Question about Sony KV-27V42 27" TV
Sony shuts off after being turned on, stand by/timer light blinks
Hi, Sony KV-27V42 When I turn on my TV,it will shut right back off again and there is a red LED light blinking on the front that says Stand by/timer next to the light.
  • 3 more comments
  • padfoot7 Feb 18, 2009
    blinks 4 times
    I can solder but where am i going to find the vert.IC? Inside or out on the back pannel? thanks
  • padfoot7 Feb 24, 2009
    Finally got it all cleaned out. I tried to solder it but the solder gun I have, for some reason, will not melt the metal. Should I add more? If so what kind of solder would be most likely used on there.
    Thanks for your help, time, and patience!
    oh yeah, i forgot the part to tell you, the board is marked IC1701, this is it right? Thanks again.
  • Yvonne Foster Apr 10, 2009
    my standby light blinks thirteen times and stops then starts the cycle again.
  • 4,234 Answers
The blinking should be in a pattern of a count, pause, count. That is an indication of the problem circuit. Can you post that count please? That info will allow me to give you possible defective parts and costs for the repair.
Posted on Feb 18, 2009
  • ABRsvcs Feb 18, 2009
    4 Blinks usually indicates no vertical. If you can solder you should be able to resolve this yourself. Locate the vertical IC which will be a small flat IC attached to a heatsink with about 9 pins or so. It will be marked LA7837 or something similar. Try resoldering the pins on the IC first. If that fails to resolve the problem, replace the IC. Report the results here. There may be a few other parts that need to be replaced, but the symptoms will change.
    Keep me posted.
  • ABRsvcs Feb 19, 2009
    Sorry about the late response, I'm just getting caught up now. Yes the vertical IC is inside the back. Look for a small metal heatsink. The part will be marked TDA8172 and on the board willl be marked IC541.
I have a sony tv model kv-27v42 i have sound but no pictture and stand by light blinks what is the problem
How many times do this standby light blinks at a time of switch on? These blinks are fault indications. From the number of these blinks, you can get an idea about the faulty circuit section inside it. Count it. If you wish to get more details about the blinking codes to Sony TVs, check this link.
Feb 24, 2013 | Televison & Video
Sony KV-20FS12 shuts off after being turned on, stand by/time light blinks
the blinking is actually an error code. watch the blinking closely and you will see it blink a number of times pause briefly then blink the same number of blinks over and over. If you let me know the number of blinks I can tell you why the set isnt powering up.
Aug 07, 2012 | Sony KV-27V42 27" TV
My tv shut itself off and now the 'stand by/timer' light is on
how old is your lamp, sounds bad. please give me high rating
Apr 16, 2010 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Sony WEGA Fails to Turn On Stand-by Timer Flashes 7 Times
IC/high power transister(s) and/or other componentshas gone bad gone bad - usually from a power surge. These will have to be replaced. A technician should check these out for you.
Jun 03, 2009 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Tv turns on then off, stand by timer light blinks 4 times
You need to replace the power supply unit on this as it has malfuctioned there about $90 bucks plus labor on that.
May 25, 2009 | Sony FD Trinitron WEGA KV-20FS120 20" TV
Sony FD Trinitron WEGA Standby Light Blinks, TV Does Not Turn On
Sony FD Trinition Wega KV-32HS510 Try to turn tv on -it starts then shuts off -stand by lights keeps flashing. Memory stick light flashes then goes off.
Nov 29, 2008 | Sony FD Trinitron WEGA KV-34HS420 34" TV
My TV won't come on!!!
you have powersupply problem .you wil have to have it checked by tech sorry
Mar 22, 2007 | Sony KV-27V42 27" TV
Sony KV-27V42 27" TV Logo
846 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
