Question about Canon Pixma MP500 All-In-One InkJet Printer
I have error U071. I have been refilling the
I have error U071. I have been refilling the PGBK5 tank with black dye not pigment black for ages. I suspect that it may be because I have not been refilling it with pigment black. The LCD says that I have "more than one ink tank of the following color installed" The diagram indicates the large tank and calls it BK ( not PGBK).It appears that the only solution is to buy a new Canon tank. However, I am concerned that it still won't work. Does anyone have a genuine fix?
  • PiranhaPete Mar 01, 2009
    The way the chips work is a light is emitted from the LED on the rear of the chip and it shines through the cartridge prism. When you start your printer the cartridges swing over the left and an optical sensor picks up the light from the cartridges. There are a number of things that can effect the sensor, such as having the lid open or a dirty sensor. Or in my case ink splattered on the prism.
    Problem Solver:
  • 15 Answers
You will need to get a new(er) print cartridge and replace the old one to eliminate the problem.
Posted on Feb 22, 2009
  • jimfaub Mar 01, 2009
    I have experienced the same problem after refilling the ink cartridge for several applications. I suspect that if the printer can not properly ID the tank levels or read the "chip" connected to the cartridge...then it is time to change it out to a different or new cartridge. That is the remedy that has worked for me.
Why does my hp c309 Photosmart Premium printer require two black ink cartridges? Can I use just one?
The Photo Black is pigment ink (last much longer than dye ink), while the Black is dye ink. Have alook here: for detail explanation
May 13, 2010 | HP Photosmart Premium C309A All-In-One...
Why does canon 860 pixma printer have 2 black ink tanks? only one seems to be used,
The big black tank is pigment based ink used mainly for printing text documents and copies and the smaller black is dye based ink used along with the color inks during photo printing.
Dec 30, 2009 | Canon PIXMA MX850 Multifunction Printer
Canon MP600 printer. Black Ink cartridge PGBK5 is
You need both. One is pigment and the other is dye. One is used for photographs and the other for non-photographs - but it's the printer that decides which one to use.
All Canon printers (to my knowledge) will stop working if any one ink cartridge is empty. This is to prevent damage to the print nozzles. The ink itself is the cooling medium for the hot nozzles.
Nov 29, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Error code U071 , more than one ink tank of te following color is installed, is the message on the screen. This is not the case as each cartridge is different and correctly installed?
Error U071 : More than one ink tank of the following color is installed. U071.
Action : Confirm that the ink tanks are installed in the appropriate positions.
The machine will not print if the wrong type of ink tank is used, or if it is installed in the incorrect position.
Be sure to install the ink tanks in the correct order. The proper arrangement from the left is Black (CLI-8BK), Black (PGI-5BK), Yellow (CLI-8Y), Magenta (CLI-8M), Cyan (CLI-8C).
Hope this hepls.
Nov 28, 2009 | Canon PIXMA MP830 All-In-One InkJet...
PIXMA IP4200 won't 'accept' Pigment black--vent blocked?
if you still have the old tank load it in. an than try the new one again. or tank could be bad.
Mar 27, 2017 | Cannon Canon i960 Photo Printer
Error U071 ;more than one ink tank for black
your chip may get something wrong if the sensor is dirty or some ink goes over it!try to pull out the Bk carige and put it back again if not help try same but get some tishue and clean up the chip contact serfice!
Aug 24, 2009 | Canon Pixma MP500 All-In-One InkJet...
Need to replace ink cartridge
Replacing the five ink tanks (cyan, yellow, magenta, black dye, and black pigment) is a simple task. The top of the printer flips up to reveal the ink tanks and the printheads, and by flipping a lever, you can pull out each tank individually. Being able to replace individual tanks is a boon, as you won't waste colors you use less frequently. Also, you won't need separate photo ink to print photos, which we appreciate. Canon ships the Pixma MP830 with full ink tanks. Replacement color and dye-based black ink tanks cost $14.25 apiece, while the pigment-based black ink tank costs $16.25. Canon estimates the cost per page for both black text and color text to be an inexpensive 2 cents.
May 31, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Black ink
The PGBK cartridge is a pigment black ink, while the others use a dye for coloration. The pigment black is used when printing text and other documents. The dye ink is used when printing photos and other colored documents. The dye black is used in conjunction with the color (dye) inks to provide tinting and color gradation, and therefore is not used nearly as much as the pigment black unless you use your printer only for printing photos.
If you're printing text and documents, you will need to buy another pigment black (PGBK) cartridge.
Oct 13, 2008 | Canon MP610 Photo All-In-One Printer
Canon Pixma MP500 All-In-One InkJet Printer Logo
307 people viewed this question
old marine
old marine
