Question about LG WM1814CW Front Load Washer
Mildew/moldy seal My seal if moldy all around the inside. We live in Colorado where it is very dry climate. Has this been a problem for others.
    Sergeant:
  • 160 Answers
This moldy look could also be due to alot of 40 degree or less washing temperatures where the bacteria cannot be killed therefore a once a month maintenance wash at max temp would help solve this.
Posted on Feb 22, 2009
A service tech told us to run an empty sanitary cycle with bleach and vinegar every few months to stop the mildewy smell.
Posted on May 02, 2009
    Genius:
  • 1,075 Answers
It dosent matter where you live,mouldy resudure is a common problem.lets fix your problem, take a simple dishwasher tablet put it in with some old rags or dish cloths and run it through your machine x2 .then run your machine as normal also run a hot wash every now and again,this will elemanate any problems you have hope this helps .adrian
Posted on Feb 18, 2009
Smell of mildew in washer
They make products to eliminate this mildew, check at the store.
Aug 30, 2017 | Washing Machines
My Maytag 9000 started to smell moldy. I tried cleaning the seal, running vinegar through a wash and drying the whole thing out but nothing works.
First pull out soap dispenser all the way ,clean it and inside the hole with mold and mildew cleaner let it soak. Use washer magic on door seal rubber Glover and a rag get in all the creases let it soak at least 15 min. Than that a cleaner called affresh. Taplets. Use two place in tub an run a clean cycle most front loaders have this cycle .if it doesn't max everything hot water extra rinse heavy soil . repeat 1 more time all steps. Than 1x a month pull dispenser clean ,clean door seal and use 1 tablet on clean cycle. Only use 2 table spoons of detergent and only use HE soap
Oct 18, 2015 | Maytag Washing Machines
Moldy mildew smell won't go away.
When I get the mildew smell , I run the machine empty and only use bleach. Then when done leave the door open to dry out. Works every time.
Oct 23, 2010 | Kenmore 3.5 cu. ft. Front Load Electric...
Moldy gasket
It because the mildew is not just on the gasket, but it is in the tub and in the pump and discharge hose as well. You need to reduce/eliminate the mildew in those parts. There is a couple of things you should do to reduce the causes of mildew.
1. Run the machine once a month using hot water and two cups of vinegar to clean out the machine. You might need to repeat this a few times to completely clean out your machine.
2. Follow the manufacturer's instructions for the about and type of laundry detergent to use with your wash. Using too much detergent causes a build up of detergent on the tub which encourages mildew growth.
3. After your final wash of the day, leave the door and laundry detergent open, wipe dry the gasket with a cloth.
4. If the above steps does not help, try a commercial product like Affresh.
Hope this helps you.
Jul 22, 2010 | Frigidaire GLTF2940ES Front Load Washer
Moldy smell from kenmore fridge model #970-43269...drip pan is dry...unable get inside seems to be a sealed unit. Only 17 months old
This is most likely your gasket that has gotten molded. Take a close UNDER the gasket aroud the door seal to see if there is any mildew or mold. If this is the problem, then you may contact us for parts for this unit.
You can get in touch with us at:
http://www.fixya.com/repair/d499389-accurate_appliance_repair_service
from 7 AM until 9 PM CST Monday through Saturday.
We will tell you how to remove/install parts whe you get your parts and supplies from us here at Accurate Appliance Repair & Parts Supplies.
Than you, Ella
Nov 27, 2009 | Microwave Ovens
Same problem. Stinky, moldy, gunky. Clothes won't clean.
First take a gallon o bleach pour it in on hot and run,then from know on after washing leave the door open so it can dry out and not mold between loads.
Nov 15, 2009 | Frigidaire GLTF2940ES Front Load Washer
Allways smells like mildew when open up
Yup, my front loader has the same issue. I found the rubber seal around the door has a fold in it that holds water and sometime candy wrappers and various stuff from pockets.
By wiping the fold in the seal out on occassion and not closing the door in between uses, the issue was resolved.
Jul 26, 2009 | Whirlpool Duet GHW9150P Front Load Washer
LG washing machine has AWFUL mildew smell
Same problem and I was told to only use detergents with "HE" on the front of them for high energy. the soap without HE is too foamy and hence never truly drains out and causes a mildew smell. I also purchased something called "A" Fresh that I run in the washer every 6 weeks to keep the smell out. I got it at an appliance store for about $11.00 for 3 tablets
Sep 04, 2008 | LG WM-2277HW Front Load Washer
Dishes not drying and mildew growing in dishwasher
I totally agree with Solution #1. We have a Whirlpool (apparently Maytag is the same) and it gets moldy 2 days after it has been run. The maintenance guy came out and said we had to use the rinse cycle every day. For an $800 dollar dishwasher (which is less than 1 year old!) I expect more.
Jul 09, 2008 | Whirlpool Gold 24 in. Built-In Dishwasher...
Mold & Smelly in Washer
Shepherd, Finkelman, Miller & Shah, LLC, is currently investigating defects and other problems in certain front-loading washing machines manufactured and/or sold by Whirlpool, Kenmore, and LG Electronics, including Kenmore Elite HE3 front load washers, Whirlpool Duet front load washers and LG Tromm, LG XL and other LG model front load washers, which result in the growth of mold/mildew in the machines and which can cause the staining of clothes and other problems.
On August 29, 2007, SFMS filed a Complaint against Sears Holding Corp. involving its Kenmore HE, HE2, HE3, HE4, HE5 and other front-loading automatic washers. If you own a front-loading washing machine that is manufactured by any of the above-mentioned companies and are experiencing the growth of mold/mildew in the machine, visit the following website: www.frontloadwasherclassaction.com
Dec 18, 2007 | Whirlpool Duet GHW9150P Front Load Washer
LG WM1814CW Front Load Washer Logo
164 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
