Question about Maytag LSE7806A Top Load Stacked Washer/Dryer
Dryer makes a loud sound when drying, sounds like shoes are in the dryer. Could be a belt. what needs to be removed to access the belt? When I open the dryer while running it is slow t stop tumbling
  • rheagreen Feb 19, 2009
    purchased in 2001. I can't say it takes a long long time to dry.
    How can I tell if I need a blower impeller? How do I access it?
  • mlord4 May 11, 2010
    you need blower impeller how old.dose it take longer to dry
Belt is slipping make loud noise when in use
Posted on Feb 27, 2009
    Problem Solver:
  • 20 Answers
Just call me mark mlord4@hotmail.com
Posted on Feb 20, 2009
What is making mywhirlpool/admiral electric dryer sound loud and thumping noise
You dryer belt may be shot and a piece of rubber is missing making it jump while working. Needs replacing before it completely quits. It will eventually just break apart.
Apr 13, 2015 | Admiral Dryer. 6.5 cu. ft. Electric Dryer...
My dryer (maytag atlantis) has started making a loud clunking noise with each revolution. its still drying fine but sounds terrible. any thoughts?
A loose belt will allow the drum to slip when clothes hit the paddles in the drum. It sometimes sounds like a pair of tennis shoes are in the dryer when it slips and is usually rythymic.
These machines also use drum rollers that can make a racket when they go bad.
http://www.repairclinic.com/Maytag-Dryer-Parts
Good luck.
Mar 02, 2011 | Maytag Dryers
My dryer is making this incredibly loud noise that sound as though there is a shoe being dried inside. It makes this loud thumping noise, and squeaks too. Help!
ALWAYS UNPLUG YOUR DRYER BEFORE STARTING ANY REPAIRS
Your problem sounds like drum rollers have flat spots on them or in need of lubrication, or maybe your drum belt has slipped off of the idler arm pulley.
Note: This method works with most front loading machines.
Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer.
Note: Some tops hinge and tilt backwards so they do not have to be removed and the electrical console with stay with the lid.
Also remove the lint filter and the screws holding the lint filter housing in place.
Be REAL CAREFUL not to knock any of the wires off of the timer switch. Then remove the top of the dryer.
Remove the front of the dryer. This will expose the drum and belt. Remove the drum and belt and this will expose the drum rollers, idler arm pulley and motor.
Now is a good time to check the belt to see if it has slipped off of the idler arm pulley and also to check the belt condition for wear.
Be sure to note the route of the belt, this will come in handy when you go to reinstall the belt.
Check your drum rollers for flat spots or wear, if they have flat spots or wear on them replace them.
If the drum rollers don't have flat spots or wear on them then they probably only need lubrication. Lubricate the shaft of the rollers with a good grade of machine oil such as 3 in One oil. Reassemble the dryer, plug back in. This should solve your noise problem.
For this FREE answer, Please rate me
Oct 03, 2010 | Dryers
Loud banging sound when dryer is on much like when tennis shoes are drying, smell a burned rubber smell when door opens
Sound like either your belt or your bearings. Either way, I wouldn't run it anymore until I got a professional appliance repair guy out to check it. We wouldn't want your house to burn down. Very dangerous!! I would also unplug it until then as well. Good luck and stay safe!
Jan 28, 2010 | Whirlpool Dryers
I have a G.E profile dryer dpgt750 cant seem to figure out how to take off the back panel, the dryer is making a loud noise sounds like possible belt problem. any ideals? THANKS MARTY
Marty, you need to remove the front cover on these and most dryers by removing lower front kick panel screws, then remove the front cover and then you access the top cover screws to remove top cover then you can access th drum belt
Nov 17, 2009 | GE Profile Harmony DPGT750GC Gas Dryer
Dryer drum stopped rotating, dryer blower continues to work.
The belt probably broke, and coincidentally happened while drying the shoes. The belt is easy to replace. Open the back and you'll probably see the belt laying on the bottom
Nov 10, 2009 | Bosch Axxis WTA 3510 Electric Dryer
I have a DLE 7177WM LG electric dryer is sound
Your problem sounds like drum rollers have flat spots on them or in need of lubrication.
If you have a front loading machine, Unplug the dryer, remove the front of the dryer. This will expose the drum and belt, remove the drum and belt and this will expose the drum rollers.
Check your rollers for flat spots, if they have flat spots on them replace them.
If they don't then they probably only need lubrication. Lubricate the shaft of the rollers with a good grade of machine oil such as 3 in One oil. Reassemble the dryer, plug back in. This should solve you noise problem.
Good Luck,
I hope this helps
Oct 14, 2009 | LG DLE7177 Dryer
Dryer very lound when drying
remove the entire outside casing exposing the drum and the belt on the drum. Make sure the belt isn't all stretched out and it is sitting on the corner rollers- both top and bottom.
Aug 25, 2009 | Kenmore 64902 Electric Dryer
Removing the back of the dryer
to get at belt you will need to get true the front of dryer.When you have top up there should be 2 screws on both inside corners on front panel remove them and lift up and towards you the front panel should come off.After that look under drum .Sounds like your belt sliped off the idler pully you can then put belt back on and reverse the steps.If any more help needed feel free to ask hope i fixya:)
May 21, 2009 | Kenmore 64852 Electric Dryer
Maytag LSE7806A Top Load Stacked Washer/Dryer Logo
222 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
