Question about Mitsubishi VS-50609 50" Rear Projection Television
Mitsubishi vs-580r red tube works for a while then starts flashin
Hello i have a mitsubishi vs-580r tv ...picture is good for a while then the red tube will start to flash off and on...stays off for a while then comes back on and stays on for a while...i was thinking that the tube may be going out...any suggestion would be appreciated thanks...
Found a loose ground wire ....repaired it and tv works great.
Posted on Feb 20, 2009
My vs-580r mitsubishi tv wont work on dish
Hi Edward helton, my name is Kimberly and I form part of the Social Media Department with DISH. It is my pleasure to assist you and further look into this for you. Please email me directly at: kimberly.escobar@dish.com and provide me more details regarding the issue so we can help you.
Kimberly Escobar
Social Media Representative
DISH L.L.C
Sep 01, 2013 | Televison & Video
Replacement bulb for mitsubishi VS-60705 rear projection tv
The set does not use a bulb, it is a CRT type set which means it has instead 3 picture tubes, a red,green, and blue.
In order to try to help what is this set doing and not doing?
Dec 18, 2012 | Mitsubishi VS-60707 60" Rear Projection...
My mitsubishi vs-55707 was smelling burnt and the picture was imbalanced, (an almost 3-D effect) then all color and sound went out. turned it on a few days later, got sound and somewhat of a red tinted...
That would be the CRT Board to Red Tube,Mats Electronics did have some CRT boards $9.95
1-800-628-1118
Encompass Parts Distribution might have them 1-800-638-3328
Jan 14, 2011 | Mitsubishi VS-55707 TV
I need to know which picture tube needs to be replaced everything on my tv is mainly green
hi I would say blue and red
depending how old is your tv you should check first with screen controls located near
the right side speaker behind the front panel
there are blue red green master screen control along with focus control just turn the controls clockwise and see what happens
if the red and blue do not light up at all the tubes are not involve
good luck
Sep 29, 2010 | Mitsubishi VS-60111 60" Rear Projection...
I need a new Lamp. what is the parts number for a mitsubishi rear projection model number VS 50501
Hello.
in VS models there is no such a thing as a lamp. Your TV have 3 CRT tubes (picture tubes) each of them dedicated to Green, Red and Blue part of image accordingly.
It is not the part that you can easy replace by yourself and it cost new around $600 and just to refurbish existing one around $320.
But you have to refurbish all three of them at the same time. So we are talking about $1000 just for parts, not to mention enormous effort to align everything back together.
If you have bad CRT in your TV - I would advise just to trash it and invest in new one.
Lamp is replaceable in DLP projection Mitsubishi TV and it is next generation of TV"s. Model number starts with: "WD".
If you still insist on part number - I need to know what color of CRT you need - they have different part numbers.
Best regards
Russ.
Aug 18, 2010 | Mitsubishi VS-50501 50" Rear Projection...
VS-50803 50" Mitsubishi No picture problem
Sounds like your picture tube has went out,, or maybe something simple,, to fix,, i would at least let a tv shop check it out ,, worth a chance ,, nothin 2 loose,, good luck
Oct 05, 2008 | Mitsubishi VS-50803 50" Rear Projection...
Mitsubishi VS-4541 too much red
The set is old and the picture tubes are probably weak. you can pop off the front grill, remove the protective panel to expose the picture tube sockets. On the sockets are controls to increase or decrease the intensity of the colors. The red is on the left ,green center and blue right. Go to a B&W picture or turn the color off, then adjust for the best grey screen.
Jan 03, 2008 | Mitsubishi VS-45605 50" Rear Projection...
Mitsubishi VS-60705 red lamp replacement
The part you are describing is actually the red picture tube, not a lamp. The tube will come dry and you will need to disassemble the lens assembly on the old tube, drain the coolant (antifreeze), reassemble the parts and seal on the new picture tube, fill with fresh coolant, install the new tube, reconnect all wires including the dangerous high voltage lead, then realign the yoke and entire convergence circuits. This is not something that should be attempted by anyone without experience. If you try it yourself and the seal is not working perfectly, the coolant will drip down on your main boards and the set will be ruined. If you slip while lowering the new tube in the chassis there is a good chance you will crack the tube's neck, and that tube will be useless too.
Jul 30, 2007 | Mitsubishi VS-60705 60" Rear Projection...
Tube sparks inside itself under red projector??
have a tech check your set high voltage is escaping.good luck.
Apr 15, 2007 | Mitsubishi VS-50501 50" Rear Projection...
1998 mitsubishi big screen tv model vs-50603
Good Day, bigjim;
No inner tube. The tube may light up but it no video bias to turn the tube on, or the tube is so gassy that it doesn't emit properly.
It sounds like you will be in the market for another TV, because it sounds like like the CRT may be bad.
Hope this was helpful and not tooo late.
Good Luck, big IRISH.
Dec 30, 2006 | Mitsubishi WT-46805 46" Rear Projection...
Mitsubishi VS-50609 50" Rear Projection Television Logo
140 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
