Excel 2007 Home Office and Student - When I try to put the curser in a cell to highlight the cell, 4 cells light up - I cannot highlight only 1 cell at a time. It's like it's stuck on a 4-cell-at-a-time curser point. Have you ever seen this?
  • 8 more comments
  • kathysiess Feb 18, 2009
    Excel 2007 Home Office and Student - When I try to put the curser in a cell to highlight the cell, 4 cells light up - I cannot highlight only 1 cell at a time. It's like it's stuck on a 4-cell-at-a-time curser point. Have you ever seen this? If I reinstall Excel, will I lose my document?
    Excel 2007 Home Office and Student - When I try to put the curser in a cell to highlight the cell, 4 cells light up - I cannot highlight only 1 cell at a time. It's like it's stuck on a 4-cell-at-a-time curser point. Have you ever seen this? I am on a Sony Vasio laptop.
    I tried to hold Ctrl and clicked the cell and it put the curser in the 1st cell, but the 3 former other cells are highlighted with a light blue shading as if they were also being populated.
    Nope. I'm trying to change the color of a single cell and I changes the color of the other 4 adjacent cells - it will not let me change the color for a single cell.
    How do I reinstall Excel if I purchased it and installed it online?
    I'm trying to highlight cell 19-E in a spreadsheet, and when I click the cell, 19E through 23E are shaded.
    Nope - didn't fix it. I'm using a laptop touch pad, and it seems to be misreading my pressure of my click. If I keep barely touching the single cell (like 20 times), eventually it will finally just click into that single cell. Somethings not right. I was away from the computer for 5 days and left several documents open and my email account open. Could this be an issue a hard boot would resolve?
    Nope, F8 didn't fix the problem.
  • Raviteja Mopidevi
    Raviteja Mopidevi May 11, 2010
    Hello there.
    I understand that in Ms Excel 2007 when you try to highlight one cell , 4 cells are highlighted.
    You may do the following troubleshooting steps.
    1)This could be a problem with the software codes( that is called bugs in the software). Updating office files may solve the issue.
    For updating please go through this website.
    http://office.microsoft.com/en-us/downlo...
    Click on the above link or copy and paste it in a address bar of a web browser.
    2) If the above steps do not solve the issue. You can uninstall and reinstall the Microsoft Office. to do this follow below steps.
    a) For uninstalling go to control panel and add remove programs. click on office and uninstall it.
    b) for reinstalling use the CD or DVD which you got. or use recovery partition to reinstall.
    Thank you for giving me this wonderful opportunity to assist you. For any further clarifications please comment.
  • 217 Answers
Have you tried working on a entirely new worksheet????...to me it doesn't seem to be an issue with Excel it seems to be the delayed response of the touch pad please try an entirely new worksheet and respond.
Posted on Feb 18, 2009
    Scholar:
  • 52 Answers
There is a known issue since excel 2003 also referred to as Ghosting, however in version 2007 it seems to have turned into an annoying bug that Microsoft does not have a final solution for yet.
Clicking near the top of the cells seems to select the single cell. Clicking towards the bottom of the cell triggers the "bug".
Reinstallation may or may not solve your problem since this is a bug in the way excel works. Give it a go, but if it does not work there are numerous workarounds. Such as:
1. Try tapping the wheel of scroll mouse, if applicable.
2. Try changing the page view from Page Layout to any other View option: View tab > Normal
3. Close the spreadsheet, open again and see if behavior still exists.
4. Close Excel, open the spreadsheet and see if behavior still exists.
5. If cell still selects multiple cells, up keyboard up/down/left/right arrows to navigate away and then back to cell, then click in the formula bar to edit (aka in the formula bar you see C1:C4, click on C1 it should auto jump you to that one cell only)
6. If it says EXT or Extend Selection in the bottom left corner of Excel, then it is in Extended mode - try tapping the F8 key once
7. Try zooming out then clicking the cell selection again: View tab > Zoom > Edit % in Custom field > Click OK
Hope one of those helps.
  • 423 Answers
You probably have EXTEND turned on. Try ths. Select a cell and hit the F8 key. Now try to select a cell 3 rows away from the originally selected cell. If EXTEND is on, then the selection will now select all cells in that range. Now hit the F8 key again. This should turn it off. Try it out and let me know. Either way, if you hit the F8 key twice, it should turn EXTEND off.
