Question about Kenmore 24 in. 17482 / 17484 / 17489 Built-in Dishwasher
Kenmore elite, no power, tried circuit box
I stood on my head, twirled three times, ate spiders...no help....
Where is the plug in on this thing? Not under the sink....take the unit out?
  • 360 Answers
The unit is hard wired (no plug). with the kick plate removed, you will see a wiring box. With the power off, open the wiring box and disconnect the supply wiring then disconnect the incoming wire from the unit. turn off the water and disconnect the water line under the unit. disconnect the drain line under the sink and pass the slack through behind the dishwasher. Open the door and remove the mounting screws holding the unit in place. slide the unit out.
Please take the time to give this solution a fix ya rating
clarkco
Posted on Feb 18, 2009
Bad bearings or the inner tub mount called a spider. Buy a new washer. sorry :(
Nov 15, 2013 | Kenmore Elite 45986 Front Load Washer
We have a kenmore elite washer mod. 970-c40062-00 ser. xc11700832. the washer leaks, and is very noisy. It is 10 years old
Your Stainless Steel drum is supported inside of the washer tub by a spider assembly. The assemply, which is made of cast aluminum, has corroded (steel and aluminum and detegent don't mix) and the spider assembly has broken. The drum has likely wobbled enough to wear a hole through the tub. You need to replace the drum and spider assembly, and tub.
Mar 06, 2010 | Kenmore Elite 45986 Front Load Washer
Broked Spider on a Kenmore Elite H3 washer.
u can buy them seperatly. the shaft is part of the basket
Feb 06, 2010 | Kenmore Elite 45986 Front Load Washer
Kenmore Microwave Oven Sudden Power Reduction
I would be sure to check the microwave's outlet under a load.
One good way is to use a toaster or hair dryer for about a minute to see if they run at full power and run without their heating elements dimming.
If the power at the outlet is steady, I would suggest a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If it still fails to heat properly, I would say you have a failing magnetron, and it would just be a coincidence that the failure began after the new wiring was installed.
If you need to order the magnetron, Sears sells it for $73.13, but you can get it for $41.84 here.
Feb 14, 2009 | Kenmore 62622 Microwave Oven
Taking bottom panel off kenmore elite front load washer
theres three screws at the bottom,,of the bottom panel,,its easier with a torexs head driver,,,onthejob
Jan 23, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite Trio Frige...Beeping three times in a row suddenly
this unit has a history of the light circuit failing and it will cause the lights to either stay on or off. if they stay on, it will melt the housing around the upper bulb area. it has a recall and should be covered by sears for no charge. it is the control board failure and has a sticking relay for the light circuit, needs board replaced.
the 3 beeps are the unit thinking it has a door open. turn off the alarm on the door control board and call sears 800 # for repair.
Dec 25, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Kenmore elite microwave oven displays "Locked" and will not respond
My Kenmore Elite microwave (don't have the model number in front of me) also mysteriously locked its own keypad (we were sitting in an adjacent room, heard a strange beep, and got up to find the LED reading "Locked."). I pressed and held down the Stop/Clear button for ~10 seconds and it returned to normal.
Mar 01, 2008 | Kenmore 62622 Microwave Oven
Kenmore elite dryer
can you spin the drum by hand? if not,pull front panel off by removing three screws on bottom, remove lint screen, then remove three screws holding inlet housing ( the big brown thing in front) check to make sure not clogged with sock, panty hose ,bra underwire ,etc.
Feb 17, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore 24 in. 17482 / 17484 / 17489 Built-in Dishwasher Logo
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
vince
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
