Question about Kenmore Dishwashers
After the rinse and dry cycle, there is a white film on the dishes
  • stmartined Feb 18, 2009
    I have been using "Jet Dry" and it still did not work.
  • 10,865 Answers
Use a rinse aid product in the dishwasher and your white film will go away.
Posted on Feb 18, 2009
  • Joe Hogan Feb 18, 2009
    In that case, I would have the water tested by a reputable company such as culligan who can install devices on the water to purify it and make it suitable for doing your dishes, clothes etc.
I have a new stainless steel Samsung dishwasher. It doesn't seem to be drying properly. Dishes and dishwasher still very wet after cycle is completed.
Hello
Your dishwasher has been designed to use a liquid rinse aid. Pouring a liquid rinse aid into the proper recepticle in your dishwasher when you add dish detergent greatly improves drying performance. You can further improve drying performance by selecting the Sanitize option, in addition to the other options you've selected, and increasing the water temperature.For Best Results, use Jet-Dry Turbo
Spots and film form in your dishwasher's rinse cycle, when detergents are already down the drain. FINISH® JET-DRY® Rinse Agent works in the rinse cycle, lowering the surface tension of water and causing it to sheet. Better rinsing results in less spots and film.
If these recommendations do not improve drying time, please contact Samsung Customer Care
Sep 07, 2011 | Samsung 24 in. DB5710DT Stainless Steel...
Frigidaire dishwasher FDB1500LFCO is not cleaning dishes properly. Glasses have a cloudy apprearance, other dishes are not clean, silveware is a mess. Have hard water so am using LemonShine for hard...
The scum, film and white residue problems have started since the reduction of phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
Dishwasher Residue and Film on Dishes
heatman101
Dec 28, 2010 | Frigidaire FDB1502RG Built-in Dishwasher
White film on dishes and still dirty.
Check rinse aid is actually dispensing - turn it up to max for a while to clear it, and check level is going down after a week.
If you suffer with hard water - your heating element may need replacing as it is probably furred up.
Jun 06, 2010 | Miele G892SC SS Dishwasher
Dishes are left with a white film.
The problem is hard water. Go to www.dishwasherfilter.com. They have a new product out that solves this problem once and for all. It filters the water entering your dishwasher and removes the hard minerals that cause these spots. Very affordable and guaranteed to leave your dishes looking amazing every time.
Jan 06, 2010 | Bosch 24 in. SMU20 Built-in Dishwasher
A white nasty film on the dishes after washing
Check to make sure there are no bits or trash or paper around the bottom parts of your dishwasher. Place a bowl of vinegar on the bottom rack of your empty dishwasher. Run your dishwasher through a complete cycle.
Mar 23, 2009 | Dishwashers
I have a white film left on the dishes i've had this dishwasher for about 4 years and this just started
Place a cup of vinegar in top rack corner (upright) and run an empty cycle to clean any build up.
Stop using any rinse-aid (jet-dry etc.), if the detergent you're using already has it included. Too much rinse-aid can create a white film on your dishes. A good way to check for rinse-aid build up is to run your fingers on the inside of the cabinet and check for a white powdery residue on your fingers. You can also run the dishwasher for a couple of minutes and check for excess suds in the water when you open it. Excess suds would indicate a rinse-aid build up.
Run the hot water at the tap before starting the cycle and make sure it's at the recommended temperature (120-140°F).
Mar 05, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Motor and pump replaced still not getting dishes clean
Dishwasher rinse water is soapy
if you noticed the white film after they were dry it's your water if not reduce the amount of detergent i prefer the powder mysef
Feb 20, 2009 | KitchenAid Dishwashers
Soap film on dishes
Rodney B if you are sure that the white film is detergent and not hard water deposits, then look at how you are using the detergent. When you watch the TV ads for dw detergents, they are showing baked on/extemely dirty dishes being put in the dishwasher and coming out clean. Well they do this as the dw detergent is designed to break down protein based food products. Fats, oils, and such. If you are prewashing your dishes before putting them in the dishwasher, then there is nothing for the detergent to attack and attach to, so it ends up staying in the dishwasher. If you are going to rinse your dishes, then you need only 1 tablespoon of detergent. Dishwashers are designed to clean using 4 parameters, hot water of 130 degrees, water, detergent,& pressure of the water jets. That is how they clean dishes. Now if this is hard water deposits, switching to an enviromently friendly detergent which is high is Citric Acid (What gives Tang drink its tartness) this will reduce this issue. Hope this helps
Jan 30, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Dishwashers Logo
62 people viewed this question
Top Kenmore Dishwashers Experts
Fred Sops
D. E. Hev
Raisin Brann
Level 1 Expert
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
