Question about Sony Xplod 1100 Watt Max 10" Subwoofer, XS-L100P5W Car Speaker
Need an amp to go with speakers
I have one jbl gt5-10 subwoofer 1100 watts i want to know the best kind and size amp to get for them
  • 74 Answers
You could get a 1100 watt amp, but, it is ALWAYS good to get a smaller amp than the max rating so you have a "safe" zone and turn it up all the way so you don't have to worry about always running it at its peak( which sounds better but more chance of blowing it)
Posted on Feb 18, 2009
  • Stephen Davids Feb 18, 2009
    plus i would highly recommend rockford fosgate. these amps are very trustworthy.
    i have been running one with my 2 10'' for years
I just purchased the dual xinbp210 and don't know what size amp i need?
  • Enclosed subwoofer with dual 12-inch speakers; measures 27.5 x 14 x 15 inches
  • illumiNITE technology constantly illuminates the speakers with blue LED lights when in use
  • Handles 600 watts RMS power, 1100 watts peak power
  • Carpeted enclosure, plexi subwoofer viewing window
  • Dual 12-inch Low-Q optimized dri
Mar 26, 2015 | Cars & Trucks
Gt5 12 inch 275 watts how many watts of amp best?
Depends on what output your stereo is. If you underrate the speakers (speaker watts is less than stereo output), the unit will sound louder for a while, then you end up blowing your speakers with the excess distortion. If you overrate the speakers (speaker watts is higher than stereo output) the speaker will not operate correctly and the distortion can damage it also. Its best to get a close match. Slightly higher is better. It is important you know actual wattage output not PMPO ( Peak music power output) A lot of stereos are rated at PMPO. The higher number sounds great but in reality, the figure is the MAX output and by then the sound is distorting badly. Distortion ruins more speakers than anything else...
Oct 11, 2013 | JBL GT4-10 Car Subwoofer
What watt amp would be best for my 1100 watt 10 inch xplod?
I have a 1100 watt sony xplode the silver one 4 ohm rms 3 00 with a 3000 watt 400 rms pyle amp? 8 ohm
Sep 16, 2011 | Sony Xplod 1100 Watt Max 10" Subwoofer,...
What size amp do i use with 2 1100 watt 10" sony subwoofers
I have the same set of speakers and im running a kenwood 2 channel amplifier thats bridged and it works well.
Jan 30, 2010 | Sony Xplod 1100 Watt Max 10" Subwoofer,...
What wattage amp do I need to get good sound in a toyota corolla
Make sure it's a RMS 1200 wats not MAX watts also the Ohms of this speakers and them you can buy any amp. with the same RMS watts of your speaker and same Ohms of resistance.
Jan 27, 2010 | Sony Xplod 1100 Watt Max 10" Subwoofer,...
I have a PB12 that is very distorted. I pull the amp and started checking out parts. There are a bunch of 2 watt metal oxide resistors and they are colored coded indicating 100 phms, but I get all kinds of...
you need to replace the output amp as well as the resistors you mentioned. go to rad shack and get a resistor color code guide as well as power supply troubleshooting book soldering Iron, Its best to have a pro do it>
Jan 21, 2010 | JBL PB12 Subwoofer
Finding the best amplifier
Hello sharky75,
That 1600 watt peak power figure for your subwoofer can't tell you what amp you need. You need to know the maximum RMS power the sub can handle. And you need to know the impedance (ohms) of the voice coil(s). JBL GT5 series subs have an RMS rating of 275 watts. The GTO series handles 300 watts. The Power series handles 400 watts. The GTi series handles 700 watts. Some are single voice coil, so the impedance is fixed. Others are dual voice coil allowing you to wire them for different impedance loads.
For maximum performance your amp should be able to provide at or near the same number of watts RMS into the lowest impedance at which the sub can be configured. For example, if your sub is the Power Series Model number P1224, it has dual 4ohm voice coils and can be wired to present either a 2ohm load (parallel) or an 8ohm load (series). You want to wire the voice coils in parallel for the 2ohm load and select an amp that outputs up to 400 watts RMS into 2ohms. The Orion Cobalt CO8001 is just such an amp. If you have one of the GTi Series subs, a better amp would be the JVC Arsenal KS-AR75 which outputs 700 watts into 2ohms.
Hope this helps.
Jul 31, 2009 | JBL Power P1022 Subwoofer - 10" Dual 2...
Amp
you could use a 2000 what amp
Dec 06, 2008 | Sony Xplod 1100 Watt Max 10" Subwoofer,...
Sony Xplod 1100 Watt Max 10" Subwoofer, XS-L100P5W Car Speaker Logo
161 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
