Question about Philips 32PFL7332D 32 in. LCD HDTV
The color on the screen goes bad and the tv shuts itself off.
    Problem Solver:
Defective the picture Tube or leakage CRT
Posted on Feb 18, 2009
Keeps reseting itself
Dude check your A/V or HDMI cables or whatever you use. HDMI cables can be tricky. Make sure that the different shades of color are matched up exactly. Ex: make sure light blue isn't plugged into the dark blue slot. it may not appear as if it matters but trust me it does.
Jan 01, 2014 | Sanyo Dp32640
My sony kp-51ws510 color rear video projector tv when i turn it on it stays on for abt five seconds and then turns off and also the timer and standby light is flashing red
this model did have problems with bad picture tubes---screen goes bright red,green,blue and set shuts down.
set also does this to protect itself---when fails look to see if specific sequence of blinks
Apr 17, 2012 | Televison & Video
Tv started to shut off here and there, then the
Hi,samsung has 3 major failures.The 1st one is the lamp, which averages 6000-8000 hrs 2-4 yrs.When it's about to go bad it shuts off and on or image won't come at all.You can find your part here:http://www.discount-merchant.com/SearchResults.asp?Search=BP9601472A Another problem that causes tv to shut off is the ballast,which is the board that powers the lamp.It makes clicking sounds and will cause pic to flicker.The other problem is the color wheel .The color wheel is a rotating disc that has a gamma of colors it spins at high rpms.The light of the lamp goes through it to create the colors on your tv.When it starts to go bad you will get color distortion ,black and white picture and sometimes you will hear humming noises.Have a bless one!
Apr 12, 2010 | Samsung HL-S5086W 50" HDTV
The TV will work for a while and then the picture will get lines in it and then the tv will shut itself off.
This Is IK shutdown, this may be from a bad picture tube going bad, or excessive high voltage, If the screen turns a certain color right before shut down then thats the tube going bad, It will either be RED/GRN/BLU screen right before shutdown, the lines are scan lines. If a tube needs replacing then it might be hard to get as CRT manufactures are not making many any more. You can contact http://www.VDC.com for used or remanufactured one.
Dec 09, 2009 | Mitsubishi WS-65809 65" Rear Projection...
My tv when turned on goes to a black screen with 3 color strips of lines going across the picture then goes to a snowy picture but only shows on half the screen and then shuts off
This sounds like a vertical problem. It could be just a bad solder joint or it could be a IC that has failed and surrounding componets. Hope this is helpful.
Nov 30, 2009 | Philips 27PT5445 27" TV
Screen goes from color to black and white
replace the cable with a new one it should be fine after that
Oct 26, 2017 | RCA Televison & Video
Samsung DLP HL-R5667W
Your set has a defective color wheel. This is the noise you hear and why the set wont even come on now. The colors were bleeding because the color wheel was getting stuck and when you hit the set you unstuck it. You need to call a tech to put in a color wheel the part is about 100 dollars plus labor.
Feb 05, 2008 | Televison & Video
Color Wheel problem.. to generate colors on a dlp the light is shine through a motorized wheel. that has different color filters on it. this is a motor and anthing that moves will eventally wear out. i just replaced the color wheel on a samsung today. standard for this to go out in about that time. i believed our shop charged 250 to put a new one in. Willie@FORDTV.COM
Sep 23, 2007 | Samsung DLP HL-P4663W 46" Rear Projection...
Philips 32PFL7332D 32 in. LCD HDTV Logo
98 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