  • 1 more comment
  • Rob
    Rob Feb 18, 2009
    Where did you download Excel from? Did you download the installer? If you did, did you save the installer first, then install? You can try and reinstall the program, but that may or maynot fix your problem. If you don't have the installer, go back to where you downloaded if from and see if you can re-download it. I think it's a glitch, I have Excel 07 and I'm happy with it.
  • Rob
    Rob Feb 18, 2009
    Try this. Plug in a USB mouse. Do you have the same problem selecting cells? If not, then I would highly suspect your touchpad.
  • Rob
    Rob Feb 25, 2009
    Hi Kathy, Did you try my suggestion of plugging in a usb mouse to see if it worked the same or not? That way you can rule out the touchpad consideration. Let me know.
    Rob
  • 495 Answers
Iv'e found an answer to this as I was having this trouble on a user's PC that I was supporting at work. Below is the fix.
Click on the Circle (top left "Ribbon")
Click Excel Options bottom of the window
Click Advanced
And scroll to the bottom.
Uncheck under Lotus Compatibility -> Transition navigation keys
I checked it and it wouldn't let me use CTRL + SHIFT + Down or Up arrows. Then unchecked it and it works fine now.
  • Manoj Rout
    Manoj Rout Feb 18, 2009
    Dont re-install excel.. it wont help you much.
  • Manoj Rout
    Yeah, you can try that option of hard rebooting.
  • 74 Answers
Excel doesn't like to highlight only one. you should try do what you are doing as if its not happening.
    Brigadier General:
  • 3,614 Answers
Did you mean you want to make a selection of the cells to be highlighted or selected?
be more specific on this, kindly input an example on which cell range you want to select.
thanks
  • micromaster
    micromaster Feb 18, 2009
    re-installing will not erased your saved document. it will remain on your documents folder. better to reinstall first excel.,
    let me know
  • micromaster
    make sure that the cell you selected was not merged to the other cell.
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 75 Answers
Hi there try to press control den click the cell you want to highlight hope this will help you
  • 126 Answers
Looks like it may be that any button on your keyboard has been stuck to its place. check all buttons whether they are on right place or not. if they are on right place then re install the software
dont forget to rate my solution
thankyou
  • vishal garg
    vishal garg Feb 19, 2009
    ey buddy,
    you are wasting your time here. You will find nothing here if it was that you can find
    answer here till now should have got the answer
    stop wasting time
    stop wasting time buddy
    regards
  • 44 Answers
Hi!
Is there some key pressed in the keyboard, maybe it is something wrong with the keyboard, Check the Ctrl and Shift keys.
  • BOZAPE
    BOZAPE Feb 18, 2009
    If you use your keyboard to navigate through the cell can you do that ok?
  • 679 Answers
Try to reinstall excel again.
  • rockfixya
    rockfixya Feb 18, 2009
    Here is a link for more information..... with images>>
    (check that might be you do some wrong with the options)
    http://www.timeatlas.com/mos/5_Minute_Ti...
    let me know for further assistance.
    Thanks
  • rockfixya
    NO.. you will not Lose any SAVED document.
How do I get horizontal lines on Microsoft Excel 2010?
Highlight the cells containing your words, right-click and select "Format Cells", then go to the "Borders" tab on the dialog that appears. You can do all sorts of neat stuff there. For your purposes, pick a line weight, then click the sample box's bottom line.
Aug 12, 2014 | Microsoft Office 2010 Home And Student...
I need microsoft word 2007 version, it is easier to use
If your only after with word then i wold suggest you to get Office Home and Student cheaper and it has only 4 applications (excel, powerpoint,word and onenote) http://office.microsoft.com/en-us/home-and-student/
Jul 06, 2011 | Microsoft Office Professional 2007 Full...
Is it possible to modify a cell content without deleting everything in ms excel?
Hi There.
Yes - it is possible to modify the content of a cell without deleting everything.
Place your curser in the cell without writing or doing anything.
You will now be able to se the content of the cell in the upper row - same place where you give in formular etc.. Here you can edit the content of the cell - a part of the text or formular without loosing everything.
Feb 02, 2011 | Microsoft Excel 2007 Home and Student...
