Question about Toshiba Satellite Pro 4600 Notebook
Unable to format
Carnt access bios so i can update to xp
  • Ryan Wendell May 11, 2010
    Please explain more. Do you receive an error?
    Try this.
    Put the windows xp cd in the cd drive restart and when it loads up you should be able to update it.
  • 75 Answers
You must boot from the xp disc as it boots up just keep pressing F8 this normally will bring up boot order for you to choose cd to boot from
Posted on Feb 18, 2009
Bios update version for hp a1420n
keep the flash drive in hand. try to install xp. while install it was asking for bios update and ask for press f8 for bios update and insert pen drive and select the path it will automatically update the bios and start installing
Apr 03, 2012 | HP Pavilion a1420n PC Desktop
I try to format my pc 1st time its operating system is windows xp i have inserted a xp cd ..... and click reboot but no change occur and i am also unable to format all other drives which donot have os...
First of all does the cd boot into the xp installer. If not the the setting in the Bios would be to boot from HardDisk first. Get into bios by the appropriate key on boot and change the boot order to cd/dvd first and then hdd. Now save settings and restart the system and the xp cd should boot up and you will be able to install xp. Be careful as you may delete all data on the hdd.
Some bios use the del or f2 key to enter, see press __ to enter setting's or bios.In that goto the boot order and change appropriately.
If xp is already installed then if other drives are not acessing saying not formatted then the easy fix would be to right click on non formatted drive and click on format. Then you will be able to access it. Do same for all other drives.
Jan 15, 2011 | Computers & Internet
How do i restore bk to factory settings on a emachines 130 pc runnind windows xp as i carnt load msn onto it or anythink like that i brought the pc second hand and want to start from fresh with it
If you buy a copy of XP with the service pack, load the XP system CD and let it format and reset the hard drive. When it has loaded XP, install the required drivers and then install Service Pack 3, that will allow you to download the latest Microsoft updates and there you go, a new system.
Dec 15, 2010 | Computers & Internet
P4m800pro-m v20 random reset I have windows 7. I
Your not going to be able to update the BIOS without having XP installed on the computer.
I had the same problem myself as a motherboard i had would not update with Win 7 installed.
If you have a spare hard drive and an XP install disk then i recommend installing XP on that and then download the exe BIOS update file and run it from within Windows to update the BIOS.
After that just turn the PC off, put back your Win 7 hard drive and your good to go.
Regards.
Jul 02, 2010 | VIA ECS PM800-M2 PM800 P4FSB 800 Supports...
UNABLE TO BOOT FROM WINDOWS XP
First Make sure your cd/dvd rom detected in bios.
For that First open cpu cabinet refix power cable and ide cable to harddisk.
Then check your bootable recovery disk and cd/dvd rom working fine.
When you power up the computer press F1 or F2 or "del" key to enter in bios .
Then go to boot option and set first boot device as your cd/dvd rom then save settings and exit.
Then it boot with disk .
If still not boot then there may be some issue with cd/dvd rom or bootable disk.
Let me know if you need more assistance.
Thanks.
Oct 13, 2009 | Computers & Internet
I have a cer apire 7520 which had vista on, But
Need to change your boot sequence so that the computer bios will run the cd at start up When your computer starts you will see it says something like press F12 for setup or press ESC. it veries by computer.
Sep 07, 2009 | Aspire Acer 7520-5324 Laptop
I am unable to install win Xp. when trying to boot from a cd to install fresh win xp ser. 2. system reboot after copying few installation files. The Bios set up shows the Sata Hard Drive but unable to load...
your HDD may be bad. I have had a number of HDD that appear fine in the BIOS but won't format either via the install disk or separately via a Linux boot disc.(You can somtimes hear them clicking on and off [seeking])
If you are mad keen on the drive, then D/L 'Hirens Boot Disc' and boot into the DOS mode (it also has a Mini XP mode).and use the HDD format utlity 'killdisk'. This will remove anything on the drive, format it and set it up ready for a fresh install.
If Hirens Boot Disk can't see the SATA drive then its stuffed.. for sure..
Apr 16, 2009 | ASUS P5LD2-VM Motherboard
Windows Xp says all usb ports are working correctly but unable to
Hi! and Welcome to Fixya,
just suggesting, in my own view, of how to troubleshoot USB problem.
BIOS Setup:
  • restart your PC
  • in booting process, press F2 or Delete tab, to show BIOS set up.
  • in BIOS setup, find the USB port see if it is Enable or Enable it.
  • save the changes and exit.
OS Problem:
  • Update your system to Microsoft, SP1, SP2 and SP3, browse the MS website for any drivers update that applicable to your system.
  • at the link below, see some updates to MS website:
http://www.microsoft.com/windows/downloads/default.aspx
Drivers Problem:
  • update your system to Unit manufacturer or Motherboard Manufacturer for new drivers update of your system.
  • at the link below, see some updates to Intel websites.
http://downloadcenter.intel.com/
thank you for using Fixya
aclamonte
Dec 13, 2008 | Intel 845GE Motherboard
Sata drive not detected
just no other solution except upgrading BIOS properly
Sep 24, 2008 | Seagate Barracuda 7200.10 500 GB SATA Hard...
I have a acer aspire 5050 computer, what was on windows vista, but now on windows xp, my computer as to many problems whatt i carnt get rid of, this isent becose i changed my windows, its just what the...
format , and reload windows. if its bios settings ,download a bios update or flashin software to clear it. Very Important! Reload the right drivers after reloading windows, driver conflicts give lots of trouble.
Jul 25, 2008 | Acer Computers & Internet
Toshiba Satellite Pro 4600 Notebook Logo
53 people viewed this question
Top Toshiba Computers & Internet Experts
Brian Sullivan
Brian Sullivan
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
