Question about Konka FL2799U TV
Picture is stretched on top and compressed on bottom
I have a Konka TV that I got from my bf, and the picture just started looking weird. The top half of the tv is really stretched out and makes people look like their foreheads are bigger than their head and the bottom half is really compressed and squished together. When watching aa show it makes everyone look like little people. Is there a way I can fix this speeding little to no money?
Thanks in advance
    Champion:
  • 252 Answers
The problem of your tv is in the vertical section,you need to replace the capasitor in vertical section .
Posted on Feb 18, 2009
Picture is stretched on top and bottom of screen
you have a vertical linearity problem. change the vertical output and components.you need a qualified tv technician to solve this problem
Aug 15, 2008 | Emerson EWF2703 27" TV
Model 42mf231d/17 42" plasma
If the loss of picture is either on top half or bottom half of screen. there are y buffer boards that go from top to bottom on left side of screen when looking at back that control those sections. when there is loss of half of picture then buffer associated with that area would be at fault and would need to be replaced. when i see a degrading symptom such as loss of picture on top half or bottom half leading to no picture issue normally you would check heat syncs on y sustain board and if not heating up after a few minutes of being turned on would recommend replacing y main and both y upper and lower y buffer boards as they complete a circuit
Jun 04, 2008 | Philips Magnavox 27MS343S 27" TV
Adjusting screen size
Make sure you dont have picture cropping on in your settings. If you do, it will crop about an inch or more off all sides of your picture.
Feb 13, 2008 | Konka KDL32AT23U 32 in. LCD Television
Wife spilled water on back of television
You burned out a resistor, capacitor or possibly a printed circuit trace on the solid state printed circuit board. This is going to take some troubleshooting in a high voltage area. If you have no TV repair experience working on high voltage circuits and solid state printed circuit boards, play it safe and have a pro take a look at the set. Good Luck
Feb 11, 2008 | Sanyo HT27546 TV
Konka TV
if you have an owners manual there is a special feature menu yu can go to that will fix how your picture fits on the screen. my tv was doing the same thing except it was the top and bottom until i played around with the remote and stumbled across the menu.
Jan 02, 2008 | Konka K2001UM TV
Sanyo TV stretches outwards and shakes
If the picture is closing (top to bottom) and goes back to normal when you hit it you probably have a bad solder connection on IC501 (location number) the vertical deflection IC on a metal heat sink. If you mean outwards as in side to side as it looks in the picture, I don't know specifically where to solder but get a magnifying glass and look for suspected bad solder connections. Look for the word width if it is there. It is good that you a confident in soldering.
Dec 27, 2007 | Sanyo DS27910 27" TV
Toshiba 32 inch tv made1990
yes,you can adjust it by your remote control,find the service menu and from there you can now adjust the vertical from of your tv.
Oct 30, 2007 | Toshiba 32AF43 32" TV
I have a Mitsubishi VS-60.. With a Picture
Vertical IC outputs , vertical Capacitors are most like the culprit on your deflection panel. good luck
Aug 16, 2007 | Mitsubishi VS-50501 50" Rear Projection...
HP flat screen tv
our hp flatscreen sometimes has a black strip across the top of the screen....resembling something "leaking"
Apr 30, 2007 | HP PE4200N 42 in. EDTV Plasma Television
Solution
You have a bad vertical output IC or a bad capacitor(s) in the vertical driver or output circuits. Not a job for the user to do unless you have the proper tools as well as a service manual. Good Luck
Mar 28, 2007 | Konka K2386U 23" TV
Konka FL2799U TV Logo
136 people viewed this question
Top Konka Televison & Video Experts
Electro Med Services...
Paul Bade
Are you a Konka Televison and Video Expert? Answer questions, earn points and help others
