Question about Intel DG31PR Motherboard
Windows server 2003 - while loading going for dump
Hi, Recently i have upgraded my system from Intel 845,P4 to IntelDG31PR with 2 GB(single) DDR2 RAM, Intel Dual core Processor 2.2 Ghz. Earlier i have 2 Hard disks with Windows XP and Windows server 2003. Am able to swap between the OS by selecting the HDD to boot from setup. Now after upgradation when i tried to login to Windows server 2003, am getting an error with blue screen going for Dump. can you help me
  • 2 more comments
  • Anonymous Feb 19, 2009
    i have installed all the drivers. If i have logged in Safe mode it is allowing me to login.
  • Anonymous Apr 14, 2009
    I have the same problem also
  • Anonymous May 05, 2009
    yes i have same problum
  • Yannick Verhoog May 11, 2010
    Have you installed the proper drivers?
  • 4 Answers
No Intel Desktop MBs "officially" support Windows Server Operating System. Having said that, the components on the MB are pretty conventional, and you should be able to build a machine running Windows Server 2003 by manually installing WinXP drivers for the otherwise unsupported features.
It sounds like the original poster wanted to boot off install HDs from another machine without performing an install - I'd strongly suggest starting with a fresh install.
Posted on Apr 15, 2009
I want to upgrade my system ram size to 2gb...my system memory configuration as follows mother board: intel102ggc2 system bus speed :800mhz processor (p4):3.0ghz ram slots available:2 and presently i'm...
The below is the contents of Intel published for your board
Intel Desktop Board D102GGC2 Technical Product Specification
System Memory The board has two 240-pin DIMM sockets and supports the following memory features: • 1.8 V (only) DDR2 SDRAM DIMMs with gold-plated contacts • Unbuffered, single-sided or double-sided DIMMs with the following restriction: Double-sided DIMMS with x16 organization are not supported. • 2 GB maximum total system memory. • Minimum total system memory: 128 MB • Non-ECC DIMMs • Serial Presence Detect • DDR2 533 or DDR2 400 MHz SDRAM DIMM
hope it helps, if so rate the solution
Nov 16, 2010 | Intel D102GGC2 Motherboard
Problem with DG31PR board while loading windows 2003 server.
check HDD and RAM, make sure your HDD new formated
Sep 03, 2009 | Intel DG31PR Motherboard
Swaping hdd 845 motherboard to 915 motherboard
its always safe to have data backed up
u can swap the HDD
but bootup with the Win2K CD in the Drive and after the files are loaded at the first screen select install then after it detects the OS select R (Repair) and this will reinstall the operating system files and then you can use the system as before though u may have to install the device drivers and motherboard drivers
for any other clarifications u can place a comment in the same question or u can mail me at mail2pvs@gmail.com
Jul 30, 2009 | Intel Pentium 4, 3.0 GHz 530...
Intel 845 gvsr memory problems
Sounds like the RAM is not compatible. Try another 1 GB chip from same manufacturer & see if that helps.
Dec 20, 2008 | Computers & Internet
Intel D865GBF Ram related questions
here are the specifications of *********** board go through it...
Processor Support Intel® Pentium® 4 processor, Intel® Celeron® D processor and Intel® Celeron® processor in the 478-pin package
Note: It is important to verify supported processors before using this Intel® desktop board. Supported front side bus speed 800, 533, and 400 MHz Integrated Graphics Intel® 865G Chipset with Intel® Extreme Graphics 2 Chipset Intel® 865G Chipset AGP Connector AGP 3.0 (4X & 8X Speed 1.5 and 0.8 Volt Only) Memory Type Dual Channel DDR 400 MHz (PC3200), 333 MHz (PC2700), and 266 MHz (PC2100).
Note: Be sure to review important memory and system bus speed considerations before using this Intel® Desktop Board Max Memory Capacity of up to 4 GB Memory Slots 4 DDR DIMM Sockets Slots 6 PCI
So it will support DDR2 and you can upgrade upto 4GB...
Sep 28, 2008 | Intel D865GBF Motherboard
Problem with DG31PR while loading windows 2003 server with 4gb ram
You MUST run a 64 BIT if you want to run anything more than 3 Gb of ram ( such as windows xp 64 BIT , Vista 64 BIT , or even winows 2008 server 64 BIT ) Windows 2003 does NOT support 64 BIT ....
Jul 29, 2008 | Intel DG31PR Motherboard
250gb sata hard disk to 845 glad mother board
Hello all. I have the same issue. My MB is 845G [P4 2.4 Ghz] and SATA harddisk I need to install is Seagate 250 GB Baracuda with 3.0Gb/s interface, I belive which makes this HD as SATA II. So for this motherboard should I prefer PCI cards which support SATA II over the supports SATA I [these are cheaper].
Thanks so mcuh!!!
May 12, 2008 | Computers & Internet
Intel ASUS P4 845 GL Motherboard
Hi, For an ASUS P4BGL-VM Intel 845GL Chipset Ultra ATA100 MATX CPU Type: Intel Pentium 4 478-Pin (OEM), the Asus site specifies max of 2 x 184-pin DIMM Sockets support max. 2GB PC2100 / PC1600 non-ECC DDR or SDRAM memory but not "and". Personally, I find it more practical to install 2 X 1Gb rather than a single 2Gb. Hope this gives you some idea. Kind regards.
Aug 07, 2007 | Intel ASUS P4BGL-VM 845GL Chipset Ultra...
Intel DG31PR Motherboard Logo
314 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
