Question about Whirlpool GH7155XHS Microwave Oven
How do you know the fuse in the microwave is no good?
So my microwave is not warming or cooking but the displays light up and I took out the fuse and examined it but I dont know what i am looking for? Will the fuse be broken? Thanks for any advice.
  • 52 Answers
First you need to see if the energy is being produced, go to an electronic store, here in UK Maplins ( US radio shack) and purchase some standard 5mm red led's cut off the leads close to the led.palce them in the oven and put on cook for 5 seconds, if they light then you have energy. if not then start looking for a large fuse inside the casing, check this and then check the control fuses on the boards.
lots of shops sell cheap fuse testers. best of luck
Posted on Feb 21, 2009
No power, no display power to unit
Blown fuse inside of unit. Must find out why fuse blew, something shorted or bad connections.
Oct 21, 2017 | Jenn-Air JMV9169BAS Convection Microwave...
LG microwave intermittently runs
I would try troubleshooting the "defrost circuit". The behavior sounds like the microwave is cooking in the defrost mode, where it actively cooks then stops allowing the food to rotate and the heat to spread then actively cooking again.
Nov 06, 2013 | Microwave Ovens
Ge microwave je2160sf03
From the description one of the door switches is defective, or a more serious problem has developed.
Jun 02, 2012 | GE Spacemaker Over-the-Range Microwave
Only display on, no cooking power
faulty components i would repolace it if it were mine
Jun 21, 2009 | Kenmore 62462 / 62464 / 62469 1200 Watts...
Need help with my Gold Star microwave.
i just took out my fuse on the same model. you have to pull down the microwave and take cover off. there should be like 6 screws on backside and cover will slide back and off. then you will see a fuse cover with a small cylinder fuse in a plastic cover. pull it out and check continuity with volt meter. mine unfortunately came up good still, so i dont know what kinda problem mine is having. had a short in light and it popped and power was gone. good luck!!
Mar 08, 2009 | Goldstar MV-1526 Microwave Oven
Cooking light inoperable, everything else working fine
just did further testing...I stated incorrectly before, appears to be one/both relays for this light
Nov 12, 2008 | Whirlpool MH1150XM Convection/Microwave...
NNP-294 Dead
If it's intermittent or random, it may be a bad connection, usually on the control board or a loose fuse holder, or even an intermittent fuse.
You should do a continuity test on the fuse while it's in the holder (with the microwave unplugged, of course) then turn the fuse by hand or take it out and put it back in, then test it again.
If you remove the fuse, then press the meter leads against the ends, it can allow internal contact to be made and make a bad fuse appear to be good.
If you suspect the fuse at all, it's best to replace it.
With the microwave unplugged, if you can easily turn the fuse with your thumb & forefinger while it's in the holder, it has overheated and fatigued and the holder should be replaced.
Simply squeezing the holder's terminals together with pliers is not really a good solution.
If you or someone you know decide to look into it, we have critical safety information and disassembly information at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
An intermittent door switch will not make the unit intermittently dead, it will only make it not heat, and depending on the model, it will also likely make the turntable and inside light not come on. But again it depends on the model.
You may need to clean and/or realign the door mechanism or door switch mounts.
This is especially true in case a user opens the door while it's cooking without hitting Stop first or slams the door. Both are big no-nos for a microwave.
The main parts that will kill the power are the fuse, fuse holder, or thermostat or thermal cutout, which are usually located on or above the magnetron and on the top of the cooking cavity.
Please feel free to contact me directly if you need more help.
We're happy to help and we appreciate your thoughtful rating of our answer.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
May 20, 2008 | Panasonic NN-P294WF Microwave Oven
Sharp Carosel R-1481 (no B) & 950 Watts
All MW has a fuse inside to protect the circuit board
Try to replace the fuse
May 10, 2008 | Sharp R-1481B Microwave Oven
GE Over the Range Microwave/Convection won't start
So it's dead - that is to say no display, no lights, and no response from the keypad?
A microwave can be dead for many reasons.
If it goes dead for a while during or after cooking then comes back on, the magnetron is probably overheating and causing the thermostat to open. When it cools, it closes the circuit and allows power through again.
If the fuse is good, it may be an open thermostat or thermal cutout on or near the magnetron or on top of the cavity / body of the oven.
If you or a friend decide to look into it, we have critical safety information and disassembly information at our site, linked here on Fixya: http://tinyurl.com/yzjozk
Please write back with more details if you need further help.
We appreciate your thoughtful rating of our answer.
Nov 25, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
Whirlpool GH7155XHS Microwave Oven Logo
151 people viewed this question
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
