Question about RCA D52W19 52" Rear Projection Television
Removing the HV Wires from Flyback on RCA TV D52W19/
In an attempt to remove the HV wires from my flyback on my RCA D52W19 TV, there is a tiny plastic piece at the top of the flyback that appears to have been holding the hv wires in place. Tugged a little to hard on it and I broke the small plastic piece. Is there a replacement I can get somewhere?
  • RCA Master
  • 5,138 Answers
You really dont need it its only a wire.sliice and reconnect.
Posted on Feb 19, 2009
The bottom half on the RCA D52W19 has been removed and the Flyback on the Back right corner emits a noticable spark when attempting to turn the television on. Is this a flyback problem? Or is this a sign...
this is the flyback. it is not uncommon for this part to be bad and spark. Now it is common if this part is bad then the horizontal output transistor is shorted. this part is located directly in front of the flyback on a large heatsink.
Oct 12, 2010 | RCA D52W19 52" Rear Projection Television
Need to purchase a hv wire boot for an itc222 flyback
You probably can't get the boots that fit over the HV connectors. What is the model of the TV and I can look it up.
Nov 11, 2009 | RCA Televison & Video
My RCA Bigscreen HDTV will not turn on.
Thats either the flyback or the HV splitter. If the sound is coming from the rear left side its the flyback. If its coming from the front of the set its the HV splitter. They are both easy to replace. I will post a link where you can get replacements with instructions if you would like.
May 06, 2009 | RCA D52W19 52" Rear Projection Television
Flyback
Yes it has to be resoldered you will need some special tools a good solder iron solder wick to remove solder a solder ****** and good solder without acid core you will need to remove the wires on the flyback be careful
Nov 14, 2008 | RCA D52W19 52" Rear Projection Television
Flyback wires
DEPENDING ON WHICH FLY BACK YOU GET. THE ONE I GOT DID NOT. I'M LOOKING FOR THE WIRE NOW.
Oct 21, 2008 | RCA D52W19 52" Rear Projection Television
Tv stop working
That model is famous for bad flyback which is what I believe is your problem as well. The flyback is the HV transformer.
Apr 11, 2008 | RCA D52W19 52" Rear Projection Television
RCA D52W19 Flyback Transformer
This transformer does not come with the hv lead,if the arch is coming from the side of the transformer,cut the side of the plug were it goes into the transformer and the lead will come out,there is no voltage stored on the hv lead after the set is unpluged for a few min.,the transformer you can get at any rca repair center.
Mar 21, 2008 | RCA D52W19 52" Rear Projection Television
RCA HD52w66
solder around flyback pins ,also these sets are having major problems with flyback transfromers/high voltage tripplers.let know how you come out after soldering HV transfromer.
Jan 26, 2008 | RCA D52W19 52" Rear Projection Television
Big mistake
what was the origonal symptom before replacing the flyback? You could try using epoxy on the wire get a nice size glob of it on there where the wire got cut.
Jan 17, 2007 | RCA P52921 52" Rear Projection Television
RCA D52W19 52" Rear Projection Television Logo
386 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
