Question about GE Profile 26.6 cu. ft. Side-by-Side Refrigerator with Dispenser TFX27PRBWW
Ice in the freezer. element failure? - GE Profile 26.6 cu. ft. Side-by-Side Refrigerator with Dispenser TFX27PRBWW
    Prodigy:
    An expert who has answered 500 questions.
    Sergeant:
  • 531 Answers
Could be timer defrost thermostart or heater
Posted on Apr 02, 2009
Whirlpool fridge gets frost build up in freezer
This means you have a defrost problem or a bad door gasket.
Apr 24, 2016 | Whirlpool Refrigerators
Why is my whirlpool wrn28nwb6 not freezing?
Check your defrost timer also make sure its turning also there's a thermostat and heating element that defrost the ice at given cycles
May 16, 2014 | Freezers
Side by Side GE Refrigerator freezer will not defrost which allows frost/ice to build up. I have cleaned all the areas behind the unit as well as under the unit. After I manuely defrost the freezer it...
The defrost circuit has failed in your fridge. Typical failure is with the defrost heating element. To troubleshoot, you need to remove the remove the contents of your freezer section and remove the freezer back panel to access the evaporator coil. You will need a hair dryer to melt the ice on coil. The heating element is attached to the coil. Use a meter to confirm that the element is bad. Hope this helps you.
Nov 08, 2010 | GE Profile 23.1 Cu. Ft. Side-by-Side...
Ice build up around fan in frezeer.makes looud noise....if not melted the refridgrator part a bottom of unit stops cooling.....if melted fan runs smthly....things cool well, but happens again over noght...
The defrost circuit has failed. Typical failures are the defrost heater has opened, the defrost timer if equiped, is not advancing or the defrost thermostat is open. To check the heater, melt the ice, and use a meter to check if the heating elements are open, if they are, then you will need to replace the heating element.
Aug 23, 2010 | Kenmore 64802 Top Freezer Refrigerator
Leaking kenmore side byside Refridgerator . It seems to leakout the freezer door side. Ice builds up at the bottom or floor of the freezer.
If freezer is icing up, you might have a defrost problem. Frost free models have a heating element that is controlled by a timer to automatically defrost ice, defrost timer turns on defrost heating element every 12 hours to melt ice in freezer and allow good air flow.
You can test defrost element with an ohm meter(located inside freezer coils-will have two wires going to a plug connection), if OK replace defrost timer (located in various places depending on make and model when ice is gone take back cover off find drain hole and clean
Aug 14, 2009 | Refrigerators
Ice maker will not make Ice. I have cleaned the
Aug 13, 2009 | Refrigerators
DOES NOT MAKE ICE
Aug 13, 2009 | Freezers
Freezer was pack withg ice and the regrigerator is warn
If freezer is icing up, you might have a defrost problem. Frost free models have a heating element that is controlled by a timer to automatically defrost ice, ie defrost timer turns on defrost heating element every 12 hours to melt ice in freezer and allow good air flow.
Aug 10, 2009 | Refrigerators
Coils inside freezer keep icing up.
You can test defrost element with an ohm meter(located inside freezer coils-will have two wires going to a plug connection), if OK replace defrost timer (located in various places depending on make and model of fridge)
Aug 08, 2009 | Refrigerators
Freezer won't keep the sane Temp
Check that the fanmotor is running and is not obstructed. If it is running, then you have an ice build up on the freezer (evaporator) coils. This can be caused by failure of the defrost system. Either the control board needs replacing or the defrost element, or the thermodisc.
Mar 08, 2009 | Freezers
Refrigerators Logo
43 people viewed this question
Top Refrigerators Experts
Sal De GO PATS
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
