Question about Bosch Nexxt WTMC3321US Electric Dryer
Want start it clicks
Belt broke or came off. There is a small switch that the tension arm will push when this happens. Reset the belt and push the switch to reset that.
Posted on May 26, 2009
  • 686 Answers
Bad motor
Posted on Feb 18, 2009
Im missing my short cut to my recent documents
Could you tell me What Operating system you have , if its Windows 7, you can
  1. Open Taskbar and Start Menu Properties by clicking the Start button 4f6cbd09-148c-4dd8-b1f2-48f232a2fd33_818.jpg, clicking Control Panel, clicking Appearance and Personalization, and then clicking Taskbar and Start Menu.
  2. Click the Start Menu tab. Under Privacy, select the Store and display recently opened items in the Start menu and the taskbar check box, if it isn't already selected.
  3. Click Customize. In the Customize Start Menu dialog box, scroll through the list of options to find the Recent Itemscheck box, select it, click OK, and then click OK again. (To remove Recent Items from the Start menu, clear the Recent Items check box, click OK, and then click OK again.)
Tip
  • To clear the list of items shown in Recent Items, click Start, right-click Recent Items, and then click Clear recent items list.
May 11, 2014 | Computers & Internet
Tip
How to fix a computer which is infected with viruses, malwares, spywares
In order to remove viruses, malwares, trojans, from the computer, follow the instructions given below.
1. Delete all of the temporary files.
a. Click Start, Click Run(Window XP) and type temp(Window Vista and Window 7-type in the Start Search box which appears at the botton left hand side corner, once you click Start), hit Enter, (hit Continue if required), Click Edit at the top in the menu bar, click Select All, Right Click on Mouse and hit Delete. This would delete all of the temporary files.Note:in Window Vista and Window 7, Menu bar would appear by hitting Alt key.
b. Click Start, Click Run(Window XP) and type %temp%(Window Vista and Window 7-type in the Start Search box which appears at the botton left hand side corner, once you click Start), hit Enter, (hit Continue if required), Click Edit at the top in the menu bar, click Select All, Right Click on Mouse and hit Delete. This would delete all of the temporary files.
c.Click Start, Click Run(Window XP) and type prefetch(Window Vista and Window 7-type in the Start Search box which appears at the botton left hand side corner,once you click Start), hit Enter, (hit Continue if required), Click Edit at the top in the menu bar, click Select All, Right Click on Mouse and hit Delete. This would delete all of the temporary files.
2.Run Disk Cleanup to free up wasted space.Click Start, click My Computer, right click C drive and click Properties. Now, click Disk Cleanup. It will delete all of the useless temporary files.If it ask to click Next, click Next.
3.Scan your computer by using one of the antimalware, antispywares.Restart your computer in safe mode with networking.(As soon as you restart the computer, start tapping F8 and choose Safe mode with networking and hit Enter.)Use the link below to install antimalwares, antispywares .
http://siri.geekstogo.com/SmitfraudFix.php
http://malwarebytes.org/
http://superantispyware.com
http://www.simplysup.com/tremover/download.html
4.Stop Programs from running at the startup.As soon as you restart the computer a number of programs load themselves at the startup and you will be able to see them at the bottom right-hand side corner. In order to stop some of the programs (except security software and programs which you use immediately after starting up your computer) to load itself automatically, please follow these steps.Click Start, Click Run(Window XP) and type msconfig(Window Vista and Window 7-type in the Start Search box which appears at the botton once you click Start),hit Enter, (hit Continue if required)
You will see System Configuration Utility. Click Startup at the top right hand side corner.
Now,uncheck the items which you want to stop to load automatically.Now, click Apply and then click OK or Close. Click 'Exit without restart'Now, you have to delete the startup from registry.Click Start, Click Run(Window XP) and type regedit(Window Vista and Window 7-type in the Start Search box
if required),.Now, scroll up to the top and click Computer, rigth-click it and click Export and save it as file name say backup on the desktop.In order to remove startup from the registry go the followinglocations:
HKEY_LOCAL_MACHINESOFTWAREMicrosoftSharedToolsMSConfigstartupfolderRight
click startupfolder and click Delete.
