Question about Olevia 237T 37 in. LCD TV
Blue power light is on but tv will not come on olevia 237T11
Fuse is good control board is new
  • stemah Mar 07, 2009
    No picture or sound. When the set is turned on there is a blue flash on the screen, but no picture or sound.
I know this post was a while ago, but I stumbled upon a solution to my tv just recently. I don't know if this will work for everyone's tv, but I find it hard to believe that this would only fix my tv with the same issue.
I opened up my tv and found that the placement for the connection for the power cord is poorly designed. For one it is very loose. Two, I don't know much about circuit boards but the connector has 5 prongs. Two of which are part of the same piece to both, I think, to anchor it down and ground it (it looks like it's part of the actual ground wire.) and the other three which I assume power the board. Those three are not completely soldered on completely e.g. they have holes in the soldering. The last thing I noticed is the ground wire is crossing the board and touching one of the coils.
As my tv got worse it started making a "short" sound. When I opened it up, I removed the connector and insulated the wire more. Also, I anchored it down tighter using the two prong piece (just made it tighter by pushing it down more and folding the prongs against the board and soldering it). Last, I re-soldered the 3 prongs, completely covering them. Put the tv back together and viola...it came back on and no problems.
I hope this help and I hope this makes it around to all the people who have this tv. It"s not a bad tv just a poorly designed board.
-Falchemist
Posted on Jul 18, 2010
I have a Olevia lt37hvs, When i plug it in the blue(olevia)light comes on then goes off and the screen will be blue for 5-6 second then go black for 1-2 seconds then screen goes blue again and it just...
tried to connect again the supply for main board and disconnect the supply for the inverter board of back light. and turn on the tv, if the indicator stay the inventer board was the cause of voltage drop at the power supply board.
Sep 08, 2012 | Olevia LT37HVS 37 in. LCD HDTV
Olevia LCD HDTV 242tfhd will not turn on.
See solution above (from John Adams) if that doesn't work it may be the power board which is available on ebay for $69 incl. shipping. Good luck.
Mar 09, 2012 | Syntax-Brillian Olevia 242TFHD 42 in. LCD...
What is the price of the main circuit?
Here is a link to the complete parts list for the OLEVIA 237T11 television:
http://www.shopjimmy.com/olevia-237-t11
And here is the direct link to the MAIN CIRCUIT BOARD for that model:
http://www.shopjimmy.com/olevia-sc0-p519201gmi4-main-board.htm
Unfortunately the above supplier appears to be currently out of stock for that particular part, although this should give you an approximate idea of what the standard asking price is for replacing that circuit board ($160 US).
Just keep searching the internet and on EBay for the exact circuit board PART NUMBER listed at the above site and you may find one somewhere else for less. The online inventory changes every day so you just have to keep checking back often.
Good luck.
Joe.
Nov 25, 2011 | Olevia 237T 37 in. LCD TV
My Olevia 242TFHD will not turn on. The blue light goes off but the tv does not power on. If I unplug it and plug it back in the blue light will come back on but when I try to power it on it never turns on
The tv have a Tuner board problems,this is the board,that take in the broscasting signal cable.Tries unplug,replug about an hour later.The tv should reset it self and work.Not than tries websites like Shopjimmy.com,Ebay.com to buy a refurbish Tuner board for the replacement.
Jul 08, 2010 | Syntax-Brillian Olevia 242TFHD 42 in. LCD...
My 42 inch olevia 242fhd-t11 tv just shut off and will not come back on.. The blue led light will not come on either... Also was having intermittent sound issues for the last couple of days prior to it not...
I just repaired this identical problem on the same model TV. You have a bad power supply (also known as an SMPS). The board is model FSP271-4F02, and is about $75. Unlike the main board for this TV, you can find the power board relatively easily. Try shopjimmy, for example. Replacing the board isn't too difficult if you have a reasonable mechanical ability, have some tools, and are careful.
Jun 12, 2010 | Olevia LT42HVi 42 in. LCD Television
Olevia 747i won't turn on, no blue led light? Help!
I would start with the power supply. Possibly a fuse. 9 times out of ten though if a fuse goes, something inside the set is causing the fuse to blow.
Oct 13, 2009 | Olevia LT42HVi 42 in. LCD Television
No picture
LCD TV TroubleshootingThe defective LCD TV may have the following common symptoms:
Symptom: No picture on screen but LCD TV still has sound.
Solutions: The problem is cause by defective inverter. Replacing ivnerter will solve hte problem. Symptom: Screen flash on and off between 1/2 to a few seconds, but power indicate light stays on and TV still has sound.
Solutions: The problem is cause by defective inverter. Symptom: Blue Screen but no picture
Solutions: The problem is cause by defective Main Board(AD Board). In some cases, this problem may cause by the defective Screen Controller board. Thsi board is mounting on teh back of LCD TV Scree. Symptom: Power light stays on but no display and sound
Solutions: The problem is cause by defective Main Board(AD Board) or Power supply board. Symptom: No Power or Power indicate light does not lits
Solutions: The problem could cause either by defective Power supply board or defective Main Board(AD Board). Symptom: Screen is half dim and half bright
Solutions: The problem is cause by defective LCD Panel.It needs to be replace.
This is a power supply problem. Try to check the fuses ,fusable resistor ,capacitor and transistor in power supply board.
Hope it may help you;
Regards,
VOTIT
Oct 01, 2008 | Olevia LT37HVS 37 in. LCD HDTV
Olevia 537H-B12 Won't Power ON
try looking at the board inside the TV for bulged capacitors see polaroid thread. this is the problem on the polaroid could be the same here.
Sep 16, 2008 | Syntax Olevia 537H Television
Olevia 237T 37 in. LCD TV Logo
337 people viewed this question
Top Olevia Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you an Olevia Televison and Video Expert? Answer questions, earn points and help others
