Question about Husqvarna "Chain Saw - 16" Bar, 3 Hp
I cant get the side cover back on, what do you have to do for it to cooperate?
  • c_dilip2003 Mar 08, 2009
    Cannot get the clutch cover back on.
  • 2,176 Answers
I have to assume that we are talking about a chain saw if not let me know what kind of product this is. Anyway if it a saw did you accidently trip the brake? if so you need to reset the brake to go around the clutch, sometimes you have to wiggle and finesse the cover to fit on. Look for any debris on the housings that would prevent it from fitting.
Posted on Feb 18, 2009
Mini cooper 2005 convertible top wont retract on passengers side
take the cover off the arm on the conv. and you'll most likely see a broken retractor arm. If you pull both sides off you'll see how the functional one works and how the other isn't working properly. With a little ingenuity, you'll be able to patch it and get it working.
Feb 19, 2013 | 2005 Mini Cooper Convertible
Show diagram
Copy following link for combo switch wiring:
http://waterheatertimer.org/How-to-wire-switches.html#combo
Combo requires neutral wire.
There are white wires that are twisted together, covered with wire nut and pushed to back of box
Nov 04, 2012 | Cooper Industries Cooper Wiring 274V...
I have the cooper K6107v-l motion sensor. Is there a way to adjust the time delay? The device shuts off after about 3 seconds, I want it to stay on for 5 minutes.
under the cover,of the device ,pry with a small screwdriver ,there is 3 controls side to side is the outer or wdth of range then in the center is time ,turn it clockwise you can adjust it up to 20 minutes
Jun 10, 2011 | Cooper Wiring Devices Motion Sensing...
Cant open boot on my mini cooper s touch pad not working
Lift the back seat. Under the seat you will find a cable with a ring attached. Pull the ring and the boot lid will open.
May 27, 2011 | 2004 Mini Cooper
My mini convertible roof leaks down the side just behind the back window, will it be covered under the warranty?
If the leak has been caused by a manufacturers defect and not by unusual weather conditions or damage from an accident, sharp object, mad ex, etc., yes , it should be something that Mini should fix at no charge.
Nov 08, 2010 | 2009 Mini Cooper
Airbags
The side curtain airbags on your MINI is a long piece that goes fro end to end on your vehicle. The dealership will NOT remove any safety equipment installed by the factory. I am guessing that your question is in regards to a child's safety in the rear of the vehicle. The airbags are designed to only extend down to cover the windows, and to stop a passengers head form striking anything that is entering your vehicle i.e.bumber/hood of another vehicle. There are no rear seat airbags in your vehicle.
Feb 05, 2010 | 2009 Mini Cooper
'03 Mini Cooper Xenon Replacement
If it's oem xenon than it should be 2 lamps. Because they had only xenon on the low beam (d2r type), however begin with changing the high beam. That one is inexpensive, so you could check if there are no other problems (like wiring).
Just open your hood and it should be clear how to open the cover for your high beam.
Dec 14, 2009 | 2003 Mini Cooper
Refrigerator just stopped cooling all of a sudden. neither side is cooling and the freezer side is barely freezing all of food is going to waste help please
is the compressor running ? if yes feel the cooper tubes around , the tiniest one is suppost to be hot if is not hot u have a leak call a tech . if it is hot open the freezer and take the back cover inside of the freezer if the coil is totaly covered with ice you have a defrost problem , check the timer , bimetal and heater
Jun 19, 2009 | Freezers
2004 Mini cooper convertible roof
Make sure that the microswitches in the rear trunk are all depressed. There is one where the parcel shelf (the cover that covers the view of the trunk from the outside) sits on the left that is usually the problem make sure that it is sitting on the microswitch (pull down on the closest side to you so it pivots forward and sits on the microswitch. Then make sure that the latch on the left side (drivers side) of the rear that allows easier access to the trunk switches the microswitch there. now close the trunk and try the conv top. the parcel shelf, the rear access latch and i think the trunk switches need to be depressed for the top to work. I know at least the first two.
Aug 04, 2008 | 2007 Mini Cooper Convertible
Husqvarna "Chain Saw - 16" Bar, 3 Hp Logo
161 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
