Question about Ovens
Cooktop elements overheating
Hi there i have a problem with the cooktop elements of my electric oven. They seem to be overheating, you set the dial to a low or medium temperture and the element glows red hot, this seems to be intermittent and affects all four elements
Oven is a Westinghouse Avondale . PAJ161B*10
jumptrout51
  • 3361 Answers
SOURCE: constantly burning food, heating element in lower oven glowin red
You have a bad thermostat if the element never cycles off.
Posted on Feb 22, 2009
  • 1122 Answers
SOURCE: only oven element will not heat
look on the oven element and see if you see any blow out holes,let me know-mike
Posted on Oct 07, 2008
SOURCE: Westinghouse Freestyle 476 Cooktop Oven
After getting an electrician out, apparently the time needs to be set on the oven. As we're in a rental & don't have a manual/ couldn't download one, we got it to work after holding the first two buttons in (the timer buton + the one that looks like a hot pot) along with the + button at the far right, which made the tim tick on, so it could be set.
The oven works now! : )
Posted on Jan 12, 2010
  • 143 Answers
SOURCE: Kenmore electric range with ceramic
It sounds like your Frigidaire made kenmore may have a power supply issue, the power block that is located at the rear of the oven may be at fault. part number 5303935061. However the digital clock can also cause this problem, and should be diagnosed by a technician.
Posted on Mar 15, 2010
  • 11800 Answers
SOURCE: Hi; I own a GE
There are no fuses inside your unit, only a few relays and 2 thermostats that are very easy to test with an ohmmeter. In your case the element has died of old age (the resistance inside it failed), the other one isn't far behind.
I seriously doubt you can obtain even a second hand element, finding a new one is practically impossible since production of this line of models ended in 2001.
I think it's time to get a new one.
Posted on Oct 22, 2010
Oven temperature will not cycle
How To Fix Oven With Little or No Heat When Baking ...
www.partselect.com/Repair/Range-Stove-Oven/No-Heat-When-Baking/
Repairing a range, oven, or stove can seem like a big task, but our ... Most electric ovens use both the bake element and the broil element in a bake cycle, with the bake... If the bake element isn't working, the oven may not reach the set temperature or ...If the element appears to look normal, then turn the oven on to a bake ...
Electric Stove Repair ' Electric Oven Repair Manual ...
www.appliancerepair.net/oven-repair-4.html
Inside the oven, the heating element is called a "bake" or "broil" element. ... To maintain a set temperature in an electric cooktop, the element is cycled on ... Do not put any cleaning agents or solvents directly on heater elements or surface units. ... A switch will show no continuity when off and good continuity when turned on.
Electric Oven Will Not Heat ' RemoveandReplace.com
removeandreplace.com/2015/.../oven-not-heating-how-to-fix-range-repa...
Aug 24, 2015 - The issue is most likely a bad internal fuse, oven temp sensor, ... oven replacement parts ... Bake and Broil Element Test - Electric Oven Repair ... Dryer Spins But No Heat - How To Troubleshoot Dryer is turning the drum but ... If your dishwasher is completing the wash cycle but will not dry your dishes, we ...
Oven Temperature Not Accurate - Repair Parts ...
Jan 28, 2016 | Frigidaire Ovens
Hi, my Blanco freestanding electric oven-FD9045WX-(gas cooktop) went out with a flash & a bang. The fan element was in pieces and the thermostat totally fried. The clock/timer does not go nor do the sparks...
Check for power at the supply terminals, follow it up to the high temp cutout > timer > multifunction switch > thermostat > element
Careful, don't electrocute yourself!
Oct 13, 2013 | Ovens
Electric range surface elements not working after self clean cycle.
It sounds like it is broken. You can bypass it by connecting the 2 wires together. This should be fine until you replace it. They aren't that expensive.
Mar 06, 2013 | GE Ovens
My oven will not get hot at the bottom
If the broil and top portion of the cooktop work, then you are in need of a new baking element. If other settings don't work, your control board needs to be tested.
Aug 06, 2012 | Frigidaire 30" Self-Cleaning Freestanding...
I have a Frigidaire electric oven and flat cooktop that went out. Neither the oven nor the cook top elements heat up. If I turn the element dial slightly, the digital clock lights up (flashes), but...
With the symptoms that you are describing here ...the problem is in the control board... you still have power, but nothing is being told to turn on...the control board controls all of those functions...
Here is a tip that will help you with the online buying...
How to Buy
Appliance Parts Online
heatman101
Dec 26, 2010 | Frigidaire Ovens
Cooktop on light will not shut off
Here is a tip that I wrote about the problem of the cooktop light staying on.
Oven Hot Surface Indicator Light stays on
heatman101
Sep 29, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
Cooktop works but the oven does not, is there a fuse in the oven because there is only a circute breaker for the cooktop?
If your electric oven is taking too long to heat or just not heating up right,then check out this tip that will give more detail about your problem.
Oven Problems Electric Oven is Heating Slowly or Poorly
heatman101
Sep 19, 2010 | Ovens
Nothing happens with the ignition, no spark at all. I now have to light hob with a match
Here is a tip that I wrote to give details about why your cooktop will notspark to light the burners..
Cooktop Range Stove spark ignition does not work
heatman101
Sep 16, 2010 | Smeg S300X Electric Single Oven
Ge range model # js968 has power but cooktop & oven don't work
Check for proper power (control panel is 120V, burners and heat element are 240V) You may have lost connection in one of hot wires causing the burners/elements not to work yet the control panel still will
clarkco
Feb 25, 2009 | Ovens
Ovens Logo
449 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
