Question about Jwin JD-VD136
Loading but not playing
Trying to play a disc, player shows" loading..." but then it shows "wrong disc". Tried many DVD's that are in good condition. My TV has only red and white outlets so i plugged red and white plugs to my TV. i can hear sound when i keep any disc. this is new dvd player and first time opened it.
  • skank Nov 13, 2007
    ive tried many dvds and after loading, it says wrong disk. this is the first tme ive tried to use it.
  • Anonymous Nov 30, 2007
    1. IT LOADS BUT THEN SAID WRONG DISC!
    2. IT GETS ALL FUZZY!
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 96 Answers
Try a firmware update
Posted on Feb 08, 2018
SOURCE:
SOURCE: dvd player not playing discs
did you check to see if you had the audio video cables on the dvd player plugged in the right place also you might want to get a s-video cable it is much easier that way not toooo much problem to hook it up you plug it in to your tv and the other part of the cable plugs into your dvd player where it says s-video
Posted on Aug 09, 2007
Palmbeach
  • 185 Answers
SOURCE: Wrong Disc
Are you referring to a prerecorded commercially produced DVD?
Discs are Region Coded This means that you will not be able to watch DVDs intended for use in a different country, unless you have a multi region player. .
There are two video standard formats, NTSC which is mostly North America, and PAL which is the rest of the world. Some players will play both, others won't. Some DVD players allow you to select the format.
Posted on Feb 23, 2008
  • 38 Answers
SOURCE: No Power
Hi Rusty,
Open the cover , there must be a blown fuse, replace with another fuse of same value. If still not working take to service centre. This is a case of SMPS power supply failure.
Please vote for me if this is helpful.
Posted on Jun 08, 2008
SOURCE: dvd disc is not recognised after loading
I have the same problem after a power failure the picture stopped and never played again
Posted on Nov 07, 2008
  • 1348 Answers
SOURCE: VHS plays in colour and DVD plays in black and white.
there is a circuit in the color section to put the tv to black and white if the color subcarrier is missing from the broadcast signal.
it is called a color killer and needs to be adjusted.
it is for a technician to do.
it operates off the 3.58mhz color subcarrier.
Posted on Aug 18, 2009
DVD player automatically stops and turns itself off, how do I prevent this?
Warning: Laser inside! If you want to open it up and troubleshoot, make sure you don't point toward your eyes.
Check the nylon laser carriage to see if it slides laser from center to outside line. If it sticks, it's probably shutting down from not properly reading a disk.
Aug 03, 2014 | Pioneer DV-343 DVD Player
I have a JVC TV/DVD combo and the DVD stopped working
This is a common problem with DVDs. You must not leave them idle for such long periods. Second, you must always leave a disc inside the player. It protects the optical lance from dust. There may be some dust deposit on the lance or the loading rubber belt may have gone lose or the spindle motor which rotates the disc might have gone slow. But to solve this problem you will need a qualified technician. Good luck.
Jan 08, 2014 | JVC LT-32D210 32 in. LCD TV/DVD Combo
DVD player loads then stops and says no disc, havent used it in about 4 years ,how do i get it to play dvd, tried to set up like it says but must be doing something wrong
Tries to play more than one DVD disc.Tries to play many DVD disc should be original DVD disc ok no DVD+R copying disc ok.If ur are still getting signal just saying loading signal awhile than say no disc show up, and u did playing it with many dvd original disc.Than the DVD player laser eye reader could be ditry.Tries websites like Amazon.com,Ebay.com to buy a DVD disc set that said like DVD players lasers eyes cleaners.Used it as directions said,if u still getting the same result mean ur DVD player laser eye reader it is dead,not worth repairing the DVD player if the DVD player laser eye reader it it dead,because the laser eye reader it is 90% important to the DVD player unit and the cost of it by replacing it will cost the same as a new DVD player unit.
Aug 29, 2011 | Polaroid 7'' Portable DVD Player
Says loading disk and then says wrong disk everytime. tried several different dvds. always the same answer!
The DVD portable player and the DVD disc came from the same countries?Ur DVD portable player and DVD disc u are using might have the wrong region DVD disc format frequencies.Like PAL frequencies only play Euroupean,Asia,Middle East,Austriala and Africa products.NTSC frequencise play only USA,Canada and Mexico DVD Disc products.
Dec 13, 2010 | Coby 7" Widescreen TFT Portable DVD Player...
Can this be fixed?
i have an audiovox dvd player model D1718 . i put the disc in and it says it is loading but then comes up no disc . how can i fix this problem?
Sep 11, 2009 | Audiovox D1708 Portable DVD Player
My Memorex won't play DVDs, it only shows "wrong disc."
No help i know, but my Liton is in the same condition. Except mine keeps saying Insert disc...
Have you tried using a cleaning disc in case the laser is dirty?
It didn't cure mine, but you never know...
Aug 15, 2009 | Memorex MVD2040 DVD Player
Jwin JD-VD136 Logo
67 people viewed this question
Top Jwin Televison & Video Experts
Ekse
Jaime Hernandez
Sheldon Dedek
Are you a Jwin Televison and Video Expert? Answer questions, earn points and help others
