Question about Panasonic KX-T7425 Corded Phone
Need all incoming calls to ring on preferred phone
We currently have four phone numbers for our business and would like all calls to these numbers to be directed to our main phone in reception. Two lines currently ring at reception, but the other two will be directed straight to phones in staffs offices. have the manual and tried everything but cant work it out. Driving us nuts. If anyone could help it would be really appreciated.
  • 1 more comment
  • eleanor621 Feb 18, 2009
    Thanks Carl, Im sorry but we dont know what DIL etc. is. I forgot to mention we have the KX-T7230AL, does your solution apply to this model as well? Also not sure what you mean by programs 407-8 and 603-4?
    Yeah that's the one we have got, when you say programs 407-8 and 603-4 do you mean to type that into the phone when in programming mode? Sorry, bit lost.
  • eleanor621 Feb 19, 2009
    Hey again Carl, we typed in the programs you said but it didnt make a difference, just changed some other settings for tones etc. Do you know if there are instructions on this in the manual somewhere? If so we would be happy to follow them, cant find them is all.
  • Panasonic Master
  • 2,460 Answers
Depending on how the private lines were programmed, you need to pull the ringing out of DIL 1:1 if it was assigned and put it into DIL 1:N. Look at programs 407-8 and 603-4.
Carl
Posted on Feb 18, 2009
  • 1 more comment
  • Carl Navarro
    Carl Navarro Feb 18, 2009
    When you say you have the manual(s), then you must have the TD-816/1232 system manuals. If you don't, programming changes are going to be impossible. I don't know what AL is, but try the U.S. version of the programming manual. http://www.public.carl.airpost.net/TD/12...
  • Carl Navarro
    Those are them.
  • Carl Navarro
    Carl Navarro Feb 19, 2009
    I'm not exactly sure what you are asking, but I'll try to be patient.
    I'm guessing that the first lines, CO1 and CO2 ring all phones. Since an 816 has 4 lines, CO3 and CO4 would be the private lines. In a 1232, it could be 3&4, or maybe 7&8. You can find that out by going to wherever those lines appear, press PROGRAM 99 and the button they ring in on and read the CO assigned to them.
    Go to the pdf page 182 and read from the top.
    Now, from the programming phone, dial 407 and use that number obtained above to see if the CO is programmed to ring at the extension ie 407 SP PHONE 0x and read the display. If it says CO 0x and Disable, you don't have to do anything. If it says CO 0x and there's a number there, like the extension it's programmed to ring to, press the TRANSFER key and STORE. Do that for the other CO obtained on the second private line so that all 407 and 408 commands say Disable.
    Now, press the HOLD button and dial 603 (pdf page 274) and press SP PHONE 2 times. The display should read #01-1 CO01 Immed. Press the FWD button until the CO shows up that you used above. It will have a status of No Ring, Immed, 1 ring 3 ring 6 ring or Disable. Change it with the AUTO ANS button until it says Immed. and press STORE. Now press SP PHONE 2 times and the display should change to 02-1. Repeat the above through all of the Jacks yiou want to ring, changing only the xx-1 jacks (digital phones).
    Honest, once you do it a half a dozen times, it will get really easy :-)
    cn
    Go to page 182 of the pdf and read from the top.
I have BT line and have call divert but can't remember how to divert calls, HELP please
Check which services are active [System X] *#001#
Charge advice (before call) *40* (Number)
Charge advice (All calls) *411#
Charge advice (During call) "R"(to hold call) *40#(Call will be reconnected)
Cancel all calls charge advice #411#
Reminder call *55*(Time in 24 hour format)#
Cancel reminder call #55#
Call Divert - all calls - activate *21*(Number to divert to)#
Call Divert - all calls - to check *#21#
Call Divert - all calls - to cancel #21#
Call Divert - on busy - to activate *67*(Number to divert to)#
Call Divert - on busy - to check *#67#
Call Divert - on busy - to cancel #67#
Call Divert - on no reply - to activate *61*(Number to divert to)#
Call Divert - on no reply - to check *#61#
Call Divert - on no reply - to cancel #61#
Call waiting on *43#
Call waiting off #43#
Call waiting - to check condition *#43#
Call waiting - to answer 2nd caller Recall + 2
Call waiting - remove beeps during call Recall + 0
"Ring back" (Camp on busy) 5
Cancel ring back #37#
Caller display on *234#
Caller display off #234#
BT call minder (voice mail) 1571
Check called number 1471
Release CLI 1470 + dialled number
Withhold CLI 141 + dialled number
Access "Choose to refuse" 14258
Call barring on (outgoing) *341 + option number #
(options are 1 = allows 999 and operator, 2 = allows 999 & local, 3 = allows 999 & STD, 4 = bars all operator calls, 5 = bars *, 6 = bars premium adult lines, 7 = bars premium information lines)
Call barring off (outgoing) #341*(PIN code)#
Incoming calls barred off [System X] #261#
Incoming calls barred on *261#
Incoming calls barred off #261*(PIN code)#
Feb 19, 2015 | BT Lands Phones
Nokia 6085 drops incoming calls
in profile management under caller settings you should find an option there to set the number of rings before timing out. Set it to whatever your preference is and it should solve your problem. otherwise it may be a provider issue, try calling AT&T and explaining what's going on.
