Question about Canon NP 6050 Copier
Porblem E210 i have engine photo copy brand canon np 6050 problem he e210 how repair he
Check motor lensa (gear is crack),check sensor
Posted on Feb 23, 2009
Bagaimana cara memperbaiki mesin photo kopi canon 6050. muncul tulisan e210
saya punya NP 6050, tidak ada hasil copyan sama sekali, apa yang perlu di cek
Mar 30, 2012 | Canon NP 6050 Copier
E 210
there is an lance home position sensor problem... open the platen glass, then open the lance cover (black Metal).. then turn on the machine and check the lance is moving forward and back to center.... if not clean the lance home position sensor or replace that.....
Nov 28, 2011 | Canon NP 6050 Copier
Cannon 6241 error E210
A E210 has to do with the scanning lamp. It could be that the scanning lamp is blown or the thermal fuse is blown or most likely is that the black power cable is cracked and the power going to the lamp is shorting out to the fram of the copier. The rubber coating cracks from the use of the scanner going back and forth. It is not a easy repair. Good Luck
Sep 05, 2011 | Canon NP 6230 Copier
E210
untuk mngatasi error 210 ini biasanya gir lensa patah,solusi terbaik yaiitu ganti lngsung gir yg patah dengan yang baru. PERHATIAN ; dlam memasang gir lensa harus bener2 presisi atau pas dalam artian tidak ada yg longgar. setelah gir terpasang dngn benar lngsng nyalakan mesin dan lakukan error kode *4*error*...jika masih error 210 brarti ada kelainan di mtor lensa tersebut. thanks ARIF FAJARRIANTO_PANGKALAN BUN.
Nov 05, 2010 | Canon NP 6050 Copier
Error code E210 any ideas
Error E210 means - there is a problem with the lens position.
Under the glass there is a lens that moves to enlarge and reduce the copies. At switch on this has to find a home position. the error code means it has failed to do so. If you look at it is is driven by a belt. The drive pull for this can be seen through the glass. This becomes miss placed and is not driven correctly. Have a look and you will see has has come out of place. You may be able to take it apart and clean it up if not you will need a new drive assembly.
Jul 08, 2009 | Canon NP 6050 Copier
E210 error turn off then on?
replace small gear located in the inside of motor (lens drive assambly motor).
Feb 25, 2009 | Canon NP 6050 Copier
Canon NP 6050
E210 Lens problem
Lens is stuck, or can not go to home position, check motor and sensors
Oct 20, 2008 | Canon NP 6050 Copier
Canon NP 6050 Copier Logo
336 people viewed this question
old marine
old marine
