FixYa.com
Tags:
Sony Hi8 Hi-8 Tape
Problem capturing audio from Hi8 Tape through...
By Cato - usenet poster
I have a Sony TRV730 Digital 8 camcorder, and I can not capture audio
from Hi-8 recorded tapes when using the firewire port. I have a
Pinnacle DV200 capture card, latest drivers.
I've tried setting the media mode on the camcorder to Hi-8, 12-bit and
16 bit audio (this is an analog tape). Analog recorded tape plays
fine back on camcorder.
The system works fine when I am capturing Digital 8 recorded
programming, but does not work when capturing from Hi-8 analog
recorded tapes.
Can anyone help?
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Aug 01, 2007
Not Rated (0)
paulrmc
paulrmc - usenet poster
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
In Premier, select file-capture-movie. The capture window that pops up
should list your capture device at the bottom of the settings folder. If it
is not listed, then Premier is probably not seeing your firewire card. I
have an ATI AIW capture card with a firewire port, I have not been able to
make this work with my DV media converter, I use another cheap firewire card
that has never given me any problems.
Mike T
Please reply to group, if you must reply direct then-
replace $ with s
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
Not Rated (0)
Luisa_K
Luisa_K - usenet poster
Rating: 0%, 0 votes
The digital camcorder plays the analog Hi-8 tape back properly, I can
hear the audio played through the camera and the analog audio out.
But I can not capture the audio through the firewire port using either
Premiere nor Pinnacles DV Capture tool.
I have version 6.01 of Premiere, and version 2.0 of the Pinnacle
drivers.
Solution #3
Not Rated (0)
lawyer
lawyer - usenet poster
Rating: 0%, 0 votes
If the Hi8 tape was recorded with PCM audio, it won't playback in a D8camera.
Can you hear the audio with headphones or out the audio jacks?
Craig H.
Can you Help with these Audio and Video Media problems?
i lost my CD software disk to...
i lost the disk and now i cant... Answer This...
SOUND DRIVERS FOR ASUS MOTHER...
i want to install sound driver... Answer This...
E-MU Proteus 1 volume control
I had what was seemingly low... Answer This...
Unlock dvdplayer
How can make my Philips PET... Answer This...
need a code to activate dvd...
Hi there, i have a phillips... Answer This...
Repair Service
Find Audio and Vid. Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
