Question about Dell XPS 200 PC Desktop
I have a dell xps 200 and it randomly shut off and power light flashes amber
  • 3 more comments
  • spawn9138 Feb 19, 2009
    i had tried that prior to posting this problem.. i took it apart and cleaned the power sorce out and bolth fans it was pretty dirty but it still shuts off... usually it runs for like 15 to 20 minutes before it cuts out... and i have tried to find a new power supply for it but there all either not the same model or way to expensive ... do u have any other ideas?... please let me know... and thanks
  • mzlogicc Feb 26, 2009
    Recently my Dell XPS 200 has been shutting down without warning. Once it shuts down, the power button starts flashing amber. I then turn off the surge protector. After a few minutes, it will boot back up. It is very annoying. Please help. Thanks. I appreciate you.
  • Anonymous Mar 09, 2009
    open up the case and put a fan next to it on high..its the fan over heating..that why i say **** dell computers
  • Anonymous Apr 22, 2009
    I have the same issue. system shuts down and power light turns to amber. I have thousands invested in this system and it is 2 years old. I upgrade to 4GB. i ALSO DID A COMPLETE RESTORE OF MY HARD DRIVE BECAUSE DELL TURNED A SIMPLE ISSUE INTO A HUGE PROBLEM AND i HAD 4 TECHS THAT COULD NOT FIX IT. sO NOW THE TECH TELLS ME i HAVE A BRAND NEW SYSTEM. nOW i GET THIS PROBLEM AND DELL WITHOUT DIAGNOSING THE PROBLEM TELLS ME i NEED ALL THESE HARDWARE PARTS BECAUSE IT IS OUT OF WARRANTY. wELL, i FIXED IT NYSELF AND I WANT TO RING THAT FRIGGIN RAG HEAds neck.DELL'S SUPPORT WENT TO ****......THEY **** ***..... i WENT THROUGH 4 TOWEL HEADS BEFORE i GOT SOMEONE WHO SPOKE HALF DECENT..IDIOTS.
  • Anonymous Apr 27, 2009
    I think the dell xps 200 is 120 watt power supply. I think it is overheating and I have mine in a small area with no cooling. Can xps 200 get a bigger power supply than 120 watt?
  • 4 Answers
I have the exact same problem with same system. What happened was, I upgraded from 1g to 4g of memory. I also had my system in a closed secretary desk that did not get much air. When I took out 2g of memory and cleaned the fans out. It was all fixed.
Posted on Apr 29, 2009
  • Juanmata Feb 11, 2013
    how do i clean the fans with out damaging eanything?
I am having the same problem. It is the I/O front panel switch. Test it by removing the switch and disconnecting the cables from it. With the power plugged in to the unit, connect the larger cable but just enough for the system to power on. It should stay on.
Posted on Apr 04, 2009
  • Dell Master
  • 3,051 Answers
Hi there:
one thing that you can do is to power it down and unplug the powercord , blow out the powersupply and than open up the case . I f the computer has a onboard fan blow it out too and while you are in the inside make sure that all of the connections are good and snug ok than put everything back and reboot and see what happnes please let me know how this works for you ok
best regards mike
Posted on Feb 18, 2009
Dell xps gen 4 diagnostic lights A C D green B amber also front power light is flashing green and amber
go to dell website and see what those lights are meaning, I can't help with no exact brand and model (Dell - model ....)
Feb 19, 2014 | Dell Dimension XPS Gen 4 PC Desktop
My dell xps 200 shuts down and the power light flashes amber. I try turning it back on and it does not respond. I have to unplug it from the outlet wait a few seconds then plug it back in. After I do this...
You can try unplugging the PC, removing the RAM and re-seating it. It could also be a power supply issue, either too much for it to handle or it's not functioning correctly. My first suggestion would be unplugging hardware that's not needed for a week or so and see if it keeps happening with only the HDD plugged in. If it doesn't continue plug one thing in at a time until you find the culprit... although because it does run for a bit when you have the so called culprit, unplug it and plug something in its place, if it continues then you may have over powered your power supply and need to get something a bit larger.
You may also have issues with the PC over heating or fans not running correctly, make sure to check these items while your PC is turned on. (please be careful).
Mar 07, 2011 | Dell XPS 200 PC Desktop
Dell XPS 200 Computer shuts off leaving blinking amber light
3 most common solutions to your problem are:
  1. Bad power supply; once it heats up will quit without warning
  2. Bad heatsink/fan; processor heats up and will lock up your Pc
  3. Bad motherboard
Try opening the machine and give the inside a thorough cleaning, paying special attention to the heatsink and fan. Once clean and you've ensured the fan is operating, put it back together and see if your problem is fixed. If not, a new power supply will likely fix your problem. Best of luck.
Greg
Jul 06, 2009 | Computers & Internet
DELL XPS 700 AMBER LIGHT
you don't tell us from where coming the amber light from the cpu or from the monitor?
May 29, 2009 | Dell XPS 700 PC Desktop
Dell XPS400 No Start!!
If you fan isn't turning like it should, it is definitely a power supply issue. Go out and purchase a power supply with 250-300 watts...thats a good standard wattage!!
May 12, 2009 | Dell XPS 200 PC Desktop
4600C no power, flashing amber light
i have a dimension 4600c. same problem. amber flashing light no sounds. replaced my power source and its now working fine. bought one on ebay for $47
Apr 11, 2009 | Dell XPS 700 PC Desktop
No power to my computer.
hi
stuart
just read this carefully.................
Unplug the power cord and the display cable from the monitor. Now press the power button for 60 sec exact. Plug the cables and your system is working................ This is just a power drain.
Enjoy
Jan 13, 2009 | Dell DimensionTM XPS 710 PC Desktop
Dell XPS 200 PC Desktop Logo
1,349 people viewed this question
Alun Cox
