz help me. I have a 15" LG made CRT monitor, which was working fine since 2003. But recently some flickers start appearing and now only a multicoloured horizontal line appears on the mid of the screen with black background. well i'm using a friends monitor which is working, so the problem is with my monitor. Can any one help me, what to do with my monitor. Thanks. well if possible provide ur email id so that i can contact u for further problems. thanks a lot.
  • verma_is_her Feb 18, 2009
    soory to say, but i neither hit nor pour water on my monitor. as mentioned it was flickering from few days and now only a horizontal streak is appearing.
    can u tell what would be the cost of reparing ?
  • 544 Answers
did your monitor accidentally hit or pouring water that may caused this problem.
i am sure your problem is not in plug..
we can say if the monitor damage it is sensitive because the only way to fix this is to go and find technician to open it...
if you pour some water accidentally or over heat occur sure some parts of the monitor are busted sometimes it can fix but often i prefer to advice you to buy a new one....
please rate...
thanks,,
Posted on Feb 18, 2009
A few months ago my LG Flatron L1900R monitor started flickering when I boot up my computer. It has become worse, to the point where it now flickers constantly.
From the information desribed, this means that your CRT monitor is going dead. Unfortuntly, there is no way to stop the flickering unless the monitor was replaced. I hope this has helped
Jul 05, 2011 | LG 700M 17" CRT Monitor
Hello sir, i hav LG CRT 15" monitor. After turning on, its LED continuous blinks and power button does not work and displays nothing. so plz suggest me what should be deffect?
Any 15-inch CRT-style monitor should be replaced by a 15-inch or 17-inch LCD-style monitor. You can find "previously-owned" monitors for $30 to $50, which is less than taking your CRT monitor to a TV/video repair-shop for an *attempt* to get it repaired.
Oct 04, 2010 | Computers & Internet
Crackling and flickering of monitor continuosly
somehow i dont think theres anything you can do for it, judging by what you said, the overload was way too much for the screen
so, solution, get another screen, and get a decent surge protector, might not do much but it may prevent this from happeneing again
hope this helps
May 16, 2009 | E-Machines eMachines Monitor E15T4
Screen flickers
ram problem once clean the ram and insert it again if the problem occurs again the change ur ram it will rectifye ur problem
Jan 22, 2009 | HP Pavilion MX70 17" CRT Monitor
Screen displaying a thin white very bright horizontal line.... plz help
problem in vertical section.
1. Solder the vertical ic
2. vertical ic supply capacitor problen.
3. dry points in neck board.
Aug 08, 2008 | LG Studioworks 45 14" CRT Monitor
Remove dry solder at Vertical IC if problem not solves replace VERTICAL IC and pf104
Darshan
Jul 05, 2008 | LG Studioworks 552V 15" CRT Monitor
Screen flickers
may be cos of coldsolder at the main board.
just try try up to resolder suspected point.
May 11, 2008 | LG Studioworks E700B 17" CRT Monitor
Monitor flickers!!
I have also same problem with LG Monitor 700E, LB(in). I want circuit diagram/systematics of this monitor in PDF or any other format. Thanks in advance.
Dec 01, 2007 | LG Studioworks 700S 17" CRT Monitor
Lg 563n monitor problem
Plz check your monitor's vga cable for ok .I think there is problem in 1,2,3 no pins wires continuity.If it is ok then check components thats are connecting these pin to video amp. ic on crt neck.If they are ok then change video amp. ic with new one.Hope this solution works otherwise i am always ready for help
Sep 10, 2007 | LG Studioworks 563N 15" CRT Monitor
IBM NetVista PC Desktop Logo
188 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
