Question about NEC AccuSync LCD52V-BK (Black) Monitor
Would like to be able to switch from normal scan to reverse scan
We have the NEC AccuSync LCD52v-BK as part of the prompter setup. We want to feed it and two other computer monitors from a VGA splitterbox. The other two monitors are only for the personell to look at when they are not reading off the camera prompter so they can follow along without looking directly at the camera. Since the prompter software can send out normal left-to-right scan to all monitors we need to reverse the feed, right-to-left, to the prompter screen with the mirror. Can we install a switch on the above mentioned monitor to be able to change the scan as needed?
jerryg50
  • 1667 Answers
SOURCE: NEC AccuSync 120 Frequency setting
This is the maximum resolution for this monitor:
1600 x 1200 / 76 Hz
Even if you lower the resolution to the monitor, as I can see that you want to do, the maximum refresh rate is still going to be 76 Hz. If you were able to force the monitor to scan a greater field rate and its protection circuits do not shut it down, the monitor will be damaged.
Your display card is most likely limited also, unless you went out and bought a very high end card.
When using a different resolution that what the specs on the monitor indicates as its native mode, this will reduce the quality of the results displayed.
Specs for this monitor:
http://www.superwarehouse.com/NEC_AccuSync_120-BK_Black_21_CRT_Monitor/AS120-BK/ps/120193
Jerry G.
Posted on Apr 24, 2008
jemmyrash
  • 180 Answers
SOURCE: No picture; power LED blinking amber/green 2-2-2-2...
You can TRY to look for cold solder at the board esp popwer section.
IrishDruid
  • 2712 Answers
SOURCE: nec monitor LCD1560V
Try changing the resolution of the screen. Right click on an empty area of the desktop and select properties. Now choose the Settings tab and try adjusting the slider for resolution and click on APPLY. The screen will go blank for a few seconds and will show up in the new resolution. If you find it satisfactory, click OK to keep it, or click NO to go back and try a different resolution.
You can also go into Control Panel and check the monitor properties from there.
Hope that helps!
Posted on Oct 21, 2008
SOURCE: NEC flat screen monitor reset screen keeps popping up.
Call 800 836 0655 and ask for directions from tech support.
Posted on Nov 18, 2008
SOURCE: DISPLAY STAYS FOR 2 SECOND ON NEC MULTISYNC LCD 1760V
the inverter board has a problem. this is the small pcb that sends high volts to the backlights you will need to change it
Posted on Dec 03, 2008
I see ny wallpaper, but I cannot see any icons that are located all the way to the left or the start button at the bottom.
your computer is infected by virus, you can repair it by system restore, boot your computer to save mode by pressing f8 continously on system start up, select safe mode after it is start you will be prompt by notice on what you want to do select the option for system restore then select for a previous date for restoring.
Jul 27, 2011 | NEC AccuSync LCD52V-BK (Black) Monitor
I have a NEC AccuSync LCD5V monitor and the picture on the screen will not extend over the whole screen....the right side has the picture re starting by about an inch
Windows 7 & Vista:
Right Click on your desktop and go to Personalization. Click on Desktop Background at the Bottom of the screen. On the Picture Position drop down menu, click Stretch and save changes.
Windows XP:
Right Click on the Desktop and click Properties. Go to the Desktop Tab. Select stretch from the drop down menu. Apply.
Please Rate my answer. Thank you.
Apr 19, 2011 | NEC AccuSync LCD5V-bk (Black) 15 in. Flat...
The problem is that it is not Degaussing
1. You may be able to obtain a schematic at this site if you do a Google search. ESI
Troubleshooting a degaussing circuit is very tedious but good luck!
I hope this helps.
Apr 22, 2010 | NEC AccuSync AS120-BK (Black) Monitor
I have a nec LCD2070nx Power light is on
Hi:
Your monitor has a problem on its inverter board. It is an electronic component failure, and often it cost's more to fix it than to buy a new LCD monitor .
Nov 23, 2009 | NEC AccuSync LCD71VM 17" LCD Monitor
Apr 24, 2008 | NEC AccuSync 120 (White) 21" CRT Monitor
1600 x 1200 / 76 Hz
Jerry G.
Apr 24, 2008 | NEC-Mitsubishi Nec Display Solutions...
NEC Monitor LCD1700V
I had a similar problem with a NEC LCD1935, and I traced it to the inverter board which was a Lien Chang LI-2190 ... it seems that common problems with this type of board are bad solder joints due to the temp. cycling, or blown capacitors, but I was too lazy to resolder everything so I just disconnected the BL signal line that goes between the main board and the inverter board, and this solved the problem. In my display it was a green line, marked BL on the inverter board -- I removed it from the connector and just taped it off.  I'm guessing that this is a blanking signal that the invertor uses to signal to the main board there is an overcurrent situation and that the display should be blanked/shutdown.
I'm certain that there are still problems with the inverter and it might go again, but at least I have a working monitor for the time being.
Caveat emptor.
Oct 26, 2007 | NEC AccuSync LCD71VM 17" LCD Monitor
NEC AccuSync LCD52V-BK (Black) Monitor Logo
187 people viewed this question
Top NEC Computers & Internet Experts
Martin Murray
Are you a NEC Computer and Internet Expert? Answer questions, earn points and help others