Dec 02, 2013 | Nokia Cell Phones
My Lexmark Interpret S405 fax?copy machine picks up incoming call from cell phone as fax. it goes onto fax automatically after 2 rings..
It seems that you're sharing your home phone line with your Lexmark fax machine. You can adjust the "pick-up" ring from the printer operator panel by pressing the Setup button > Fax Setup > Ringing and Answering > Pick Up On > select your preferred number of rings before the fax answers.
Please note:
If you have an answering machine connected to the same line as the fax, set the answering machine to answer incoming calls before the printer does. Increase the number of rings by a factor of 3 over the answering machine. For example, if the answering machine is set to pick up on 4 rings, set the printer to pick up on 7 rings.
If you have a voicemail feature in the same line as the fax, you may subscribe from your phone service provider for a distinctive ring pattern feature. You can program your printer to have a distinctive ring pattern and phone number for incoming faxes.
Should you still need assistance, please leave a comment to my response and I'll get back to you. Should this resolves your problem, your rating will be greatly appreciated.
Nov 08, 2011 | Lexmark Interpret S405 Wireless All-in-One...
I have a mobile of spice model no m4330 .from todaymy incoming calls are barred .if anyone dial my number it answeres that the number is busy . my outgoing calls are running smoothely.pls help me to break...
To cancel bared incoming calls on your phone, enter one of the code given below.
##67#, ##21#,##62# or ##61# then okay/send/yes. the phone will be unbarred.
Regards
Jun 25, 2011 | Cell Phones
Hi: I have a Panasonic KX-T7420 phone. When one of the incoming lines is ringing and I pick up the handset, it picks up the intercom and not the incoming line. Is there a way to get the thing to answer...
There are 2 things that would prevent you from being able to answer a ringing phone by picking up the handset. Your phone has to be ringing, and you need to set preferred line ringing on incoming calls.
The second part is easy. Press PROGRAM 99 and dial 22 STORE on your phone. Now when a call rings on your phone you can pick it up. If you can't, then your phone is not ringing.
Ringing is set in system programming.
Carl
Aug 04, 2010 | Panasonic KX-T7420 Corded Phone
Answering
Hello, if you are using this phone on a Panasonic 308 or 824 system press 40 for an external incomming call or 4 followed by the extension number to pick up a certain extension that is ringing.
Thank you.
Mar 25, 2010 | Panasonic KX-T7730 Corded Phone
Line 4 doesn't ring in coming call
The way 4 line phones work is that you need 4 lines on every jack that is connected to your phone.
You see the light probably because one of the phones has line conected and you see line appearance.
Mar 20, 2009 | Nortel Lands Phones
Answering machine wont pick up it just cuts off incoming call leaving line busy
just set the amount of rings higher on the back of the phone and make sure all you old messages are deleted and also make sure its not set to do not disturb
Mar 28, 2008 | Uniden Cordless Phone
Sharp UXB700 Fax
Below is for when you are using machine in fax mode, is that how you use it or are you also using the answering machine function? ie TAD mode
If desired, you can change the number of rings on which the fax machine
answers incoming calls in FAX mode. Any number from 2 to 5 can be
selected.
1 Press FUNCTION once and 3 times.
Display:
OPTION SETTING
To select FAX mode, press
(with no document
in the feeder) until the arrow in
the display points to FAX.
RESOLUTION/
RECEPTION MODE
RESOLUTION/
RECEPTION MODE
FAX
A.M.
TEL
Using TEL Mode
58
2 Press once and once.
3 Press once.
4 Enter the desired number of rings (any
number from 2 to 5).
Example: 3 rings
5 Press to return to the date and time display.
Note: If you are using Distinctive Ring, the fax machine will answer calls after
two rings regardless of the above setting.
Oct 16, 2007 | Office Equipment & Supplies
Panasonic KX-T7425 Corded Phone Logo
283 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