HKEY_LOCAL_MACHINESOFTWAREMicrosoftShared ToolsMSConfigstartupreg
Right click startupreg and click Delete.Restart your computer.
5.Uninstall the useless programs(unnecessary toolbars like my web search,smileys,myfreeze toolbar). Click Start, click Control Panel, Click Add or Remove programs(Programs and Features or Programs in
Window Vista and Window 7),you will see a list of the programs. Click on the programs, you want to uninstall and click Remove(Uninstall in Window Vista and Window 7).
6. optiize and reset internet explorer.Close all of the window, click Start, click Internet explorer, click Tools, Click Internet Options.Now,on the Internet Explorer properties window under General Tab, click Delete and then click Delete All. Now,click Advanced on the top right hand corner.click reset. click Apply and OK.
7.Update your antivirus, antimalware, antispyware program.
8.Update WindowsWindows XP:Click Start, click Control Panel,Click Performance and Maintenance, Click System, click
Automatic Updates tabclick Turn automatic updating on and click install updates.Windows Vista:Click Start, click Control Panel, click System and Maintenance,click Windows
Update,click Turn automatic updating on and click install updates.
on Apr 07, 2010 | Computers & Internet
Tip
My computer is running slow
In order to optimize your computer performance, follow the instructions given below.
3. Run Disk check.Disk Check program is used to check and clean any errors on your computer and keep it running smoothly.
How to run Disk Check:Click Start, click My Computer.Right-click on C drive, click Properties.Now, click the tab, Tools. In the Error-Checking section, click the Check Now. Also, check both of the check boxes: Automatically fix file system error and scan for and attemp bad recovery of bad sectors.
Now, You will see a message box that says you can schedule the disk check to start the next time you restart your computer. Click Yes. The next time you restart your computer, it will automatically run through a disk check before displaying your login screen. After the disk check finishes, Windows will automatically bring you to your login screen.Note: Check Disk can take more than an hour to check and clean errors on your computer.
4.Defragment Your ComputerTo arrange the files in a sequential manner, it is recommended to defragment the hard drive. Click Start, click My Computer, right-click Local Disk, aclick Properties.Now, the Tools tab, click Defragment Now. Now, Click first hard disk, click Defragment.Note: Disk Defragment may take long time like 30-40 minute to complete.
5.Stop Programs from running at the startup.
Click Start, Click Run(Window XP) and type msconfig(Window Vista and Window 7-type in the Start Search box which appears at the botton once you click Start),hit Enter, (hit Continue if required)You will see System Configuration Utility. Click Startup at the top right hand side corner. Now,uncheck the items which you want to stop to load automatically.Now, click Apply and then click OK or Close. Click 'Exit without restart'Now, you have to delete the startup from registry.Click Start, Click Run(Window XP) and type regedit(Window Vista and Window 7-type in the Start Search box which appears at the botton left hand side corner, once you click Start), hit Enter, (hit Continue if required),.Now, scroll up to the top and click Computer, rigth-click it and click Export and save it as file name say backup on the desktop.
In order to remove startup from the registry go the following locations:
Right click startupfolder and click Delete.
6.Uninstall the useless programs(like gaming softwares, unnecessary toolbars like my web search, myfreeze toolbar)Click Start, click Control Panel, Click Add or Remove programs(Programs and Features or Programs in Window Vista and Window 7),you will see a list of the programs. Click on the programs, you want to uninstall and click Remove(Uninstall in Window Vista and Window 7).
