Question about GE 5 cu. ft. / 142 liter Chest Freezer FCM5DMWH
Fish smell power went out about a year ago, full of fish... WHOAA! Tried everything cant get all the fish smell out, tried baking soda, charcoal, vinegar, bleach. Not much smell left, but some. Not sure if this will affect other food i try to put in the freezer.
  • GE Master
  • 3,051 Answers
Hi there
i have to give that a wow !!! any way if you can get some clr and wipe it down real good and leave it wet it overnight that has helped us in some of the apartments that we clean well good luck and let me know how this does best regards mike
Posted on Feb 18, 2009
Used wrong water filter. Now that we replaced with correct filter, there is a horrible odor in the refrigerator.
Hello Mary;
My name is Peter. I am a retired field service refrigeration technician.
Putting in the wrong water filter will not effect the smell in your refrigerator. At times the granules in a water filter will break down and get into your water dispenser and ice cube tray. This should not create a bad smell, just cloudy water.
Your plastic liner in your refrigerator has pores and holds odor. You have something in your fresh food section or freezer that is spoiled. Your fresh food section receives cooling air from your freezer. If you have a spoiled product in your freezer you will not smell it because it is frozen. But, as the cooling air goes into your fresh food section and cools down you will smell it.
Find the bad product in your freezer and discard.
With a 50% solution of white vinegar and water wash the plastic liner.
Now you can put a tray of baking soda in your unit, until you purchase deodorizers based on temperature requirements, one especially designed for the freezer section and one for fresh food section. These deodorizer are about $12.00 each.
Try Lowe's and Home depot.
May 11, 2015 | Samsung RF31FMEDBSR Stainless Steel 31 cu....
My ice cubes have a funny odor/taste.
Does your refrigerator have a water filter? if it has one it will be in the kickplate/grill below the freezer door. If it has one replace the filter.
Aug 17, 2011 | Whirlpool Freezers
Bought house and deep freeze stayed, looks relatively new, maybe 7-10 years old, we defrosted it, and vacuumed out the excess water and had it unplugged for about a week before plugging back in and no...
Spray it out with neat bleach (wear old clothes), lemon scented works well, then flush the unit out with water, I use a high pressure cleaner but hose will do, tip it on its side if needs be, it wont harm it. Ensure not to get water in any of the electrics, allow a day to dry out and hay presto, a fresh smelling freezer.
Hope that helps, please dont forget to vote.
Mar 02, 2011 | Freezers
There is a horrible foul smelling fish like odor coming from the freezer. It has been cleaned inside and out and we found a dead mouse under the freezer but removed it and then cleaned again. There has...
This is just an idea. the sounds may just be age.. some systems are louder than others and some that are noisy become quiet. But the smell concerns me. It may be that there is something in the cooling fins that is producing the smell. The air from the outside does not directly go into the freezer so I don't think the mouse is the issue. Problems like this usually end up coming from the insulation inside the walls of the freezer. But since you have no history of the freezer loosing power and fish going bad I can suggest anything...If you have any easy access to the inside of the freezer try and take a look. One way to possible clean the smell is to put a bunch of charcoal briquettes on some cookie sheets and put those inside the freezer for a day or two. then switch them out... also you can put a pan of armor hammer backing powder down inside and change that every other day. good luck
Sep 17, 2010 | Kenmore 16.7 cu. ft. / 473 liter Upright...
Mold and mildew
call a repairman to replace the gasket and see what he recommend.
Apr 27, 2010 | Frigidaire 14.1 cu. ft. Upright Freezer...
Foul fish smell emanating from the freezer
Well an old remedy is to put a box of opened arm and hammer baking soda in the freezer and fridge to keep it from having bad odors.If that doesn't work you can try some charcoal it is perfect for absorbing odor, just don't use the matchlight kind or it will smell like lighter fluid.
Apr 06, 2010 | Kenmore 20.3 cu. ft. / 575 liter Upright...
Sears Freezer, Model 253 9284013-unable to locate manual, nor online. Freezer did not maintain freezing level, fish thawed slightly, dripping liquid onto bottom interior. It froze over. On bottom, at the...
Your problem could be caused by a clogged drainage tube. even though you may have removed the ice it may still have a clog. my suggestion would be to take all of the contents out of your fridge and let it sit unplugged for atleast 24-48 hours with the doors open this will eliminate any left over ice that may be clogging your drain tube. if this dosent help then you may have a defrost heater problem, or possibly a defrost termination switch problem. as for the smell i know that vinegar works well for getting rid of odor. ther eis also a product you can purchase called fridge aid, it is a charcoal based air purifier and should work well.
Oct 11, 2009 | Kenmore Freezers
Smell from fridge freezer even after thorough cleaning and disinfecting and defrosting Model Hotpoint RFA52. Temperature control OK
Put Charcole brickets in the refrigerator. Charcole works better than baking soda and usually take care of the smell.
Feb 20, 2009 | Hotpoint Freezers
Freezer problems big time
Try putting a tray of crushed charcoal in there... a one foot by one foot tray about 3 inches deep filled with crushed BBQ briquettes (the kind that doesn't have lighter fluid in it!) left over night or longer may pull much of the "stank" out, and you can always do it again with fresh charcoal if it works but not well enough... Good luck!
Aug 17, 2008 | Freezers
Frost free freezer smells like fish
IF THERE WAS A LAYER OF ICE ON THE BOTTOM OF THE FREEZER, THE DRAIN IS PROBABLY PLUGGED UP. IT WILL NEED TO BE CLEARED BEFORE PUTTING BACK INTO SERVICE OR IT WILL JUST DRAIN INTO THE FLOOR OF THE FREEZER AGAIN. AS FAR AS THE ODOR, TRY PUTTING CHARCOAL IN IT TO ABSORB THE ODORS. IT WILL HAVE TO BE LEFT IN THERE FOR QUITE A WHILE. WHEN THE FREEZER IS CHILLED, IT WILL LESSEN THE SEVERITY OF THE ODOR. IF THAT IS UNACCEPTABLE, THERE ARE COMMERCIAL ODOR NEUTALIZERS ON THE MARKET YOU CAN USE.
Mar 30, 2008 | Kenmore Freezer 20.3 cu. ft. Frost Free...
GE 5 cu. ft. / 142 liter Chest Freezer FCM5DMWH Logo
162 people viewed this question
Top GE Freezers Experts
Charles T Nevin
Charles T Nevin
christian nielsen
Victor Nwachukwu
Victor Nwachukwu
Are you a GE Freezer Expert? Answer questions, earn points and help others
