Question about Black & Decker 9072CTN Cordless Screwdriver
Drill bit won't in securely - Black & Decker DP240 Screwdriver
I just purchased a Black & Decker DP240 Screwdriver and I'm unable to get the bit to fit securely in the socket. The instructions are not particularly helpful.
I may be new to hardware, but I didn't think it would be so difficult.
Help, please!
Thanks
N
  • 2,176 Answers
I am going to assume that the bit you are trying to insert is a 1/4 hex drive. If so are you pulling or pushing on the collar of the tool holder to insert or remove a bit. Make sure that the hex on the bit is not twisted also. Let me know and I will go from there.
Posted on Feb 18, 2009
Change the screwdriver bit in a black and decker 9.6v cordless drill
It should just pull out with a standard or needle nose pair of pliers.
Sep 22, 2014 | Black & Decker 9.6V Cordless Drill Driver...
New dp240 screwdriver wont charge
Take it back and get a Makita or Millwauke Tools cordless screwdriver of at least 14.4V. B&D isn't what it used to be! Neither is Ryobi!
Dec 08, 2013 | Black & Decker Pivot Plus Cordless...
Pivot Plus PD600 drill bit problems
pull the very front bit back that holds the drill Re: Jeff
Apr 10, 2012 | Black & Decker Pivot Plus Cordless...
How do i change the bit?
It just pulls out if its a screwdriver and if it has a quick release chuck then pull chuck back towards drill body and pull bit out.
Feb 02, 2011 | Black & Decker Pivot Plus Cordless...
How do I change the screw drivers on the black & decker power screw driver?
The black collar should slide forward, allowing for the removal and insertion of bits.
Nov 25, 2010 | Black & Decker Pivot Plus Cordless...
CANT GET DRILL BIT OUT OF BLACK DECKER BATTERY CHARGE DRILL HELP
dear sir
please use drill bit remove key with drill machine and try to turn it anti clock vise then your bit will being loose and you can remove it easily .
thank you
hope answer the question
please vote !
Oct 04, 2010 | Black & Decker Pivot Plus Cordless...
Having problems securing masonary Bit on 3/8 Black&Decker Drill 7
If it's an inexpensive bit, odds are it's spinning in the chuck. If the chuck key can't tighten the jaws well enough, you'll need to borrow or buy a different drill (or you could replace the chuck).
If you bought an SDS bit (one with slots milled in the shank), you're best off buying a bit made for a standard drill. It's not impossible to get a SDS bit to chuck into a standard drill, but it's difficult and they often slip loose during drilling, messing up the hole.
Take care!
May 24, 2009 | Black & Decker Drills
Can't get screwdriver bit out
hold the bit into the bench vise & pull the drill wiggle at the same time.
May 01, 2008 | Black & Decker 9072CTN Cordless...
Black & Decker 9072CTN Cordless Screwdriver Logo
255 people viewed this question
Top Black & Decker Drills Experts
JOHN LAPIER
Are you a Black & Decker Drill Expert? Answer questions, earn points and help others
