My computer is getting boot up
I couldnt even see the BIOS screen.... kindly do tell me waht could be the reason behind it.......and how to fix the problem.....
  • 1 more comment
  • Prem  Kumar
    Prem Kumar May 11, 2010
    What model of DELL Computer is it? for eg..Dimension or XPS
  • Blokely
    Blokely May 11, 2010
    Do you hear any beep sound? Do you use an add-on graphics card?
    Check if any of the following components are seated properly:
    - RAM cards
    - graphics cards
  • Kathleen Bota
    Kathleen Bota May 11, 2010
    hi suseeboon...
    what operating system are you running?
    also... do you hear the usual booting noises or not? if you do it may be the screen... so if your computer sounds like it's booting normally, you should probably check the screen cables... check the connection going out of the sceen, as well as into the computer and into the power source.
    let me know how that goes....
    bru*
  • 3 Answers
Sometimes there are settings in the CMOS setup that tell it not to show that screen. So you need to force it to go into setup to change that by pressing either F1,F2,F10, Del or escape key before you see the O/S logo come on the screen and get into setup and make the changes.
Posted on Feb 18, 2009
I have an acer aspire 9300-5317. She has been a great computer but I recently have been having problems. I am looking to format and reinstall but for some reason I get no acer slash and therefore no bios...
you ca try few steps first try with F10 or when you turn on press tab to show psot screen or physically you should reset coms by removing and fixing your coms battery try and get back to us!!!!!
Nov 27, 2010 | Acer Computers & Internet
Change hard disc problem
Ah this is a nightmare problem.... the only solution I know of to fix this is tiresome to say the least
Reinstall XP
But you need to delete the partition that Windows is on
and then reboot your computer
Go back to install XP and all should work well -- you may need to remake the partition and format it before Windows recognises the disk - but that is simple enough
If you can not boot into the CD - you will need to change your BIOS settings to boot from CD first
When your computer comes on a screen displays
It will tell you which key to press to get to your BIOS setup / settings page
Look for boot options and make sure the CD is first on the list
That will get things working -- a total drag I know but it is the only way I have found of getting this to work
Please vote kindly if this has helped
Oct 08, 2009 | Dell Vostro 1510 Laptop
I have been having some boot problems into windows with my p4s800 mx motherboard. I have purchased it with a 3,0 ghz cpu and put it together yesterday, after which I tried to boot it. It works on lets say...
The BIOS utility probably has a setting for the BIOS to automatically detect and maintain your CPU's clock speed. Make sure that is ON or ENABLED. Another probable reason for the failure may be your RAM settings. Again, use the automatic detection of your memory's speed and latency settings.
One last probable reason may that you may be using different kinds of memory SIMMS or DIMMS. Some boards are very finicky and will not work efficiently with different types, if at all. Others will simply not work.
Aug 16, 2009 | Computers & Internet
Error loading operating system
1. The reason it says "error loading operating system" is because kill disk wiped the operating system from off your computer.
2. Now that you have the installation disk, you need to tell the computer to boot from it. For Dells, usually press F12 when the Dell logo appears, and it should bring up a boot menu. Select the optical drive and it should boot. If you do not see a boot menu, go into your computer's BIOS and tell it to look at the optical drive first when booting, then it will boot from the disk.
Jun 28, 2009 | Dell Inspiron 1100 Notebook
Emachine destop not recognising acer lcd monitor
It sounds more like the computer isn't starting up. The "no signal" message is coming from the monitor itself to tell you it's on but there's nothing coming in to display. Normally no special drivers are required for the monitor, and you'd see at least the computer maker's splash screen and BIOS messages if the computer was starting up properly.
You'll need to determine what is keeping the computer from starting up. Make sure it's getting AC power and that the power light comes on when you press the front panel power button. You may need a power supply. If the computer comes on but doesn't boot you may have memory problems or trouble with the motherboard. But your monitor is working properly.
May 10, 2009 | Microtek C593 15" Flat Panel LCD Monitor
Pc restart before entering os
Okay you will need to run the OS install disk. DO NOT REINSTALL THE OS!!! Instead enter the repair portion of the disk. When you get into the dos command screen type "fixboot" without the quotations. It will ask you if you wish to continue. Then restart. That will fix your problem. If it doesn't tell me and I will continue troubleshooting.
Ryan Frame
Creative Energy Associates Technical Center
May 02, 2009 | Computers & Internet
Dont have post messages at boot not even bios version
sir u can go to the bios by tapping the f2 key while turning the system on immediately....
in the bios page the bios version id written.
also if the system is not booting up try disconnecting each and every device that is connected with the computer except for the mouse,monitor and keyboard.
Apr 25, 2009 | Dell Dimension 2350 PC Desktop
ECS A350 WON'T BOOT
plz check the first boot device is rom and your having a bootable cd, if every thing is ok then try by changing the hdd cable
Jul 06, 2008 | Computers & Internet
No Beep but boot up fine
possibly the on board speaker is disabled in the BIOS ?-
May 16, 2008 | Intel D865GBF Motherboard
MAC OX
#1, I assume you are installing this on a MAC computer... On a regular PC computer, this is technically not possible legally...
What version of OS X are you installing?
Rgds.
Nov 10, 2007 | Computers & Internet
Computers & Internet Logo
57 people viewed this question
David Payne
David Payne
