Question about Logitech Optical Marble Mouse USB PS/2
Buttons dont work like they did
My computer i originally setup the mouse on got stolen so when i got a new computer. i installed the mouse and it has four buttons, two for normal clicking and the other two used to work while i was navigating the internet or whatnot, they would go forward and back pages. they dont do that anymore, how do i make it so they do?
  • devils666gua Feb 18, 2009
    yea i tried that too. it didnt even give me the option to pick what the buttons do.
    ok so i got that and all the buttons work, but for whatever reason, my browser wont go back a page when i click the button on the mouse. i made it so the same button does something else to ensure that the button works and it does, so thats not it. is there a way my computer is set up to not allow page scrolling from the mouse? and if so how can i set it up so it will
    President:
  • 778 Answers
You can try accessing mouse properties in Control Panel and check, change the button configuration on the button tab.
To access mouse properties, click Start, then Control Panel, double click Mouse, then the buttons tab.
Posted on Feb 18, 2009
  • 2 more comments
  • Frank  Fernandez
    Frank Fernandez Feb 18, 2009
    In that case you'll need to update the Driver. You will find it herehttp://www.logitech.com/index.cfm/429/15...
  • Frank  Fernandez
    Click on downloads and select your Operating System.
  • Frank  Fernandez
    No, I don't think so, but your Browser may, try updating it or try another Browser.
  • Frank  Fernandez
    You could do a "Manual" Microsoft update and see if anything related to the mouse comes up under "Additional Software or Hardware" for update?
How to setup ge 99916 wireless mouse
Instructions
    • 1Hold the mouse in your hand, press down on the battery compartment cover (the back of the mouse) then slide it off.
    • 2 Insert two AAA batteries into the mouse. Make sure the positive and negative terminals match up with the diagrams inside the battery compartment.
    • 3
    • Replace the battery compartment cover.
    • 4 Connect the USB receiver to a USB port on the computer. The computer will acknowledge that a new device has been installed and you will be prompted to install the software.
    • 5 Insert the software installation disc into the optical drive. Follow the instructions provided by the installation wizard to install the software.
    • 6 Press the link button on the receiver, then turn the mouse over and press the link button on the mouse. The mouse is ready for use.
Jun 07, 2014 | GE Wireless Optical Mouse
How do I setup a wireless mouse on a desktop
To setup a wireless mouse regardless of its type, do the following:
1. Insert the USB transmitter (this could look like a mini plug or a stick) and wait for windows to complete installation.
2. Once this is successful, turn on the mouse by holding down the power button. Or insert the disc that came with the mouse and run the installer. The installer will install the device drivers and setup your mouse's configuration panel which will reside in your system tray.
Make sure that the mouse has batteries and that it is switched on for it to work. It will glow red when it is switched on.
Jul 06, 2011 | Gigabyte Wireless Optical USB Mouse GMW7C
I dont have driver so send me setup plz
Here are two links to driver files. The first is for the PK-335MB, the second for the PK-335E. These are the two models of PK-335 manufactured by A4Tech. Identify which one you have, and then download the corresponding file to install the drivers. If you are unable to figure out which one you have, download and install both. Your computer will then automatically select the correct driver for the camera.
PK-335MB
http://www.a4tech.com/driver/CameraB.zip
PK-335E
http://www.a4tech.com/driver/A4_IM_Magician.rar
If this solution is helpful, please indicate so with a positive rating!
Jun 14, 2011 | A4tech Viewcam PK335 Webcam
Doesn't work.....no laser light appears on the bottom of the mouse. Nothing happens when I hit the "connect" button.
It sounds like these is either a problem with the USB port on the motherboard or with the mouse itself.
Assuming that if a wireless mouse: the batteries are new, the device is actually turned on and the transmitter has been removed from the mouse and plugged into the the USB port and it still does not work, it should be tried on all the other USB ports of the computer. If none work, try on another computer.
This will help determine if the mouse or the computer is the problem. If the mouse does not work on other ports or on the other computer, a defective mouse is likely. If it does work in a different USB port of the original computer, the first USB port is suspect.
If it only works on a different computer, the problem my lie in the setup or BIOS page of the computer. Look for a setting for USB ports. Enable the ports if disabled, and try again. If still no luck, there is some other issue at the motherboard level. Unless fairly new and under warranty, it will probably not be worth trying to fix the problem, when a $20 USB expansion card could be purchased and installed to provide USB connectivity needed.
You could also try connecting a different USB device (if available) to test the USB port. A USB webcam, hard drive, mechanical mouse, etc. are all good choices to test the port. You should indicate or cover any ports that are found to be defective.
I hope this helped and good luck!
Nov 01, 2010 | Computers & Internet
I replaced my hard drive in my hp pavilion desktop a1520n windows loads and then reads that i will have to register my copy of windows But my keyboard and usb ports dont have power so i cant do a...
A lot depends on where the keyboard and mouse are plugged in. I have seen in the past that the USB in the back works better than the front. Are these the original keyboard and mouse? If not, use the original until after Windows loads the desktop.
Mar 21, 2010 | HP P2360AA Keyboard/Mouse
My mouse and keyboard dont work... how do i get it on i dont understand the directions
1. Make sure batteries are inserted and in the right way round.
2. there should be three items
3. Signalsender/receiver. with usb connection
4. Micky Mouse
5. Keyboard
6. Possibly Setup CD?
If setup cd install/wait
Connect signal sender/receiver via usb. Place unit convient position so it can pickup signalfrom keyboard/mouse/ line of sight. Should be a small button push on rear of both micky and keyboard, to activate items, PUSH button.
Nov 16, 2009 | Logitech Cordless EX 100 Mouse
Wireless mouse
Normal 0 Go to Control Panel and click on the Mouse icon. Then the mouse properties will appear showing the mouse buttons. Check to make sure they are set properly.
Hope this helps. Bud
Jan 01, 2009 | Toshiba Wireless Mouse PA3205U-1ETC
Wireless mouse
INSTALLING THE MOUSE
STEP 1 - Battery Installation:
The first step in installing your Wireless Wheel Mouse is to install the batteries.
1 - Locate the two AAA sized 1.5 Volt batteries that came in your Wireless Wheel Mouse package.
2 - Remove the battery compartment cover located on top of your mouse by pressing the cover release button and sliding the cover backwards.
3 - Install the two batteries into the compartment paying close attention to proper polarities.
4 - Replace the battery compartment cover.
STEP 2 - Connecting the Receiver:
If you are connecting the mouse to a notebook that has an onboard pointing device or if you are using a keyboard with an onboard pointing device, you may need to
disable that device before installing and using the mouse.
Sep 14, 2008 | Computers & Internet
USB mouse won't work under XP in a dual boot Ubuntu GRUB 1.5
It has the latest mouse driver (logitech setpoint 4.0). Before installing Ubuntu the setup worked w/ SUSE/XP using GRUB dual boot. After installing Ubuntu XP does not see the usb mouse. Even Logitech setpoint does not have the mouse setup/configuration option. It appears that at boot it does not recognize the mouse or disables it. The BIOS has the usb keyboard and mouse enabled. Currently, I have two mices one for xp and either mouse will work under Ubuntu.
Sep 03, 2008 | Canonical Ltd. Ubuntu
AOPen O35g to usb port
sometimes adapters do not work.
this might work
start computer without mouse. you may have to work with keyboard tab key as you press tab key you should see the icons highlighted install drivers plug in mouse to usb if lucky O/S will recognize mouse and setup
Jul 17, 2008 | AOpen (O35G)
Logitech Optical Marble Mouse USB PS/2 Logo
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
