Question about Lexmark X4270 All-In-One InkJet Printer
How would fax run on VOIP? what requirment it needs?
Fax is not very reliable over Voip. You may take a look at a https vfax service that you can plug into your fax machine. It is 99.99% reliable even with high packet loss
http://www.caller-ip.com/vfax
Posted on May 06, 2015
    Problem Solver:
  • 12 Answers
I use Ringcentral as my business voip and for that I must say
  • Your RingCentral VoIP phone system is an Internet-based voice, text and fax platform you can customize, without requiring on-premise PBX hardware.
  • You get free call management software, with a user-friendly web interface empowering you with crisp voice, fax, and robust features
Check here(S): RingCentral Review Are They The Easiest Going Business VoIP
Posted on Jan 11, 2015
Remember the fax/printer, your telephone and your computer all have to use a regular phone jack when using a router/VOIP service. This means you will have to use a splitter. The data port on the back of the Lexmark will work. But do not use the phone port as this will not work.
Posted on Aug 31, 2011
    Problem Solver:
  • 12 Answers
Typically faxing doesn't work on VOIP. i tried many times and sometimes it would go through although it said it didn't. other times it didn't work at all. VOIP has a limited bandwidth and the fax needs to send more info over the line than VOIP makes room for.
to have the best luck, stop all downloads and other network traffic while attempting to fax, so that there are no other programs or devices using the internet. the fax will have its best chance of working that way, although it probably still won't
here are some very good tips as well:
http://chris.pirillo.com/how-to-fax-over-voip-on-the-internet/
Posted on Feb 18, 2009
How do I access system settings to change the baud rate and turn off ECM.Thanks in advance.
Fax settings for VoIP ' How to lower the Baud Rate ' Faxing ...
www.voipmechanic.com/voip-fax-settings-9600-baud.htm
How to Lower the BAUD rate to 9600 on fax machines for better VoIP faxing success.
Faxing over VoIP, the correct configuration settings that you ...
www.voipmechanic.com/faxingissuesandotherdevices.htm
How to fax over VoIP and the settings and configurations, like BAUD rate that you need to set.
Dell VoIP Fax Settings, how to lower the BAUD rate and ...
www.voipmechanic.com/voip-fax-settings-dell.htm
VoIP Fax settings for Dell printer/fax machines/multi-purpose machines.Missing: kyocera
Faxing over VoIP - Sfax
Dec 15, 2015 | Kyocera FS-1128MFP FS-1128MFP...
Fax problem
I want to make sure I understand this completely. You get no dial tone from the fax machine when hooked up to VOIP. In the past, was there an audible dial tone from the fax, or did it just dial silently and give you an error if there was no tone? When you said you got a dial tone by connecting a phone to the ext phone port of "the machine" did you mean the fax machine? If you get a dial tone by running a phone through the fax machine, then the line is good. I have used a fax machine over Sunrocket before they went defunct, which used the same technology base as Vonage - so it should work. If you used to get an audible dial tone when using the fax, and no longer do, and you are geting a dial tone on a regular phone that is connected to the ext. port of the fax machine, then the problem has to be in the fax machine itself, not the VOIP. If you can verify that, we can go from there.
Oct 08, 2007 | Brother MultiFunction Center MFC-440CN...
My problem is that I have just purchased Vonage as a VOIP phone line. I have a HP LaserJet 3055 printer/fax and I am trying to send faxes but it does not work. I was instructed to lower the baud rate,...
Configuring the V.34 setting to Disable (Enable is the default setting) to lower the speed.
Voice over IP (VoIP) services provide normal telephone service, including long distance service through a broadband Internet connection. These services use packets to break up the voice signal on a telephone line and transmit it digitally to the receiver, where the packets are reassembled. The VoIP services are often not compatible with fax machines.
If you continue to have problems faxing, contact your VoIP provider. Because the installation process varies, the VoIP service provider will have to assist in installing the all-in-one fax component.
Although a fax might work on a VoIP network, it can fail when the following events occur:
• Internet traffic becomes heavy and packets are lost.
• Latency (the time it takes for a packet to travel from its point of origin to its point of destination) becomes excessive.
Feb 15, 2011 | HP LaserJet 3055 All-In-One Printer
Connect fax from 6210 to phone via cable modem (VoIP)
In Order to use a Fax functionality of the router you need to connect the small RJ11 cable for telephones on the printer port. These printers do not suppoer VOIP Fax. To use VOIP as fax you can purchase a online VOIP subscription where you can scan and fax the documents.
Feb 04, 2009 | HP OfficeJet 6210 All-In-One InkJet...
Can not receive fax on Canon Laser Calass 710 Faxmile.
Line noise could cause trouble. I don't know if this unit supports VOIP phone lines. Many fax units require a genuine analog line or something that reproduces an analog phoneline.
Can you test the unit with a genuine analog line?
Nov 17, 2008 | Canon LaserCLASS Fax 710 Printer
Problems faxing with VoiP
Not exaclty, Becaure VOIP Is a Service provider which supports Digital, and the All-In-One we have is a Unit which detects analog signals the best.
And that is the main reason you are not able to send and receive faxes through VOIP Servies.
First i would recommend you to call Vonage and ask why you are not able to sena a fax through thrie VOIP Services.
They should have a fix for the same, because you pay for their services.
And if in case you call HP and check the same issue, they will also dierct you to call your service provider and clarify the same with them.
One step that you can try is by decreasing the fax speed.
Go to Setup/Menu in the All-In-One, Gop to advance fax setup and reduce the speed to slow and then try.
Good Luck
Aug 28, 2008 | HP Photosmart 2610 All-In-One InkJet...
Faxing using voip
I can tell you after trying Vonage a few years ago and them telling us to change all sorts of settings on the machine, that faxing never worked and now I have no idea what the factory default settings should be.  So, if you decide to try it, WRITE DOWN THE DEFAULT SETTINGS so you can switch them back if you need to!
Jul 22, 2008 | HP OfficeJet 6110 All-In-One InkJet...
HP 5610xi All-in-one wont send fax since switching from Vonage to Comcast
the 5610 will send & recive with comcast try to do the test from the unit itself. Try to send a test fax to HP 1-888-473-2963 it will send you a return fax
Jul 11, 2008 | HP Officejet 5610 All-In-One InkJet...
Faxing using voip phone service
We found out that the machine requires a dedicated analog line, so we won't be able to use it on a voip system.
Jun 16, 2008 | Canon PIXMA MX700 All-In-One InkJet...
CANT SEND FAX THRU VOIP LINE
Make sure baud rate is set to 9600 and error correction mode (ECM) is off. If this does not correct your issue then you may have to contact your provider to adjust your sample rate (packetization). This adjusts the size of the packets and is often a common fix. You may want to run a ping/tracert from command prompt to check for latency and/or packet loss with your ISP. I'm a voip tech and these are the primary fixes for fax issues.
Jan 24, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Lexmark X4270 All-In-One InkJet Printer Logo
465 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Roopesh S
Roopesh S
Sanath Kumar V
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
