Question about Belkin Easy-Transfer Cable for Windows XP and Windows Vista Business English DVD for PC
Connectivity problem with Belkin Easy Transfer Cable with XP and Vista. Presumably, software is installed on both machines (installed F5U258 driver on the XP machine, and was pre-installed on the Vista machine). Tried work around using network connection, but seems to lose connection there also. Tried using the Belkin cable connection several times, but never could establish a connection.
Hi..Start the file transfer on your old pc.When you get the screen to choose the option of using the transfer cable,select it..On your new pc click Start>accessories>System tools and then windows easy transfer..Follow on screen prompts and away you go..Just transfered some hol pics to my new vista machine
Posted on May 01, 2009
I can't get mynew computer to accept windows xp
Ok so im a little confused.. You have windows 8, windows 7 and xp on your computer??
Did you install the xp os correctly?
Nov 30, 2013 | Belkin Components Belkin Easy Transfer...
Ten simple sentences
What exactrly do you mean? Is this a problem pertaining to the Belkin Easy-Transfer Cable for Windows XP and Windows Vista?
Feb 16, 2011 | Belkin Easy-Transfer Cable for Windows XP...
Purchased a belkin easy transfer cable. When
One of the most common problems is the computer's operating system not recognizing the cable's drivers. This is most common with non-English operating systems. The quickest solution is to download the most recent driver.
If the Easy Transfer Cable isn't working properly, you can try a few things to fix the problem. Make sure that you have installed the Easy Transfer Cable drivers on your old computer with the CD that is included in the cable package. If you did not do this, close Windows Easy Transfer, insert the CD that came with the Easy Transfer Cable into your old computer, and then follow the instructions on the screen. When this is complete, begin the transfer process again.
USB ports might be another cause of the problem. When Windows Easy Transfer asks you to connect your computers with the Easy Transfer Cable, try plugging the cable into other USB ports on your computers.
A more complex problem involves the F5U409 USB PDA Adapter (The USB/Serial Portable Adapter) not installing properly. If the driver is unzipping, but the unit is not working, you need to manually update the drivers. They should all unzip to a file called F5U109 in the C: drive of your computer. Point to this file through the Device Manager to update.
Hope it helps.
Mar 21, 2010 | Belkin Easy-Transfer Cable for Windows XP...
I recently purchased a Dell Inspiron 560S with Windows 7. Our present computer has Windows 2000. I bought a Belkin Easy Transfer Cable and note on the packaging it states for Vista and XP. Will it work for...
Unfortunately, Windows Easy Transfer is not supported on Windows 2000. So I would suggest you to return this cable back and use the manual method of transfer of data from one computer to another. Thanks. Abhishek
Mar 10, 2010 | Belkin Easy-Transfer Cable for Windows XP...
My Belkin easy transfer cable is having problems installing. It has been stuck inspecting my current configuration forever. Is something wrong?
i use windows live messenger 14.0 , if anybody send an webcam request , my cam open but not always connected , plz i need some solution , thx a lot for u
Dec 30, 2009 | Belkin Easy-Transfer Cable for Windows XP...
Transfer XP files to Vista: i am having a nightmare of a time trying to transfer files from my XP computer to my new Vista computer. I tried using an Easy Transfer Cable fo Windows Vista. The driver CD was...
yeah u can use remote desktop connection.which u can find in start->program->accessories->remote desktop.first u need to connect the two computers using lan wire(ethernet cable)....for detailed help ask me on satvir_kambo@yahoo.com
Sep 01, 2009 | Belkin Easy-Transfer Cable for Windows XP...
Belkin esy transfer cable problem?
Check the easy transfer details on the link below:
http://techtake.net/2009/08/12/windows-easy-transfer-windows-7/
http://techtake.net/2009/08/12/can-i-upgrade-from-windows-xp-to-windows-7/
This may not be a direct solution, but will help you identify the problem.
I hope this helps.
Aug 26, 2009 | Belkin Easy-Transfer Cable for Windows XP...
Error installing belkin easy transfer cable
Go to Belkin's support site here: http://catalog.belkin.com/support/?lid=en, then navigate to the cable that you have and download the drivers to your hard drive. Then when the found hardware wizard comes up next you can select to install the driver from a location you'll choose (point it to wherever you downloaded them to on your hard drive). XP SP2 should have picked it up, but if your running Vista you may need Vista specific driver (should be at the Belkin support site linked above).
Good luck.
Feb 24, 2008 | Computers & Internet
Belkin Easy-Transfer Cable for Windows XP and Windows Vista Business English DVD  for PC  Logo
1,085 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
