Question about Refrigerators
Kelvinator model N641n
The compressor all the time is working but does not stop.
I have a kelvinator refrigerator, top-mount type model # SKNT 16E.
220V, 1-phase, Defrost amps 1.9, Watts 575,
Gross/Liters 453/396
I have replaced new door gasket.
Freezer gasket is in very condition.
Compressor drawing 3.15amps.
  1. Question is Compressor is working 8 minutes and remains off for 3 minutes.This cycle is happening from some days.Thermostat and timers seem to be ok. Do i need to change Overload cut-out at the compressor or not....please suggest.
masood
masbimed@yahoo.com
Posted on Feb 18, 2009
Kelvinator aircon, model R225B wiring diagram needed, please help!
call a technician as it most likely is a start/run capacitor for the compressor or an outside control board problem
Jan 09, 2017 | Kelvinator Refrigerators
Kelvinator 1205 TF compressor not starting
you should look for the man to check your refriginator and look for your model on google and try to check what is the problem
I recommending registering to the best site for earning money online http://www.clixsense.com/?8516905 I recently found and please do that I you find me helpful hahah
GOOD LUCK
Jan 03, 2016 | Kelvinator Refrigerators
Why is gas leaking from my kelvinator fridge
probably a hole in the evaporator
But I have to ask what is it you are seeing as the gas is not visible to the eye
is it a mist that you see on opening the door or has the compressor stopped working
Aug 22, 2015 | Kelvinator Refrigerators
I have kelvinator fridge it doesn't cool in both compartment we replaced the compressor il coold down for only 3dayes then returned back to hot state
is the condenser fan running back there?also did you clean out the condenser coil?usually when the middle strip gets hot the coil is filled with dust or the fan where the compressor is isn't running.the condenser fan keeps the compressor cool and all the heat from the machine escapes out through the condenser coil.check this,also the start device could be bad on the compressor,send model number next time you write so whoever helps you can look up your machine.hope this info helps you out.
Sep 15, 2012 | Kelvinator Refrigerators
Freezer won't get below 30 degrees at the highest setting, food won't freeze.
Possible that the gas pressure is down to low gas or leak on the system. Also it can be due to faulty thermostat, faulty compressor if the compressor is working all the time and reaching the set temperature. Also if the compressor is not cutting off this must be a suspect.
Aug 24, 2011 | Kelvinator Freezers
My kelvinator upright freezer stopped freezing and it just kicks on and kicks right back of what could be wrong with it?
Start Relay/Overload or Compressor is bad. A bad compressor can make a Start Relay/Overload go bad but the only way to find out if compressor or Start Relay/Overload is bad is to replace the Start Relay/Overload if it starts and stays running you fixed it if Prob. returns in a week or so or if you have the same Prob. after replacing the relay the compressor is bad.
May 20, 2010 | GE 13.7 cu. ft. General Electric Upright...
I have an airconditioner a Kelvinator KSR20C Split system
Your condensor fan motor has more than likely gone out. This fan should run at all times when the unit is on. Since the fan isn't working then the motor must have gone out.
Dave
Nov 16, 2009 | GE Zoneline AZ38H12DAD Split System Air...
Refrigerators Logo
102 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
