Question about RTO Ford----oil Pump-drive Gear 2n,8n,9n
Oil pressure good at startup, after driving 10 or 15 min it gose down and out when stop. but will go up when givin gas. dose not knock or tap.
  • 491 Answers
Sounds like a worn engine.....the more clearance you have on the crank bearings....the more oil leaks out from them....lowering the pressure......but that doesn't mean you can't run it .
As long as you have some higher pressure when working the engine.....I wouldn't worry about it.
It is normal for the pressure to drop a little at slower engine speed when warmed up.
Why not put in a thicker oil.
Try a 20w40 or 20w50 or straight 40 if your weather is warm to increase warm/hot oil pressure.
Posted on Aug 25, 2009
When im driving or giving car gas oil pressure is good, if car stops moving and gets no gas oil pressure drops to zero? I drive a 2007 gmc envoy 4.2 liter. Any ideas everyone says just a bad motor.
Are you hearing a knocking coming from the engine if so yeah there may be a rod getting ready to go soon which would be an engine replacement. Have you checked the oil levels? It could also be an oil pump or oil pressure sensor. There are many things to consider and many things it could be.
Jul 04, 2017 | GMC Cars & Trucks
1995 Ford Windstar Engine Knocking at startup. Driven 2800 miles since last oil/filter change. Oil level SAT, Coolant level SAT and no visible leakage. Engine completely rebuilt 2 years ago. Engine has...
No if the oil light has flickered you have oil pressure loss some time just belive the sensor do help us out. lifter do not cause oil pressure loss pressure is built in the rotation of the crankshaft. The knock under the plenum will point you to that cylinder that is affected, (main bearing) as for a 1995 the injectors can only cause a misfire but no knocking noise,will they honor the warranty
Apr 21, 2011 | 1995 Ford Windstar
After driving for 5 to 10 mins oil light came on then engine started tapping. ended up changing oil and oil filter and still done same thing and now is tapping all the time.
It sounds like your oil sending unit is not functioning. When this goes out you lose oil pressure. When the oil pressure drops the oil does not circulate and then your engine does not lubricate and will seize up on you. That's the knocking you are hearing.The oil light is on because of the drop of oil pressure. I would stop driving that vehicle until that oil sending unit is repaired. If you do not repair this at home or where the vehicle is at the you will want to have it towed to the point of repair. You can test the oil sending unit with a pressure gauge beforehand too but it sounds to me like it is bad. Sometimes they are easy enough to switch out. If you give me your make and model and year of vehicle I can list the steps and location for you. Other wise have it towed to a mechanic. I would like to reiterate that you should not drive it anymore until it is repaired. The other thing that it could be is your oil pump. Either way stop driving it.
Regards, Tony
Apr 10, 2011 | Suzuki Aerio Cars & Trucks
My 1991 jeep Cherokee has a knocking sound in valve area. How do I fix
the cure depends upon the problem: Knocking is usually down low and is generally an engine bearing problem. If you hear a tapping noise (lighter than a knock) and oil pressure is good it can be caused by wear of the pivot for a rocker arm, a worn lifter or lifter and camshaft or a broken valve spring. Tapping can also be caused by low oil pressure in which case it can be due to low oil level, obstructed pump pickup or worn engine bearings. If you are unfamiliar with any engine repair, get a chilton or haynes manual to guide you through whatever needs doing.
Mar 13, 2010 | 1991 Jeep Cherokee Limited
Noking
a knock from the bottom of the motor is a big end bearing STOP DRIVING, new engine or rebuild required, a knock from the rear of the engine could be loose pressure plate on clutch assembly, that is if it is a manual, STOP DRIVING. a rattle from top end is lifters or rockers but you say its a knock so probably not it. one test to do, remove all drive belts to water pump etc and start if the knocking is still apparent then it is internal and time to consider trade in, rebuild or new engine.
May 16, 2009 | 2003 Saturn VUE
2004 FLHTCI Oil pressure not stable
Put an oil pressure gauge on it and monitor it closely. Could be a defective sending unit showing low pressure when pressure is fine. Tapping may be spark knock. Harley did have problems with their fuel injection systems. Make sure you have the right oil filter and oil is at the recommended level.
Apr 27, 2009 | 2004 Harley Davidson FLHTC - FLHTCI...
Oil pressure good at startup, after driving 10 or 15 min it gose down and out when stop. but will go up when givin gas. dose not knock or tap. its 86 ford bronco 302
try changing the oil pump sending unit relay. if that doesnt work have your oil pressure checked to make sure your oil pump is fine
Feb 18, 2009 | 1986 Ford Bronco
Knocking in the engine
are you using the right octang of gas.
Sep 18, 2008 | 1993 Subaru Legacy
My v.w glof glow light dose not come on?
Most likely ignition switch has gone bad.  Don't need to worry about oil pressure light IF the motor is not running, but IF it IS running, shut down motor immediately until oil pressure can be verified with an external gauge.
good luck
please rate all solutions
Sep 11, 2008 | 1997 Volkswagen Golf
RTO Ford----oil Pump-drive Gear 2n,8n,9n Logo
242 people viewed this question
Top RTO Garden Experts
John Trevino
Joseph Mueller
Joseph Mueller
Andy
Are you a RTO Garden Expert? Answer questions, earn points and help others
