Question about Konica Minolta PagePro 1350W Laser Printer
Konica Minolta 2550dn status monitor
Every time I try to run status monitor i get an error message saying unable to find supported driver on a supported port, then KMSMUI MFC application has stopped working. I want to be able to monitor the toner in my printer in detail.
How can I get this?
  • Anonymous Mar 24, 2009
    I have the same problem can sum one help us with this
  • jgrella123 May 11, 2010
    Do you have the original sofware that came with the printer?
  • 214 Answers
SOURCE: konica minolta 2400w toners problem
hei, yes you can buy new toners but usually this problem is caused by toner dust, you have to take out your toners, and clean the contact chips and reinstall your toner. also there is a mechanism whats reading the chips that can be dusty.
Posted on Feb 09, 2008
SOURCE: Konica Minolta 2400W Error Message
remove the opc drum.
there are two black plastic flags that detect paper jams. one is high up just below the fuser unit. The other is roughly half way up the printer between two small transfer rollers very close to the opto sensor. Apparently it frequetly gets jammed behind the plastic cover, and once jammed you would never realise it is there.
I managed to prise it out from behind the cover and the "paper jam at transfer roller" message was cleared.
Unless you know it is there and hiding it is not obvious at all that anything is wrong.
Posted on May 27, 2008
SOURCE: Keep Getting Error Message "(Colour) Toner Not Installed"
I did not have any error message for each color. My message error was sepcific for magenta after I removed it to refill it. After refilling, cleaning metal contact points, resetting the metal tab which prevents message of "low toner", I put the cartridge back in and received the "magenta toner not installed" message. I turned off the printer (safety first!) , I then pushed the button left of the hole where you slide the cartridge in, There is a squarish hole with a circular or cynlinder shaped button in that squarish hole. Use a small screw driver to push and hold it in. While the button is held in I gently rotated the cartridges so that my magenta cartridge was no longer in view, (rotate them counter clockwise). I released the button, shut the door, then turned on the printer.
Posted on Sep 28, 2008
  • 3 Answers
SOURCE: konica minolta 1350w status display comes on at start up
Open c:\windows\system32
find a file called MSTMON_Q.EXE
right click and rename the file to anything with a file extension .exe, I named it MSTMON.EXE
Create a shortcut to this new file in case you need it in the future and put the shortcut on your desktop
also, write the original name of the file down or put it on notepad, in case you want to change it back.
restart windows
Posted on Apr 16, 2009
  • 34 Answers
SOURCE: how do i replace the
When you open the door to access the toner and waste toner area, you will see a letter "K" on the left side of the waste toner box, and a thumb screw on the right side of the waste toner box. Immediately above the letter "K" there is a raised area in the brown plastic housing. It is between the blue toner cartridge, and the waste oner box. There is a second raised area 2.5 inches at a 225 degree angle below the thumb screw on the right side of the waste toner box.
If you will place your thumbs on the raised areas and your forefingers on the white plastic rear cover of the waste toner box immediately below the raised areas and squeeze your fingers towards your thumbs, the waste toner box will come forward at the top of the box. You can then lift the waste toner box up and out of the printer.
Please squeeze carefully if you think your waste toner box is close to full as you may inadvertently find waste toner all over the place.
The two blue caps on the back of the waste toner box are to keep the waste toner in the waste toner box instead of your carpet.
Installation of the new waste toner box is the reverse of the above procedure. The new waste toner box almost snaps in place.
Here in California waste toner is considered a hazardous material and must be disposed of properly.
Posted on May 14, 2009
I am getting an "unable
Try formatting the card with the 'Format' function in the camera menu.
If you read the manual you can can find which card types are supported.
Sep 04, 2011 | Konica Minolta DiMAGE Z1 Digital Camera
Konica Minolta 5430DL error code 111112
I couldn't find the install disks so downloaded the driver from the Konica website, un-installed the software and re-installed it. After calibrating the colours everything seems fine now.
Oct 01, 2008 | Konica Minolta magicolor 5430 DL Laser...
Status monitor for Konica Minolta 2400w
The status software does not run when the printer is shared. Whenever I have a problem I have to unshare the printer then run the status and it will show up. I then resolve the problem then turn the share back on.
Pain I now but it works
Aug 02, 2008 | Konica Minolta magicolor 2400 Laser...
Konica Minolta 2400
what is the printer condition, what lights are burning in printer panel. what does the status monitor say, did you try to print status/conf page from status monitor. ?
Jun 23, 2008 | Konica Minolta magicolor 2400 Laser...
pleas install status monitor, that will tell you whats wrong.
May 29, 2008 | Konica Minolta magicolor 2400 Laser...
Printer not recognised
Probably you need to reinstall your printer drivers. Here is the download page
Feb 16, 2008 | Konica Minolta magicolor 2400 Laser...
Konica minolta 2400w toners problem
My Konica 2430DL does this every time I start the printer, I am quite sure it is supposed to do this as I it rotating the toner and calibrating itself. On one occasion I recently had the status monitor say to install cartridge... I removed it, shook it, reinstalled it with the same results. I just purchased a new Konica brand toner, replacing the old one and 'voila' sucess! It still does the little dance (rotation) every time, but it always has, but after installing the new toner the message went away. If you reinstalled the toners, this may be your problem - you need all new toners; spendy but it should solve your problem, otherwise; if you've already done this, I don't have an answer. Good Luck!
Dec 28, 2007 | Konica Minolta magicolor 2430 DL Laser...
Error light and no printing
What does the status monitor message say? The red light is the most general error. It's bit like taking a 747 back to Boeing and saying there is something wrong with it.
If you do not have the status monitor installed, download it from Konica Minolta and run it. Once the status monitor is running it will read the error from the printer.
Sep 05, 2007 | Konica Minolta magicolor 2300DL Laser...
Konica Minolta PagePro 1350W Laser Printer Logo
365 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