7.Scan the computer with good antimalware, antispyware, antivirus.
http://malwarebytes.org/http://superantispyware.com/
8.Update the drivers on the computer.Click Start, Click Run(Window XP) and type devmgmt.msc(Window Vista and Window 7-type in the Start Search box which appears at the botton left hand side corner, once you click Start), hit Enter, (hit Continue if required).Right click the device, click Properties.Click Driver tab, and click Update Driver.Follow the on screen instructions to complete update.
9.Upgrade RAMWindows can run slow if you do not have enough RAM.Many newer operating systems and programs use more RAM when they are running.How to check RAM.Click Start, right click My Computer, click Properties. You will see the RAM mentioned her.You should have at least 1 Gb(2 GB would be even more better)RAM.
10.Update Windows
Windows XP:Click Start, click Control Panel,Click Performance and Maintenance, Click System, click Automatic Updates tabclick Turn automatic updating on and click install updates.
Windows Vista:Click Start, click Control Panel, click System and Maintenance,click Windows Update,click Turn automatic updating on and click install updates.
on Apr 06, 2010 | Computers & Internet
My printer spoler is not working
Hi g k,
Have you tried restarting the print spooler from services?
Start the Print Spooler service from the Services console
  1. Click Start, click Run, type services.msc, and then click OK.
  2. Right-click the Print Spooler service, and then click Stop.
  3. Right-click the Print Spooler service, and then click Start.
Start the Print Spooler service at command prompt
  1. Click Start, click Run, type cmd, and then click OK.
  2. Type the following commands at the command prompt: net stop spooler
    net start spooler
    exit
    Note Press ENTER after each command line.
Hope this helps, and please rate:)
Gary
Aug 01, 2013 | Samsung Office Equipment & Supplies
Spooler not running
Start and stop the print spooler Windows XP
To start and stop the print spooler open Computer Management, click Start, click Control Panel, double-click Administrative Tools, and then double-click Computer Management. In the console tree, click Component Services.
Under Console Root click Services (Local)
In the details pane, double-click Print Spooler. Do one of the following depending on the task you want to do:
Click Stop to stop the service.
Click Start to start the service.
Feb 23, 2013 | Dell 1110 Laser Printer
Its slowing down and i want to reset everything were i could start off fresh
before you reset every thing lets do these steps
10.Update Windows
PS Please Note to leave a positive note.
Jul 08, 2010 | E-Machines eMachines Monitor E15T4
Slow running laptop
10.Update Windows
PS: Please leave a positive comment
Jul 07, 2010 | Dell Inspiron 700m Notebook
I changed from classic view to movie view and i dont no how to put it back
  1. Open Taskbar and Start Menu Properties by clicking the Start button 4f6cbd09-148c-4dd8-b1f2-48f232a2fd33.png, clicking Control Panel, clicking Appearance and Personalization, and then clicking Taskbar and Start Menu.
  2. Click the Start Menu tab, click Classic Start menu, and then click OK.
Nov 27, 2009 | CyberLink Power DVD DX 8.0 for PC
Start button keeps poping up i am not able to click at start any other program please help
Try these steps:
  1. Click start, click programs, click accessories, click system tools then click system info
  2. Go to tools and click system configuration
  3. Click on general and click advanced
  4. Make sure enable start menu is not selected and click ok
  5. Click on then yes to restart pc.
Jun 22, 2009 | Microsoft Windows 98 for PC
Printer
click start and click on run.. Then type services.msc. Then click OK. search for Print spooler, double click on it and set it to automatic under startup type and click on start. Click apply and Ok if got the message saysing "started"... Then try printing. If u got any error message or if are not able to start. Then try clicking on Start and click on run.. delete the services.msc and type sc config spooler depend= rpcss and click ok. Then try starting the spooler again. Do as mentioned in the first paragraph.
Sep 19, 2007 | Lexmark X1270 All-In-One InkJet Printer
Bosch Nexxt WTMC3321US Electric Dryer Logo
95 people viewed this question
Top Bosch Dryers Experts
Lawrence Oravetz
MightyMikeJr
Are you a Bosch Dryer Expert? Answer questions, earn points and help others
