Question about AOpen Computers & Internet
AOpen AX 34 Pro II Motherboard boot failure
Recently my PC which has a AOpen AX 34 Pro II Motherboard has for some unknown reason failed to boot. This occurs everytime the PC is turned on and a speaker alarm sounds.
Appreciate any assitance provided.
Cheers
  • 135 Answers
Well at least the mobo is still good for now, try a known good stick of ram, also try re-seating any video cards you may have.
Posted on Feb 18, 2009
Update graphics device foram1100-e1302b
All downloads for Acer computers are to be found at www.acer.con, specifically
http://www.acer.co.uk/ac/en/GB/content/drivers
Your model is a Desktop > Aspire > M1100
It will ask you what O/S you are using, because the drivers you need, in general, depend on that.
13.April.2014
Feb 02, 2014 | Acer AOpen AX 6BC Pro (91.87810.A03)...
Hi, I have a Pentium II computer with an award 6BC motherboard. I'm trying to make a dual boot hard drive with win98se and winxp os. Have successfully installed win98se on first partition but cannot...
I assume that when XP gives lot a choice of where you want to install it that you are selecting unpartitioned space ( which should be listed after your primary 98 partition) and that there is enough room on that partition for XP.
If that space is already partitioned, try delecting the partition and then tell XP to install in the newly created unpartitioned space. XP should then prompt to format that space after which the install should continue. If it does not, you must be getting some error message indicating what/where the problem is. If you let me know what the error messages are I may be able to provide further help.
If you have any additional questions contact me by clicking on the "Add a comment" link located under your problem description on FixYa. Also, if you believe that this information was helpful to you, please rate my solution using FixYa's "Solution Helpful" rating scale.
Best regards,
Yavacotech
Mar 30, 2011 | Acer AOpen AX 6BC Pro (91.87810.A03)...
How to connect reset, HD Led, ?
you will need the motherboard manual
go to
http://download.aopen.com.tw/
select motherboard, then ax59 pro, then manual
once you get your hands on the manual open it up and search teh documents for LEDs this should lead you to the LED panel showing you how to connect each labled cable to the motherboard
Sep 24, 2010 | Acer AOpen AX 59 Pro (91.87810.411)...
I want to disable user log in on an older computer atx micro atx cpu 133MHz what jumpers will disable the user log in?? after boot it want the user and password and this machine was bought without...
Hi walkertexr
You can clear the cmos, which will reset the password on the motherboard, by the following:
  1. Turn off the system and unplug the AC power.
  2. Remove the ATX Power Cable from the Connectore PWR2
  3. Locate the JP14 and short Pins 2-3 for a few seconds
  4. Return JP14 to it's normal setting by shorting pins 1-2.
  5. Connect the ATX Power Cable back to connector PWR2
  6. Plug in the ATX Power Cable back to the System,
That should do it. Here's a really bad picture but it should give you an idea of where the jumper is.
Good Luck,
Mark
Nov 18, 2009 | AOpen Computers & Internet
MONITER PROBLEMS
There is are many things that can cause this, try the following:
  • Disconnect any extra items you may have hooked up, disconnect power connectors too (except mobo and fans) (HDs, CD/DVD drives, extra cards except the video card)
  • Remove all but one stick of ram, then rotate the ram in several slots, and swap out that chip with others if it doesn't boot yet (sometimes bad ram will cause your error)
  • Re-seat your CPU
  • after all this also reset your bios, this can be done by unplugging the computer from the wall and removing the battery from the bios, or on some boards there is a jumper to do this (See your manual)
I hope this helps.
Jan 21, 2009 | AOpen Slot 1 AX63 Pro (91.87810.611)...
Web cam
you can buy a USB web cam and install the drivers that came with it then plug camera in should work
Jul 26, 2008 | Acer AOpen AX 6BC Pro (91.87810.A03)...
How to connect Remote to computer
Hello Nairy, Install infrared module onto IrDA connector, and enable function from the BIOS setup. Make sure you have the correct orientation when you plug into the motherboard. Location: Towards rear of motherboard, next to first PCI slot, on AGP side. The number one pin is closest to rear of board. Pin Configuration: 1. +5V 2. NC 3. IRRX 4. GND 5. IRTX 6. NC Please let us know how this works for you, and if we can help you in any other way. Best regards, nightdiver
Sep 20, 2006 | Acer AOpen AX 59 Pro II (91.87810.402)...
Computers & Internet Logo
121 people viewed this question
Top AOpen Computers & Internet Experts
Michael Galve
Michael Galve
David
David
Alun Cox
Are you an AOpen Computer and Internet Expert? Answer questions, earn points and help others
