FixYa.com
Tags:
IBM Internal Floppy Drive
Possible bad floppys...
By Grant - usenet poster
Howdy everybody. I recently had a bunch of PS/2 Model 60s fall into
my office. Unfortunately, it looks like the floppys are not working on
any of them...an example:
c:\ Insert new diskette for drive A:
and press ENTER when ready:
Invalid parameter
c:\
I've spent the last few hours swapping drives around trying to see if
I could get a working configuration, but to no avail. I was just
wondering if anybody out there could actually verify that the floppy
drive is dead from the above information?
TIA!
John
­__
John Kinsella, Sys Admin | UC Davis Math Department | Hardware: (n) The
Voice: (916) 752-8801 | 585 Kerr Hall | part of a computer
| Davis, CA 95616 | that can be kicked.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Aug 01, 2007
Not Rated (0)
Horner
Horner - usenet poster
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
Along with DASDDRVR.SYS mentioned below, there was a production
run of Model 60s with bad floppy drives. They failed over time as the
insulation on the internal wiring harness broke down (it was too short, and
suffered abrasion). These were almost all labelled as ALPS drives.
In <4158od$@over.mhv.net>, (Rick Buser) writes:
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
Not Rated (0)
Ross
Ross - usenet poster
Rating: 0%, 0 votes
Larry J. Ovshak () wrote:
: John Kinsella () wrote:
: : Howdy everybody. I recently had a bunch of PS/2 Model 60s fall into
: : my office. Unfortunately, it looks like the floppys are not working on
: : any of them...an example:
: : c:\ : : Insert new diskette for drive A:
: : and press ENTER when ready:
: : Invalid parameter
: : c:\ : :
: : I've spent the last few hours swapping drives around trying to see if
: : I could get a working configuration, but to no avail. I was just
: : wondering if anybody out there could actually verify that the floppy
: : drive is dead from the above information?
: : TIA!
: : John Kinsella, Sys Admin | UC Davis Math Department
: John, have you run the Reference Disk to verify the SetUp configuration?
: If so, and your drive A: is properly defined, your problem is likely to
: be either a bad floppy disk drive(s) or the floppy drive controller
: (FDC). Unless you can lay your hands on a known good FDD and swap it
: into the A: slot, then the FDC is also suspect.
: In the event you require replacement FDD's, I represent a small
: entrepreneurial firm, Precision Peripherals, Inc. We specialize in the
: sale of genuine IBM PS/2 FDD's that we thoroughly refurbish (i.e. clean,
: lube and align to IBM specs). And we sell them for a small fraction of
: what IBM would charge - our price is $65 each for the FDD I think your
: Model 60 uses and we warrant them for 6 months (assuming the FDD is IBM
: P/N 90X6766 or equivalent). FYI, IBM Parts (1/800/388-7080) charges a
: staggering $329 for this P/N (albeit brand-new) and provides a 90 day
: warranty. For your convenience and protection, we take Visa & M/C.
: Feel free to contact me, John, if I can help you in any way. I'm always
: glad to offer help with PS/2 FDD questions! For more detailed info, we
: have a posting in biz.comp.hardware if you happen to receive that Newsgroup.
: Larry Ovshak
: Precision Peripherals, Inc.
: Phone: 612/571-2905
He might also try a special driver update that deals with floppy/harddrive
problems (and other nuisances) called Dasddrvr.sys. There is a version
of it already on many refdisks, but the update takes care of problems since
the original was released. It is found at ftp.pcco.ibm.com in the
/pub/system_specific directory as ps2updat.dsk. He will also need to
download Ldf.com, found in the /pub/utils directory (and probably
elsewhere) that self-decompresses to extract the program Loaddskf.exe,
which translates *.dsk files to "disk images", essentially recreating
the intended program to the harddrive or floppy. Typing loaddskf at the
c: prompt in the directory the file exists will prompt you for and alert
you to options and syntax.
Dasddrvr.sys is required on PS/2 models 50, 60 and 80 running any Dos
operating systems. It is not required on the 25, 30, 50Z, 70, or if you
are running OS/2 on any of the machines. If you do try and install it on
a machine that doesn't require it then it will not install and won't
return an error message. (Preceeding and following taken an IBM error
code list)
There are five reasons for this particular device driver.
1. Intermittent read failures on 720K original application software
diskettes.
2. Intermittent 'Not ready' or 'General Failure' message on the floppy
or fixed drives.
3. Format fails on multiple formats of 3.5 inch diskettes. Get 'Track 0
bad or invalid media' message.
4. False 301 and 8602 error messages when the machine is turned on and
off quickly.
5. Loss of time or 162/163 error messages. this is the main reason for
installing the driver.
Probably the latest version of dasddrvr.sys can be found on the most
recent refdisk for his mod 60. Dasddrvr.sys needs to be installed as
a device driver in your config.sys file. I would first copy dasddrvr.sys
to my Dos subdirectory so it's on the path. Then, I would simply add the
following line to my config.sys file: (on the first line)
Device=c:\dos\dasddrvr.sys
As mentioned above, if the driver isn't needed, it doesn't install and
uses no memory. So, couldn't hurt.
Solution #3
Not Rated (0)
Brad
Brad - usenet poster
Rating: 0%, 0 votes
: c:\ : Insert new diskette for drive A:
: Invalid parameter
: c:\ :
: TIA!
Larry Ovshak
Phone: 612/571-2905
Solution #4
Not Rated (0)
Bouncy
Bouncy - usenet poster
Rating: 0%, 0 votes
<snip
Found out what was wrong! Basically, the machines had been left powered off
for too long probably. As a result, the cmos battery and data had drained
out, and the machines didn't have cmos settings for the floppy drive. The
strange thing, I found out, is that I could read and write to the drive, but
I couldn't format it.
Anyways, thanks goes out to:
(Edson Gin)
(Aron Eisenpress)
John
­__
Can you Help with these Floppy Drives problems?
Floppy Drives
applications of linear...
1. if a rectangle has a length... Answer This...
Floppy Drives
floppy drive
The floppy drive will not open... Answer This...
Floppy Drives
word problems regarding a...
If you earned an average of... Answer This...
Floppy Drives
maths linear equations
A positive number is 5 times... Answer This...
Floppy Drives
konica floppy photo disks
I have photos on the old konica... Answer This...
Repair Service
Find Floppy Drive Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
