Question about Toshiba SD-2800 DVD Player
I have a 1987 zenith model sd2713h television and a toshiba dvd player and can not get the two of them to work together or find a viewing channel. How can I get them to work?
2 Suggested Answers
SOURCE: Toshiba Tv remote control
I NEED THE CODEOR CODES THAT TOSHIBA DVD-HD A30KU TU USE AND RECCEIVER ONKOY
Posted on Sep 24, 2008
the q guy
  • 393 Answers
SOURCE: How can I program a remote model number NB079 to a Zenith dvd pl
I found that this website should have all the codes and instructions for most remotes
http://www.xdiv.com/remotes/
or http://www.remote-codes.com/
if this helps please give a fixya rating as thats how we get paid.
Posted on Apr 28, 2009
Dvd player toshiba sd-350esb schematics would be great
Toshiba SD-350ESB Manuals
www.manualslib.com > Brands > Toshiba Manuals > DVD Player
... User Manuals. View online or download Toshiba SD-350ESB Owner's Manual. ... Manuals and User Guides for Toshiba SD-350ESB. ... DVD VIDEO PLAYER.
Toshiba SD350ESB DVD player - Instructions Manuals
www.instructionsmanuals.com/modelo-8363-en-DVD+player.htm
Download instructions for TOSHIBA SD350ESB. Toshiba SD350ESB DVD PLAYER. Click on the instructions manual you would like to download for the model ...
Nov 07, 2015 | Toshiba Televison & Video
I replaced my TV and now my VCR Zenith Model 2100 will not record
Digital TV can use component video and stereo connections to record on analog VCR. Analog VCR needs DTV converter to record digital TV channels. VCR play back use AV channel on TV.
Feb 11, 2012 | Zenith Televison & Video
Our new Toshiba SDV398KC2 will not play a DVD. It is like it is on the wrong channel. It shows the DVD playing with the counter but does not show it on the TV. Can you help?
I've seen this behavior before.
For this model, I *think* that you need to use the component connections/input in order to view the DVDs. If VCR shows ok when using the cable, but not the DVD (and it seems to work since it goes up as if playing), try to connect the component (blue/green/red connectors) and it should work.
Don't forget to switch input on your TV to component.
P.S. If you have HDMI on both this dvd/vcr & your TV, it should work with that too.
Nov 18, 2010 | Toshiba SD-3980 DVD Player
I need codes to program tv to my zenith combo player
Please try code : 01, 24, 25, 29, or 37.
Regards
Jul 18, 2010 | Zenith XBV442 DVD Player/VCR
How do you get DVD picture to show up? Power is
You DO NOT use "Channels" to View a DVD player it usually connected to the AV External input. via AV, Yellow, (Video) Red & White, (Audio) or Component Video, Blue, Red & Green. (Video) + Red & White (Audio). These are selected via the External Inputs.
Feb 18, 2010 | Zenith ZDA311 DVD Player
I have a zenith dvd vcr combo. The tv I'm using
If no little switch on back, it must be a selection in the setup menu. wutxtye0rjd9d9ekmodqt1eoxkvn9hr9qjz1l3dabggyud7sdgr36czsrfxqenadhnijx9nfayi+sz1sug0aaaaasuvork5cyii=
Jun 26, 2009 | Zenith XBV243 DVD Player/VCR
How to change vcr input from channel 4 to channel 3
On the Zenith, turn the power off. Hold down the Channel up or down button on the machine itself (not the remote) for 5 seconds, it will say RF03 hold down until it says RF04.
Apr 27, 2009 | Zenith XBV243 DVD Player/VCR
Need the remote code for a phillips dvd player
These are the codes printed in the owners manual for your dvd/vcr player.If they do not work you will have to contact Emerson and ask them for help getting the code. The contact number should have come with the instructions for the remote. Just give them the model number of you remote and the units model number and they should be able to help you. I hope this information helps you with your problem. Switch the input selector on your TV to an appropriate external input channel (usually near channel 0).
Press a button on the TV’s original remote control that selects an external input channel until the DVD
recorder’s picture appears. Check your TV owner’s manual for details.
Admiral
Curtis Mathis
GE
Hitachi
JVC
Kenwood
LXI-Series
Magnavox
AUX
LINE1, LINE2, 00, 90, 91, 92, 93
INPUT, TV/VCR, 00, 90, 91, 92, 93
INPUT, AUX
VIDEO, VIDEO 1, VIDEO 2, VIDEO 3
AUX
00
AUX CHANNEL
Input Mode Names for Common TV Brands (Example)
Panasonic
RCA
Samsung
Sanyo
Sharp
Sony
Toshiba
Zenith
TV/VIDEO
TV/VIDEO
VIDEO
00
VIDEO1, VIDEO2, VIDEO3
TV/GAME
00
Apr 25, 2009 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Zenith XBR411 DVD Recorder/VCR Combo Problem
I have the XBR616 zenith combo.
If your dead set on initializing your dvds, I can try to
do one in my dvd player to see if it works, then send it back to you. I can't guarantee anything, my player is a bit fussy, but I don't mind helping you.
If so, let me know
Oct 28, 2008 | Zenith XBR411 DVD Recorder/VCR
Toshiba SD-2800 DVD Player Logo
35 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