Are there any free product keys for office 2007
Microsoft Office 2007 Professional
XC84W-M642D-2QDWY-YTKMM-RWJQW OR TCCMP-PXGHB-3TR88-6WDCX-2HDBD
OR H36BT-QFYMQ-FCFC3-KYQ69-G67PT
T3PVR-XX42X-T49DW-WGBG6-9FT73 OR C3T4B-8MD24-46K4H-6XPPX-VD6YD
OR DM6GQ-HM9CG-HCVY9-T3C74-GVHVW
MS Office(Home and Student) 2007: GHJGD-TWT9Y-G7H42-FWDJK-3G6KW
MS Office(Home and Student) 2007: KRBWK-TVGBX-3KQG4-H7WXG-KQGKM
Microsoft Office Home & Student 2007: JWR9T-HFR92-74RQ7-3FRMB-CY676
Norton Antivirus 2008:VGH96-FY8HM-443GH-F4Y36-PYH98
Microsoft Office Home & Student 2007: TW6JJ-D28JW-B7KRM-44W66-MGVGY
Microsoft Office 2007 Home and Student: B4MKP-KP9YP-7TBQ4-7T4XF-MTGWY
Microsoft Office 2007 Home and Student: DDY79-433JV-2RXGX-MQFQP-PFDH8
Microsoft Office Home and Student 2007: DDY79-433JV-2RXGX-MQFQP-PFDH8
Microsoft Office Home and Student 2007: B4MKP-KP9YP-7TBQ4-7T4XF-MTGWY
Microsoft Office Home and Student 2007: KGFVY-7733B-8WCK9-KTG64-BC7D8
Microsoft Office Small Business 2007: S/N: CKMPB-6B4QT-MG4C6-2VH4C-RDD43 Or HTPWX-FR6J8-2WBCQ-T63JR-3M8PD
A Few Activation Keys for Office 2007 Home and Student.
More on the Way for different MS Products
Visit us at thedeadlyghost dot com.
before visit this site try the following key.
1-HBC66-D6YR7-CRP7H-T8VP4-99PMW
2-QXMDH-CRYFM-QFR87-HB783-T7RFQ
3-P37JV-FYJ32-YHH3T-KX7GX-7BJY3
4-HRMGX-K8WKJ-7FBGW-FTBCY-DWCM3
5-RCFMT-WFT7M-R779R-BJQMB-M2KWD
6-T9HJX-4C3BM-MG2R6-WC933-RCBRT
7-BTT7P-9HBFP-6QHM7-RFHDV-X8XWG
8-HWMMV-7H4DT-J2PJ6-YB8X4-VQCM6
9-JM2QC-KMVTP-VR8GV-HJRKQ-YWXWG
10-BHD34-K6BT7-T6PXP-BXKT4-X3G8D
11-DDH8T-C2JGD-G6MWW-6CYBV-BDTB6
If this answer helpful please vote me. Good luck.
Thanks for using FixYa
Jan 13, 2011 | Computers & Internet
Problem Printing Excel file
You may find it easier to follow the steps if you print this article first. .... Step 4: Remove any remaining 2007 Microsoft Office installation files .... Microsoft Office Standard 2007; Microsoft Office Home and Student 2007; Microsoft Office Basic 2007; Microsoft Office Access 2007; Microsoft Office Excel 2007 ...
support.microsoft.com/kb/928218
Jul 20, 2010 | Microsoft Office Home and Student 2007...
Where can i get the key for all the microsoft? like excel and word? is it the same key for all?
if you buy a license for the office suite, it will only ask for the product key one time and it will unlock word, outlook, excel, powerpoint, and access. if you purchase the professional version, this will include publisher and any other office suite software.
Jul 11, 2009 | Microsoft Office Professional 2007 Full...
Product key for office 07
RATE THIS SOLUTION ACCORDINGLY
Jan 12, 2009 | Microsoft Office Professional 2007 Full...
Letter
Try one of these cd keys
CDKEY:
1. TT3M8-H3469-V89G6-8FWK7-D3Q9Q
2. V896H-YQG24-DDH4P-C9DYJ-KQVR6
3. XC84W-M642D-2QDWY-YTKMM-RWJQW
4. QWJPF-2W3DM-V2X3F-9H7WH-CFCVW
5. KGFVY-7733B-8WCK9-KTG64-BC7D8
6. K3GFK-PBHXT-DG3F2-VXY6B-MKQ6B
If these are not working then tell me about ur office2007 whether it is home edition or student edition or enterprise or professional edition, i will send u the particular key.
Hey! dont forget 2 rate the solution
Apr 14, 2008 | Microsoft Office Professional 2007 Full...
Computers & Internet Logo
22 people viewed this question
David Payne
David Payne
