-   Unit is a couple of years old - but only used once last fall.
Same thing - plug in, red light is on,
but nothing happening - no heat, etc.
Frustrating since it did work so nice last fall.-   stevennu
Check the plug and then remove the bottom plate and look to see if the wires are still connected. Check another outlet to make sure a breaker wasn't tripped.
no more power when plugged in no red light on, no heat, outlet working, manual says theres a reset...
(More)
no more power when plugged in no red light on, no heat, outlet working, manual says theres a reset button but i can not seem to find it, how can i fix or where is reset button located
we received this as a gift, and put it on a shelf, then figuring to use it now that an old fryer...
(More)
we received this as a gift, and put it on a shelf, then figuring to use it now that an old fryer quit, took it out of the box, only to discover that only the fryer was in the box, no manual, no 'serving spoon', only the fryer. nan you help us out? Kevin Henderson 121 W. 9th Halstead, KS 67056 316-835-2886 kldlhenderson@att.net
Purchased fryer in Dec of last year and it has stopped working already. Will not heat up. It does...
(More)
Purchased fryer in Dec of last year and it has stopped working already. Will not heat up. It does get somewhat warm but it will not heat to full temp. The store I purchased it at no longer carries it or I would exchange it. How do we fix the problem?
